HELP
if network and client computer support mdns you could access it as http://duet.local/ independent of the IP.
( if you changed
M550
in config.g to something other than duet, then use that name instead
https://duet3d.dozuki.com/Wiki/Gcode#Section_M550_Set_Name ) -
still don't think things a completely right.I don't see the duet anywhere in the router web interface
Well if the Duet has an IP address then it's got to be in there somewhere. Check for DHCP.
Well i managed to get up to step 11 this morning
got an to assign me an address went the DHCP route. Searched the ip it gave me and found the DWC and am in there poking around.
Not to confident on this step -
I think you're well on your way.
Down to the last step now checking M554 and M553 Gateway and Netmask ip.Found
the Netmask its good and for the life of me can't find the Gateway ip?
Cuz i don't know what that is -
if you used dhcp you don't need to set gateways and netmasks; if you decided to use a static ip then you should probably match the netmask and gateway of your computer connected to the same router
Well thank you......it says i am done. Guess i should shut it down and see if it will reconnect . On the DWC in the upper left corner it says Duet Test with a little box and the word off in a red box.whats this for and what's it indicating
We'll thats another problem the whole way i am sending this has changed since yesterday.
I can't attach any pics and when i hit reply it changes to a full blank page not the way it was yesterday with a small window at the bottom of the page and you could still see the chats above the reply you are typing.Dont know if i touched something i shouldn't have -
Hmm, I'm not sure. Has your browser been zoomed in or something like that?
The reply window box has a little black up down arrow at the top left you can use to grow and shrink it.
BINGO...zoom out and all is well
![0_1599250944661_Screen Shot 2020-09-04 at 1.21.15 PM.png](Uploading 22%)
now i still can't ad pic
logged out and in looks good -
DuetTest is the name of the printer as defined in the config.g file that came on the SD card from the factory.
Off probably means it's not connected to VIN?
Now that you're connected I suggest you go through the firmware update process I outlined earlier and then get a config file set from the web config generator tool.
Well put the AC to her and no smoke no fire the X Y stop switches work on the DWC so thats good. Are there any indicatores LED to show the Duet 5 is connected and or working
Not sure off hand for LEDs but you can send m122 and it should say if a duex is detected.
i remember seeing that earlier in the procedure but can't find it again
-bash: M122: command not found
is the response i get now -
You'd be sending that in the gcode console in the web interface. Or over USB terminal. It will spit back a diagnostic report.
