    Heater not working
    • NiklasPundefined
      NiklasP
      Hi, I just finished wiring up my printer and wanted to test the heaters. Bed works but due to any reason I can't get the hotend heater to work. I already tried a second one, changed from e0 to e1, measured if there is a break in the wiring ( about 15 Ohm so it should fit the 40W rating) and checked the thermistor that works as well.
      I'm using this one from trianglelab: https://de.aliexpress.com/item/32815934251.html?spm=a2g0o.store_home.productList_1322398741.pic_0
      (don't mind the whole code. I scraped the old config.g and uploaded a new one. Didn't do any other changes yet)
      M550 P"My Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2:3 E4 ; set drive mapping
      M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00:800.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00:12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00:180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00:20.00 E250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800:800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X370 Y370 Z400 S0 ; set axis maxima
      M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P200 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e1heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      T0 ; select first tool
      • Vetiundefined
        Veti
        check the 7.5A fuse if its blown using a multimeter
        • NiklasPundefined
          NiklasP
          Nop the fuse is fine. Just checked. In case if it's blown shouldn't the steppers also not work?
          • Vetiundefined
            Veti
            just checking, you have updated to firmware version 3.1.1?
            • NiklasPundefined
              NiklasP
              Yes I did. (FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2)
              • Vetiundefined
                Veti
                i dont see anything wrong in you config. your z settings are redundant but that does not matter.
                also i dont think that the mosfets are both broken.
                • NiklasPundefined
                  NiklasP
                  Ok not sure what the error was but it seems to work now. I formated the SD and unpacked the files from the Git into it. Then I installed the update to 3.1.1 again an uploaded a fresh firmware from the fw generator. No idea what went wrong before.
