Solved Z probe back to micro sw.
So here is where im at now.
Ive got everything working including the endsw.
Unfortunately the dwc tells me z prob allrwady engaged at start of probe.
When i hit the estop for z the led goes out so the dwc is reading the switch. But no mater what i change the card still sees the switchbas open ????
Im lost -
include parameter I1 in the M558 command if you are using a normally-open switch.
sw set to n/ c
; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 Pe3 ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes forward
M569 P1 S0 ; Drive 1 goes backwards
M569 P3 S0 ; Drive 3 goes backwardsM569 P3 S1 ; Drive 3 (Extruder 0) goes backwards
; M92 X79.7 Y320 Z400.4 E96 ; Set steps per mm
M92 X79.2 Y320 Z400.5 E96 ; Set steps per mmM566 X1600 Y500 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000 Y1600 Z300 E1500 ; Set maximum speeds (mm/min)
M201 X500 Y500 Z300 E5000 ; Set accelerations (mm/s^2) is 500
M906 x950 Y1200 Z850 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
; M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
; M208 X495 Y495 Z460 S0 ; Set axis maximaM208 X0 Y0 Z0 S1 ; Set axis minima
M208 X500 Y500 Z500 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; Set endstops controlled by sw. Z controlled by capasitive sensor; Z-Probe
; M558 P4 H5 F100 T2000 ; Set Z probe type to capasitive and the dive height + speeds
M558 P4 H5 F100 T4000 ; Set Z probe type to capasitive and the dive height + speeds
G31 P500 X-42 Y-5 Z1.12 ; Set Z probe trigger value, offset and trigger height - is Nozzle hogerM557 X15:215 Y35:215 S20 ; Define mesh grid
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S120 ; Set temperature limit for heater 0 to 80C
M305 P1 T100000 B4400 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 240C; M307 H1 A245.3, C121.7, D4.0, S0.5 ; PID
; M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
; M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned offM106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0Chere is my conf g
; Enable Bed Leveling
;G29 S1 ;commented out Enable Mesh Bed Leveling -
Well if it's saying it's already triggered you need to invert the signal, so try adding
I1
to M558. -
and home all and home z
, home z
; homez.g
; called to home the Z axis
G91 ; relative positioning
G1 Z2.5 F6000 S2 ; lift Z relative to current position
G90 ; absolute positioning
G1 X51 Y20 F6000 ; go to first probe point
;G91 ; relative positioning
;G1 S2 Z2.5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
so I-1 got rid of the error but the sw. is still inactive
the led next to z driver plugs goes out when i trip sw. it dust doesnt do anything
Well I would suggest trying to upgrade to RRF3 which makes defining pins for probes a lot more flexible.
You could try swithing to using the Z probe connector and using mode 5.
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mode_Num_5
my concern is with my limited knowledge i might get lost if i dont make it at lease run
after its running that will be my first task. if that makes sense.. ive noticed several thing that need changes like compensation is commented out and the size specked out for it so... i would like to correct everything before i update....im close... thanks to you... i wanted to make sure were talking about the same thing the first set of pins in the x.y.z stops is where im pluged in... not the z probe... i am assuming when i pick #4 it activates the z stop pins?
n /c switch opens on activation.... -
im trying the z prob connection now
If you really want to use the Z stop, you would want mode 7.
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mode_Num_7, but it's not used in modern firmware, but since you're on a very old firmware it would probably work for you.
would rather use z stop connection i just have a setting off if you ask me
the led is functioning just the way its suposto -
So M558 P7 uses the Z stop endstop in your firmware version.
thanks got that part
so this is what cured my problem for the time being
z probe connector #7 didnt work at first changed to #5 and the z stop registered on the duet interface unfortunately we added the I-1 to m558 which i removed. problem resolved
Thank you... phaerdrux
