Test stepper motor amperage?
Duet Web Control
    supset
    Is there a way to test the stepper motors amperage, power, to see what its specs are via commands
    Assuming you have a stepper motor that you have no idea what the specs are, but you want to find out
    That would be cool
    b
      The steppers are dumb devices, they don't know anything about themselves, so we can't really ask. You can kind of test it yourself by starting from a low current value and seeing how it behaves. At very low values it might not even move or stall very easily, and as you increase the current it will get more powerful, and as you go up and up it will just start to get hot. You might also be able to find specs from a similar sized/length motor, but that's kind of dodgy. Better to just buy something with a spec sheet. Life's too short to mess with stuff like that.
      undefined 1 Reply Last reply 25 Aug 2020, 05:12 Reply Quote 0
        supset @Phaedrux
        @Phaedrux agreed lol - test until just to touch and a bit lower to keep just high warm
        Tks
        b
          Veti
          measure the resistance of one phase
          then google for stepper motors with that resistance and the same length. that will give you a good starting value for the current requirement.
          undefined 1 Reply Last reply 25 Aug 2020, 15:52 Reply Quote 2
            supset @Veti
            @Veti
            they are a little older and weaker than I need, I decide to pick up these
            https://www.moonsindustries.com/m/p/nema-17-high-precision-hybrid-stepper-motors/ms17ha4p4200-000004611110015912
            I required a 34 max millimeter length
            They should do the trick - replacing the stock ones of a Cetus MK3 - Proof of concept
            Thanks guys
            1 out of 5
