    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.6k
    • jschallundefined
      jschall @Veti
      @Veti said in RRF 2.03 pressure advance causes 20% overextrusion:
      @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
      However, when I print this part with pressure advance on (set to 1.0, calibrated using this script),
      how long is your bowden tube? A Value of 1 is VERY high.
      Very long bowden (800mm+): S0.7 and up
      790mm. The value for PC is higher than the value for PLA. It is tuned correctly.
      also reducing extruder jerk is counter productive for pressure advance.
      also you should consider updating to at least 2.05.1. 2.03 is very old.
      No significant changes to pressure advance since then according to the history in DriveMovement.cpp. Not opposed to upgrading, just don't think it will change anything.
      • jschallundefined
        jschall @Veti
        It shouldn't change the number of total steps taken.
        • Vetiundefined
          Veti
          pressure advance does really quick movements back and forth.
          there could potentially be slipping filament. the titan extruder does not have the tightest grip on the filament.
          jschallundefined 1 Reply Last reply Reply Quote 0
          • jschallundefined
            jschall @Veti
            The right way to confirm a firmware issue vs a mechanical issue is to log the net steps sent to the motor driver through the entire print. It should be exactly or almost exactly the same on the print with and without pressure advance.
            That said I'm personally almost beyond a shadow of a doubt on a firmware issue.
            • jschallundefined
              jschall
              Another observation is that overextrusion does NOT happen when I just print a simple cube. I suspect it may have something to do with travel moves or something.
              Anyway, there's got to be an asymmetry in there somewhere...
                Update to 2.05.1 to get on recent code.
                Post your config.g.
                jschallundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • jschallundefined
                  jschall @Phaedrux
                  @Phaedrux config.g
                  Using extruder 2 (counting from 0) to print
                  And some stuff stored in memory currently:
                  M566
                  Maximum jerk rates (mm/min): X: 500.0, Y: 500.0, Z: 60.0, C: 6.0, E:
                  800.0:800.0:200.0:800.0, jerk policy: 0
                  M566
                  M572 D2
                  Extruder pressure advance: 1.960, 0.000, 1.000, 0.700
                  M203
                  Max speeds (mm/sec): X: 583.3, Y: 583.3, Z: 20.0, C: 83.3, E: 33.3:33.3:33.3:33.3, min. speed 0.50
                  M201
                  Accelerations (mm/sec^2): X: 6000.0, Y: 6000.0, Z: 400.0, C: 400.0, E: 6000.0:6000.0:1000.0:6000.0
                  • jschallundefined
                    jschall
                    Going to try printing two cubes, to see if it is travel moves that are causing the problem.
                    Then I'll update to RRF 2.05 at least, if not RRF3.
                    • botundefined
                      bot
                      Are you seeing any underruns on the prints that are overextruded? Perhaps, if there are underruns, the moves that are not being ammended would have had PA applied to them, to balance other moves, but because of the underrun the PA was not applied in a balance manner.
                      I'm not sure if this is actually possible, it's wild speculation, but it's a scenario I've wondered about before.
                      *not actually a robot
                      • jschallundefined
                        jschall @bot
                        @bot
                        Will check now.
                        Printing 2 cubes did not cause overextrusion...
                        • jschallundefined
                          jschall
                          I'm really surprised there's no counter anywhere for total steps taken on each drive. Maybe I should try to add that (would have to work out how to build).
                          Alternatively I can hook up a logic analyzer and have it count the steps...
                          • jschallundefined
                            jschall
                            Logic analyzer capturing, wrote a python script to analyze the results, running the file with pressure advance now, then I'll run without.
                              Why 8x microstepping on the extruders?
                              M350 E8:8:8:8 C8 I0
                              What are the actual extruders?
                              M566 X500 Y500 Z60 C2 E800:800:1200:1200				; Set maximum instantaneous speed changes (mm/min)
                              M203 X35000 Y35000 Z1200 C5000 E2000:2000:2000:2000	; Set maximum speeds (mm/min)
                              Your max speed is a bit low and might be limiting your retraction speeds.
                              jschallundefined 2 Replies Last reply Reply Quote 0
                              • jschallundefined
                                jschall @Phaedrux
                                @Phaedrux said in RRF 2.03 pressure advance causes 20% overextrusion:
                                M350 E8:8:8:8 C8 I0
                                8x microstepping on extruders would be the default setting for E3D's toolchanger, I haven't touched that.
                                The extruders are E3D titans.
                                I reduced maximum speeds because I was starting to get skipped steps when commanding high speeds through the interface.
                                • jschallundefined
                                  jschall
                                  Does Duet configure the trinamics in rising edge or falling edge mode?
                                  With PA at 1.0, as counted by a python script analyzing the output of my Saleae (assuming rising edge mode):
                                  fwd_count 6334445
                                  rev_count 5157566
                                  net_count 1176879
                                  mm 2979.440506
                                  Slicer says 2.48m filament use. Duet web interface confirms, says the file has 2481.7 mm filament use.
                                  Next up, PA at 0.0. If this comes out correct, it will be incontrovertible proof that there is a firmware issue with PA causing overextrusion.
                                  • jschallundefined
                                    jschall
                                    The python script: step_counter.py.txt
                                    The data with PA: https://drive.google.com/file/d/16LW2Xb2MWsUTvyCdSjDqBvFwDXq1xOuR/view?usp=sharing
                                    • jschallundefined
                                      jschall
                                      Ah, the TMC 2660 doesn't have a falling edge mode, only rising edge and both edges. I misread the datasheet.
                                      • jschallundefined
                                        jschall
                                        With no pressure advance: https://drive.google.com/file/d/1oFvrJnxZc6fvLlGZqTdCqO7GB4Zfzdy_/view?usp=sharing
                                        Python script output:
                                        fwd_count 1942964
                                        rev_count 961423
                                        net_count 981541
                                        mm 2484.913924
                                        2.48m, dead on what the slicer expected.
                                        Proof positive that PA causes overextrusion and that this is a firmware bug, NOT a mechanical or configuration issue.
                                        CCS86undefined 1 Reply Last reply Reply Quote 2
                                        • jschallundefined
                                          jschall @Phaedrux
                                          What is recommended?
                                          Vetiundefined 1 Reply Last reply Reply Quote 1
                                          • Vetiundefined
                                            Veti @jschall
                                            @jschall
                                            x16 with interpolation enabled.
                                            also your thermistor config is wrong.
                                            Your bed is 4138 which is the default and very likely wrong.
                                            Your hotends are 4388
                                            So you might be printing at the wrong temperature.
                                            E3D uses 104-GT2 thermistors which is B4725 C7.060000e-8
