BlTouch not triggering, tried everything
I purchased the latest BlTouch but for the life of me can't get it to work. Got all the latest firmware that I know off.
Using the Duet 2 wifi.
Heater PWM 7 input
Everywhere i look it says something different so im really quite stuck...
attached is my config file, if someone could point me as to where im going wrong i will be so thankful!; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 14 2020 09:23:59 GMT+0100 (British Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"XL Printer" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P7 S1 ; physical drive 7 goes forwards M584 X0 Y1:4 Z2 E7 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E150.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y1500:1500 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X30 Y0 Z0 S1 ; set axis minima M208 X630 Y350 Z350 S0 ; set axis maxima ; Endstops M574 X1 S0 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop M574 Y1 S0 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P1000 X0 Y40 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X45:215 Y15:195 S50 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M307 H7 A-1 C-1 D-1 ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
post your retract and deploy script
1/ what version of the firmware are you using . try M122
( you are on version 3 of the config.g , but have you upgraded to version 3 firmware )
2/ Are you getting the red light and getting the in and out power on self test -
Supposedly auto-generated from their new tools.
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 14 2020 09:23:59 GMT+0100 (British Summer Time) M280 P0 S10 ; deploy BLTouch ; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 14 2020 09:23:59 GMT+0100 (British Summer Time) M280 P0 S90 ; retract BLTouch -
Board: Duet WiFi 1.02 or later (duetwifi102)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.03 (2019-06-13b2)
Duet WiFi Server Version: 1.23 -
You config is for the 3.xx firmware version.
YEP , you are running the version 3 config file , but still running version 2 firmware ..
upgrade to version 3 firmware or use the version 2 configurator
Ive tried upgrading to 3.0 but it doesnt seem to update the firmware... I used "duet2and3firmware-3.1.1.zip" and uploaded it
You need to upgrade to I THINK version 3 ? , then 3.1.1 .
I know you can't do it in one go !!! -
Lifesavers!!! yes 3.0 first worked!
Thank you all so much... hopefully, it's plain sailing now! -
This post is deleted! -
The bits which you normally get it wrong is offsets ( G31 ) , Which you say is level on the X axis , but the probe is 40mm behind the nozzle on the Y axis ?
And how you home !!! You need to use G30 to home Z
G31 P1000
Try G31 P25 instead.
