    Duet Maestro 3.1.1 and 3D Touch V3
    475
    • Vetiundefined
      Veti
      @flopo76 said in Duet Maestro 3.1.1 and 3D Touch V3:
      M350 X64 Y64 Z64 I0 ; configure microstepping without interpolation
      the duet maestro support interpolation at x64, you should turn it on.
      you have to define the mesh with the probe offset in mind
      M557 X15:290 Y15:290 S128 ; define mesh grid
      G31 P25 X28 Y-35 Z0.512 ; set Z probe trigger value, offset and trigger height
      so your probing should start at X0 (or negative if possible) y 35 and not X15 Y15
      same for the max
      flopo76undefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        according to marlin config
        https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/Artillery/Sidewinder X1/Configuration.h
        sidewinder uses epcop thermistors. that is not what you have configured.
        • flopo76undefined
          flopo76
          Yes the thermistor i will correct that,soon as i resolf the ofset.Thanks
          • flopo76undefined
            flopo76 @Veti
            @Veti said in Duet Maestro 3.1.1 and 3D Touch V3:
            same for the max
            But if G31 is configured with x and y probe offset,should al made automaticaly the mesh grid. And whe i homed the Z the probe should go to centre off bed not the nozzle......
              Are you certain that you have configured the X and Y probe offsets with the correct sign? For example, assuming you have chosen the head reference point to be the nozzle, you have set the X offset to +28 which means that the probe is 28mm in the +X direction from the nozzle.
              • flopo76undefined
                flopo76 @dc42
                @dc42 said in Duet Maestro 3.1.1 and 3D Touch V3:
                Yes,tryed positive and negative for both x and y probe ofset. I used Wagster mod to install the 3d touch and used a wiki model to measure the probe offset from nozzle center . Same result in z homing nozzle at center off the bed x150 and y150
                • Vetiundefined
                  Veti
                  the homing position is defined in the homez / homeall script
                    A Former User
                    Imhop a genuine bl-touch is a p.o.s and a fake one even more so...
                    Best advice I could give is to fit an IR sensor or a precision piezo.
                    • flopo76undefined
                      flopo76 @A Former User
                      @CaLviNx said in Duet Maestro 3.1.1 and 3D Touch V3:
                      Have already printer with piezo sensor,smart efector,ir sensor al with duet board.And £d Touch works like a charm....
                        A Former User @flopo76
                        For now..... Give it time
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
                          Here's how to measure your offset accurately and easily.
                          That's not how it works in RepRap firmware. You're in charge of positioning everything based on the nozzle (aka head reference point)
                          Create yourself a diagram like this to help visualize it.
                          • flopo76undefined
                            flopo76 @Phaedrux
                            @Phaedrux said in Duet Maestro 3.1.1 and 3D Touch V3:
                            That's cool....Thanks man.
