    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.0k
    • jschallundefined
      jschall
      Hi, bought an E3D ToolChanger about a month ago, totally new to RRF and duet.
      https://github.com/Duet3D/RepRapFirmware/issues/421
      I have my esteps calibrated correctly. I can have my printer extrude a given length of filament and the extruded filament will be just under the expected length and it will weigh what I expect it to weigh.
      I reduced my extruder jerk, acceleration and max speed to ensure no missed steps.
      Nonlinear extrusion is disabled.
      However, when I print this part with pressure advance on (set to 1.0, calibrated using this script), it weighs 20% more than I would expect it to weigh based on the total extrusion in the file. If I have pressure advance set to zero, it weighs just under the expected weight.
      I've tried with and without retractions, with the slicer set to generate relative moves, and with the slicer set to generate absolute moves.
      At the end of the print, the reported extruder position is almost exactly what it is supposed to be.
      So, questions:
      • Which variable exactly in the code does the reported extruder position come from?
      • Can someone give me an introduction to the codebase? Is there developer documentation somewhere?
      • Is "COMPENSATE_SPEED_CHANGES" typically enabled by default? I have whatever firmware came on the board.
      • Is "stepsPerMm" logged somewhere?
      • Is there a way to count total steps on the extruder drive?
      jschall created this issue in Duet3D/RepRapFirmware
      closed Part 20% over weight predicted by slicer #421
      • jschallundefined
        jschall
        @dc42 just hoping to bring this to your attention, I'd really like to work out what is going on here.
        • Vetiundefined
          Veti
          @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
          how long is your bowden tube? A Value of 1 is VERY high.
          Very long bowden (800mm+): S0.7 and up
          also reducing extruder jerk is counter productive for pressure advance.
          also you should consider updating to at least 2.05.1. 2.03 is very old.
          jschallundefined 2 Replies Last reply Reply Quote 0
          • jschallundefined
            jschall @Veti
            @Veti said in RRF 2.03 pressure advance causes 20% overextrusion:
            790mm. The value for PC is higher than the value for PLA. It is tuned correctly.
            No significant changes to pressure advance since then according to the history in DriveMovement.cpp. Not opposed to upgrading, just don't think it will change anything.
            • jschallundefined
              jschall @Veti
              It shouldn't change the number of total steps taken.
              • Vetiundefined
                Veti
                pressure advance does really quick movements back and forth.
                there could potentially be slipping filament. the titan extruder does not have the tightest grip on the filament.
                jschallundefined 1 Reply Last reply Reply Quote 0
                • jschallundefined
                  jschall @Veti
                  The right way to confirm a firmware issue vs a mechanical issue is to log the net steps sent to the motor driver through the entire print. It should be exactly or almost exactly the same on the print with and without pressure advance.
                  That said I'm personally almost beyond a shadow of a doubt on a firmware issue.
                  • jschallundefined
                    jschall
                    Another observation is that overextrusion does NOT happen when I just print a simple cube. I suspect it may have something to do with travel moves or something.
                    Anyway, there's got to be an asymmetry in there somewhere...
                      Update to 2.05.1 to get on recent code.
                      Post your config.g.
                      jschallundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      • jschallundefined
                        jschall @Phaedrux
                        @Phaedrux config.g
                        Using extruder 2 (counting from 0) to print
                        And some stuff stored in memory currently:
                        M566
                        Maximum jerk rates (mm/min): X: 500.0, Y: 500.0, Z: 60.0, C: 6.0, E:
                        800.0:800.0:200.0:800.0, jerk policy: 0
                        M566
                        M572 D2
                        Extruder pressure advance: 1.960, 0.000, 1.000, 0.700
                        M203
                        Max speeds (mm/sec): X: 583.3, Y: 583.3, Z: 20.0, C: 83.3, E: 33.3:33.3:33.3:33.3, min. speed 0.50
                        M201
                        Accelerations (mm/sec^2): X: 6000.0, Y: 6000.0, Z: 400.0, C: 400.0, E: 6000.0:6000.0:1000.0:6000.0
                        • jschallundefined
                          jschall
                          Going to try printing two cubes, to see if it is travel moves that are causing the problem.
                          Then I'll update to RRF 2.05 at least, if not RRF3.
                          • botundefined
                            bot
                            Are you seeing any underruns on the prints that are overextruded? Perhaps, if there are underruns, the moves that are not being ammended would have had PA applied to them, to balance other moves, but because of the underrun the PA was not applied in a balance manner.
                            I'm not sure if this is actually possible, it's wild speculation, but it's a scenario I've wondered about before.
                            *not actually a robot
                            • jschallundefined
                              jschall @bot
                              @bot
                              Will check now.
                              Printing 2 cubes did not cause overextrusion...
                              • jschallundefined
                                jschall
                                I'm really surprised there's no counter anywhere for total steps taken on each drive. Maybe I should try to add that (would have to work out how to build).
                                Alternatively I can hook up a logic analyzer and have it count the steps...
                                • jschallundefined
                                  jschall
                                  Logic analyzer capturing, wrote a python script to analyze the results, running the file with pressure advance now, then I'll run without.
                                    Why 8x microstepping on the extruders?
                                    M350 E8:8:8:8 C8 I0
                                    What are the actual extruders?
                                    M566 X500 Y500 Z60 C2 E800:800:1200:1200				; Set maximum instantaneous speed changes (mm/min)
                                    M203 X35000 Y35000 Z1200 C5000 E2000:2000:2000:2000	; Set maximum speeds (mm/min)
                                    Your max speed is a bit low and might be limiting your retraction speeds.
                                    • jschallundefined
                                      jschall @Phaedrux
                                      @Phaedrux said in RRF 2.03 pressure advance causes 20% overextrusion:
                                      M350 E8:8:8:8 C8 I0
                                      8x microstepping on extruders would be the default setting for E3D's toolchanger, I haven't touched that.
                                      The extruders are E3D titans.
                                      I reduced maximum speeds because I was starting to get skipped steps when commanding high speeds through the interface.
                                      • jschallundefined
                                        jschall
                                        Does Duet configure the trinamics in rising edge or falling edge mode?
                                        With PA at 1.0, as counted by a python script analyzing the output of my Saleae (assuming rising edge mode):
                                        fwd_count 6334445
                                        rev_count 5157566
                                        net_count 1176879
                                        mm 2979.440506
                                        Slicer says 2.48m filament use. Duet web interface confirms, says the file has 2481.7 mm filament use.
                                        Next up, PA at 0.0. If this comes out correct, it will be incontrovertible proof that there is a firmware issue with PA causing overextrusion.
                                        • jschallundefined
                                          jschall
                                          The python script: step_counter.py.txt
                                          The data with PA: https://drive.google.com/file/d/16LW2Xb2MWsUTvyCdSjDqBvFwDXq1xOuR/view?usp=sharing
                                          • jschallundefined
                                            jschall
                                            Ah, the TMC 2660 doesn't have a falling edge mode, only rising edge and both edges. I misread the datasheet.
