    Noctua fan PWM issue
    1.2k
    • S13_Millsundefined
      S13_Mills
      Yep, they're 4-wire PWM fans. Noctua NF-A4x10 PWM.
        Have you see this?
        https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Connecting_4_wire_fans
          S13_Mills
          Yes - this is the guide I followed to connect them. They're connected as specified in the guide, but not working as expected.
            Which Duet are you using?
            The FAN- connection is an open drain output with a flyback diode connected to VFAN. The leakage in the flyback diode is very small, so it should be safe to connect the FAN- pin directly to the PWM input. However, if you are worried about the leakage then you cold connect a 1N4148 or similar diode between the FAN- pin and the fan PWM lean (cathode to the FAN- pin). I am running two Noctua 4-wire fans on Duet 3 in this way.
            Did you remember to set the fan PWM to be inverted, and to increase the pWM frequency to 25000 ?
              S13_Mills
              I had my Smart Effector off to change out some other components yesterday, and took the opportunity to re-make all the fan connectors and test some things.
              I tested both fans with a known good 12V supply - both were working. I reassembled everything, and haven't had an issue with it since...
              It seems that there was a dry(ish) joint somewhere between the Duet and the fans, and the voltage wasn't quite high enough on the fans for them to start reliably (apparently Noctua fans are known to need a high voltage to start - i.e. if there is too much droop on the 12V, they won't work).
              Everything seems to be working now, so I think this can be considered closed - thank you very much @Phaedrux and @dc42 for your help!
                You didn't say in your original post that you were using a Smart Effector. The magnetic joints on the effector prevent some makes of fan from starting, especially if you haven't alternated the rod directions so that they go N-S-N-S-N-S around the effector. I suspect that may have been the problem.
                • Psylenceoundefined
                  Psylenceo
                  If this helps you or anyone else this is how I have my 2 Noctua 4pin fans:
                  NF-A6x25
                  NF-A4x10
                  M950 F0 C"!out4" Q25000                         ; create fan 0 on pin out4 and set its frequency
                  M106 P0 C"Extruder" S0.2 L0.2:1.0 X1.0 H1 T60:180                  ; set fan 0 name and value. Thermostatic control is turned On, low low speed at 60c max speed at 180c+
                  M950 F1 C"!out5" Q25000                         ; create fan 1 on pin out5 and set its frequency
                  M106 P1 C"Part" S0.2 L0.2:1.0 X1.0 H2 T25:80                      ; set fan 1 name and value. Thermostatic control is turned on low speed at 25c and max speed at 80c
                  • devpeepsundefined
                    devpeeps
                    Thanks so much for all of this it helped me a lot. Question: How do I view the rpms if I connect it to the PB6 via a diode?
                      Phaedrux Moderator @devpeeps
                      @devpeeps said in Noctua fan PWM issue:
                      The RPMs should show up in the DWC dashboard.
                        If you are running RRF3.x then you will need to declare the tacho input in your M950 command. There is an example at https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M950_Create_heater_fan_or_GPIO_servo_port.
