    Blower fans for a duet wifi
    757
    • bigwood247undefined
      bigwood247
      Hi I'm wondering is there a blower fan in the current market that can be successfully pwm controlled like I've bought a sunon blower and it is really hard to control the speed its ither all on or basically no airflow I mainly print petg and nylon and I only need like fan on at 25 to 30 percent power if that I'm debating going with just a 40x20 4 wire noctua fan for part cooling also I just bought a second 5015 blower different company same deal I like the idea of blower fans but I cant find one that is good with only being powered at 30 percent speed
        What Sunon blower did you get? I have 2 different sunon models that work well. Though one of them is pretty weak and is only really useful at 100% anyway for PLA.
        https://www.digikey.ca/en/products/detail/sunon-fans/MF50151VX-B00U-A99/7691033?s=N4IgTCBcDa4KwE4C0BGAHGZA5AIiAugL5A
        You can try adjusting the PWM frequency for the blower. It may give you more control range.
        bigwood247undefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti
          currently i used this https://www.aliexpress.com/item/32985338508.html and can run at 25% for my petg prints
            bigwood247
            That's not a sunon it's a fystec and mine doesn't have 3 wires but I have another one that I'm gonna try that has 3 wires so thanks tho
              bigwood247 @Phaedrux
              @Phaedrux I'll have to try that one that u put the link up for does it have 3 or 4 wires those usually work better for pwm I've found I've tried frequency as low as 100 Hertz up to 10000 Hertz with no luck
                bigwood247
                My sunon blower is only 2 wires and its ither on 100 percent power or it barely blows at all no middle ground
                  bigwood247
                  Is there any blower fans that are pwm capable they usually have 4 wires?
                  • Vetiundefined
                    Veti @bigwood247
                    @bigwood247
                    not that i am aware of
                      I use Winsinn 12V blower fans from Amazon on the Hemera tools on my tool changer.
                        bigwood247
                        I just found a 5015 sunon blower that's 4 wire its this model MF5015VX-C05C-S99
                          bigwood247 @dc42
                          @dc42 so thst one works well with pwm control u can successfully control the speed?
                            dc42 administrators @bigwood247
                            @bigwood247 said in Blower fans for a duet wifi:
                            @dc42 so thst one works well with pem control u can successfully control the speed?
                            Yes, it even works at 10% PWM. The listing I purchased from was https://www.amazon.co.uk/gp/product/B07RSV5LTH/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1. They have a 24V version too.
                              bigwood247
                              https://www.ebay.com/itm/264486995606 I think this one will work too
                                bigwood247 @dc42
                                @dc42 thanks I'll try those
                                  Phaedrux Moderator @bigwood247
                                  The one I linked controls well down to 10%, though it doesn't move a lot of air through the duct at that point. Useful low range is probably 20% and at 100% it's very powerful.
