    Paneldue crashing?
    PanelDue
    1.3k
    • Hornetriderundefined
      Hornetrider
      Hi there
      some time ago I have also expirienced the same behaviour of freezing communication between PanelDue and DuetWifi. And it allways happens when the Wifi Module reports a lost of connection.
      After running all latests updates, both on PanelDue and DuetWifi and resetting the Wlan Hotspot (finding a better channel) this issue was gone for a while.
      But now this week it started again.
      Today I have rebootet my Hotspot, to hopefully find a new and better 2.4GHz channel and therefore creating a stable connection.
      In my opinion the freeze of the comm is related to the procedure how the DuetWifi handles the Wifi connection initialisation and time out.
      I have also noticed, that right after restart of the DuetWifi and before the Wifi conn is established the communication between the PanelDue ant the DuetWifi is extremly delayed.
      For example:
      • Switch on DuetWifi
      • run Home all (during this period the Wifi Conn is not established as the machine has something different to do...)
      • after Home all and without promt of Wifi Conn-> try to activate a Makro or reading out files via PanelDue...extreme delay in 10+ sec
      • right after the Wifi has established a stable Connection everything works fine and in usual speed
      One more thing. The "Wifi lost conn" occurs shortly after the first connection build up (prompt by Duet) or even during a print.
      Only the STOP button on the Paneldue keeps working!
      Any ideas?
        Hornetrider
        Any comments at all?
          Phaedrux Moderator @Hornetrider
          @Hornetrider said in Paneldue crashing?:
          Please create a new thread with your issue. Include your config.g and homeall.g files since you mention those. Include what firmware version on the duet and paneldue. Thanks.
            Hornetrider
            HI @Phaedrux
            why a new thread if everything is explained here?
            Please find requested data below.
            xxxxxxxxxxxxxxxxx
            PanelDUE FW: 1.24
            Board: Duet WiFi 1.02 or later
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
            Duet WiFi Server Version: 1.23
            xxxxxxxxxxxxxxxx
            Diag:
            Send code...
            10.9.2020, 20:26:29 M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
            Board ID: 08DGM-917DA-G4MS8-6J9DD-3SN6R-1SVB9
            Used output buffers: 3 of 24 (21 max)
            Static ram: 30516
            Dynamic ram: 91948 of which 36 recycled
            Exception stack ram used: 560
            Never used ram: 8012
            Tasks: NETWORK(ready,640) HEAT(blocked,1240) MAIN(running,3740) IDLE(ready,156)
            Owned mutexes:
            Last reset 84:43:09 ago, cause: software
            Last software reset at 2020-09-07 07:42, reason: User, spinning module GCodes, available RAM 8028 bytes (slot 1)
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
            Error status: 10
            Free file entries: 10
            SD card longest block write time: 390.4ms, max retries 0
            MCU temperature: min 32.1, current 34.0, max 36.3
            Supply voltage: min 23.9, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: standstill, SG min/max 0/173
            Driver 1: standstill, SG min/max 0/155
            Driver 2: standstill, SG min/max 0/781
            Driver 3: standstill, SG min/max 0/1023
            Driver 4: standstill, SG min/max 0/176
            Date/time: 2020-09-10 20:26:15
            Slowest loop: 84.39ms; fastest: 0.09ms
            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 102, MaxWait: 82940312ms
            === MainDDARing ===
            Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
            === AuxDDARing ===
            Heater 0 is on, I-accum = 0.2
            Heater 1 is on, I-accum = 0.5
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 391.94ms; fastest: 0.00ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is running
              WiFi firmware version 1.23
              WiFi MAC address ec:fa:bc:2d:e8:d1
              WiFi Vcc 3.39, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 25672
              WiFi IP address 192.168.1.110
              WiFi signal strength -39dBm, reconnections 0, sleep mode modem
              10.9.2020, 20:26:11 Connected to 192.168.1.110
            XXXXXXXXXXXXXXXXXX
            Config:
            M552 S1 ; Enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M569 P0 S0 ; Drive X goes backwards
            M569 P1 S1 ; Drive Y1 goes forwards
            M569 P2 S0 ; Drive Z goes forwards
            M569 P3 S1 ; Drive E0 goes backwards
            M569 P4 S0 ; Drive Y2
            M584 X0 Y1:4 Z2 E3 ; Apply custom drive mapping
            ; Microstepping
            M350 X32 Y32 Z16 E16 I1 ; Configure microstepping without interpolation
            M92 X160 Y160 Z1600.00 E410 ; @32 X and Y Ratio 24:20 (2020.01.12)Set steps per mm for Bondtech BMG Extruder
            ; Speed & Acceleration
            M566 X600.00 Y600.00 Z80.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
            M203 X8000.00 Y8000.00 Z400.00 E6000.00 ; Set maximum speeds (mm/min)
            ;M203 X8000.00 Y8000.00 Z400.00 E6000.00 ; Set maximum speeds (mm/min)
            M201 X800.00 Y800.00 Z45.00 E3000.00 ; Set accelerations (mm/s^2)
            ;M201 X800.00 Y800.00 Z30.00 E3000.00 ; Set accelerations (mm/s^2)
            ; Motor Current
            M906 X1000.00 Y1000.00 Z900.00 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S5 ; Set idle timeout
            M208 X295 Y330 Z298 S0 ; Set axis maxima
            M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
            M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
            M574 Z1 S2
            ; Z-Probe Inductive
            ;M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
            ;G31 P500 X0 Y0 Z1.42 ; Set Z probe trigger value, offset and trigger height
            ;M557 X5:170 Y5:275 S40 ; Define mesh grid
            ; BLTouch
            ;M307 H4 A-1 C-1 D-1
            ;M558 P9 F100 H3 R0.3 T7000 A5 B1 ; Set Z probe type to switch and the dive height + speeds
            ;G31 P25 X-40 Y40 Z2.26 ; Set Z probe trigger value, offset and trigger height
            ;M557 X5:215 Y5:295 S55 ; Define mesh grid
            ; Precision Piezo
            M558 P8 C"zprobe.in+zprobe.mod" I1 R0.4 H2 F420 T3000 A5 B0 ; Set Z probe type to switch and the dive height + speeds
            G31 P500 X0 Y0 Z-0.5 ; Set Z probe trigger value, offset and trigger height
            M557 X5:285 Y5:330 S93 ; Define mesh grid
            ; Laser Filament Sensor
            ;M591 D0 P5 C3 R130:280 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
            ; Rotating Magnet Filament Sensor
            M591 D0 P3 C3 R70:130 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
            ; Heaters RRF3.0x
            ; Heaters RRF2.05
            ;M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
            ;M143 H0 S120 ; Set temperature limit for heater 0 to 120C
            ;M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
            ;M143 H1 S280 ; Set temperature limit for heater 1 to 280C
            ; Board Cooling
            M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
            M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
            M106 P2 H2:3 L0.15 X1 B0.3 T36:45 ; set fan 2 value
            ; Fans RRF2.05
            ;M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
            ;M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
            ;M106 P2 T36:46 H100:101:102 ; Set Fan speed to cool MCU
            M563 P0 D0 H1 ; Define tool 0
            ; MCU temp Adjustment
            M912 P0 S-9
            T0 ; Select first tool
            ;load config-override
            M501
            xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
            Homeall:
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 31 2018 02:05:14 GMT+0100 (Mitteleuropäische Normalzeit)
            G91 ; relative positioning
            G1 H1 X-300 Y-340 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X10 Y10 F6000 ; go back a few mm
            G1 H1 X-15 Y-15 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            G1 X147.5 Y167 F8000 ; go to first bed probe point and home Z
            M140 S50 ; Set Bed to 50DEC
            G10 S210 ; Set current tool temperature to 130C
            M116 ; Wait for the temperatures to be reached
            ;play sound
            M400
            G4 P200
            M300 P200 S523.25
            G4 P200
            M300 P200 S659.25
            G4 P200
            M300 P200 S739.99
            G4 P250
            M300 P285 S880.00
            G4 P450
            M300 P285 S880.00
            G4 P285
            M300 P625 S1108.73
            G4 P200
            G90
            XXXXXXXXXXXXX
            Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • Vetiundefined
              Veti @Hornetrider
              because it gets confusing for people who will start to get mixed up.
                Because this isn't your thread and it becomes incredibly difficult to keep the information straight. If you think this thread is relevant, include a link to it. It may seem draconian and unnecessary to you, but we ask that each individual issue be contained in it's own thread for the benefit of those trying to help you resolve it.
                  Hornetrider
                  @Phaedrux
                  ok, got it.
                  Better creating a lot of personal threads instead of keeping related information for the same event in one single thread.
                  No problem at all, thx for the advise.
                  @Veti
                  Sorry, don't get your point.
                    @Hornetrider Trust me, when you have a 200 comment long post with 3 people claiming they have the same issue with several long config.g and M122 reports it makes it incredibly difficult to provide accurate and quick support.
                    As I said, if you think this thread is relevant, include a link, thus tying the related information together without cluttering the two together.
                      Hornetrider
                      Just an additional info.
                      After rebooting my routers and setting up the Wifi to a less used channel, now the connection to the Duet Wifi has become stable again.
                      But this is a side effect and my impression is, that something in the handling of the Wifi connection reset on the Duet Wifi is odd.
                        You very well may be right, let's explore it in a dedicated thread.
                          Hornetrider
                          @Phaedrux
                          see here:
                          https://forum.duet3d.com/topic/18601/panel-due-hanging-up-after-loss-of-wifi
