    I was having a hard time getting my fans wired and working.
    707
    • ROBOZILLAundefined
      ROBOZILLA @Phaedrux
      @Phaedrux
      Ok yes I hooked up wrong type of fans to out 4/5. I had mentioned that I was using 3 wire fans. I just didin't hook up yellow wire.
      I looked in my PC parts and found a 4 wire fan. Just to check. Hooked up on out 5 and it cam on high then went to med and stayed on. It also did this on 4/6 same results.
      Ok wired fans to out 7/8 changed g code as directed. Extruder fan nothing. Used panel due to get extruder to temp nothing. I did get blips from my own wired led like when I had fan on out 5 when temp hit 45c but no go. Went back to the due and tryed to toggal fan that showed up nothing. tryed to toggal in slicer nothing. Part or extruder. The 4 wire fan on out 4 still on.
        ROBOZILLA @Phaedrux
        @Phaedrux
        Before you say inline led or wiring. Pluged a compleatly differant fan in out 8 nothing. heated Extruder to 50c at 45 you can see the fan blip but no go.
        • Vetiundefined
          Veti @ROBOZILLA
          @ROBOZILLA said in I was having a hard time getting my fans wired and working.:
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
          M308 S1 P"temp1" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin temp1
          on a side note. your thermistor config is wrong. 4138 is the default and most likely wrong.
          What thermistor is 4388 ?
            ROBOZILLA
            4388 saw that for E3d V6 some where. I made some prints temp looks and acts good have a ir thermomiter seams to read a little low. I do have a sock on and it wasn't made for high temp. Reads bed ok.
            • Vetiundefined
              Veti @ROBOZILLA
              @ROBOZILLA
              E3D hotends use Semitec 104-gt2 if you set it in the configurator you get B4725 C7.060000e-8
              ROBOZILLAundefined 2 Replies Last reply Reply Quote 0
                ROBOZILLA @Veti
                @Veti
                I might have seen that as well. I wase't going to change it at all. I am wrighting down this note thou. I will see what happens.
                  ROBOZILLA @Veti
                  @Veti
                  4388 was for old firmwair. I made the change.
                    @Phaedrux said in I was having a hard time getting my fans wired and working.:
                    M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                    Change the S0 to S1. That might do it for the thermostatic fan.
                    ROBOZILLAundefined 1 Reply Last reply Reply Quote 0
                      ROBOZILLA @Phaedrux
                      @Phaedrux Both fans work. Thanks for the help! So the out 4-6 more for case fans?
                        Phaedrux Moderator @ROBOZILLA
                        They're for any low voltage output, not just fans. If you don't need PWM and tach pins, they would be more appropriate on those ports.
