    Duet Web Control 3.1.1 - Not accessible from all devices
    Duet Web Control
    744
      jay_s_uk
      There's no sort of filtering being done to prevent access.
      What board do you have?
        What exactly happens when you try and connect? Are you able to ping the IP from those computers?
        • HDavidundefined
          HDavid
          I am using the duet wifi.
          I get a connection time out once I try to connect:
          Ping result from only machine working:
          Ping result from an other laptop:
          I have other RaspberryPi Servers on the same network and can access them from any machine.
          David
            Does your wifi router have a block on connecting wired and wireless devices?
            • HDavidundefined
              HDavid
              I don't think so, I have multiple wire/wireless devices that inter-communicate properly.
              But that's a good guess and let you know if I found anything.
              • DeltaConundefined
                DeltaCon
                Are you SURE thhey are on the same network? I don't think so... You probably are using a router as accespoint / Switch, and it happens to DHCP in the same segment as your main router.
                If you think trial and error is dangerous, try routine. That's even more so!
                HDavidundefined 1 Reply Last reply Reply Quote 0
                • devpeepsundefined
                  devpeeps
                  Do you have an asus router? I have been seeing this more and more lately with them (I had the issue as well). Turn off Airtime Fairness.
                  • HDavidundefined
                    HDavid @DeltaCon
                    @DeltaCon
                    I only have one DHCP server and it is handle by my routeur.
                    The client on which it only work is connected to the router via wire and the duet is on the wifi.
                    I can ping any devices from any other devices, Wired or Wireless. But the duet board replies to ping from that one and only machine.
                    • HDavidundefined
                      HDavid @devpeeps
                      @devpeeps
                      No Asus Router
                      • Vetiundefined
                        Veti
                        can you plug another machine in by wire and try to ping it from there?
                        • HDavidundefined
                          HDavid @Veti
                          @Veti
                          I did, same result 😞
                          • HDavidundefined
                            HDavid
                            Here is an example of situation that confirms that I am on the same network:
                            I am on my laptop (192.168.1.12), I connect to my desktop(192.168.1.33) using remote desktop.
                            On my desktop I can connect to the duet (192.168.1.49). If I try to connect directly to the duet from my laptop, I get the connection time out.
                              That sounds like the router preventing wireless to wireless LAN communication, assuming the laptop is wireless and the desktop is wired in your scenario.
                              • Vetiundefined
                                Veti
                                what router is it?
                                  A Former User
                                  Smells like a firewall or indeed two different networks; compare the mac address for the gateway on each computer?
