    My New Effector Plate
    24
    4.1k
    • Qdeathstarundefined
      Qdeathstar
      Yeah, its like $70 for the trucks and another ~65 for the wheels and hardware. Maybe you got a deal 😄 Looking at them it seems like they make belt tensioning a lot easier and are probably a lot more percise in terms of leveling… but, if i go with those i've got to get the magball arms 😄 SO thats like ~300 total, i could almost get everything i need for a 300mm x 300mm x 300mm core XY machine (using the electronics and steppers i've already got in the rostock)... although, going that route would mean to printer for a while, and you need a printer to make a printer... i'd hate having to wait for 3d printed parts from 3dhubs.
      • kraegarundefined
        kraegar
        Maybe I did pay that, and am in denial. 😄
          Qdeathstar
          Everything that trick laser has sent me has been top-notch. Not saying its not worth the price, just saying its making the decision harder…
          • kraegarundefined
            kraegar
            They cleaned up my delta motion vs. the injection molded carriages. Not sure it was enough to actually see in a print, but it was measurable. I got their arms at the same time, but switched away from the ball cup design to magballs (hoping to sell the arms and get some of the $$ back at MRRF)
            • kraegarundefined
              kraegar
              I updated the gallery, but here's the shot of my layer fans on my new plate.
              • Yonkimanundefined
                Yonkiman
                Wow, that is just beautiful! How well does your Piezo Z-Probe work?
                • Hergonowayundefined
                  Hergonoway
                  Hello, just wow !
                  I currently have a 713maker hotted mount, will it be possible to share your step files ? I've got a laser cutter at my job, I'd like to give it a shot 😄
                  Delta goes BrrrRRRRrrrrrRRRRrrr
                  • patterson6undefined
                    patterson6
                    What is your rod spacing? I would like to incorporate this into my future build. I need the carriage for a mr12 linear rail H block however. I have the 713 ball cup setup now. Switching over to mag arms and mr12 for a big delta build.
                    If the Piezo Z-Probe works great you should get 713 to make something up. Just saying.
                    • kraegarundefined
                      kraegar
                      @Yonkiman:
                      The piezo's working great - I need to contribute some data to the probe repeatability test, but it's been awesome. (I posted my mount for it in the piezo probe thread)
                      • kraegarundefined
                        kraegar
                        @Hergonoway:
                        Hello, just wow !
                        I can share the step files I provided 713maker, but they were awesome enough to trim them down much further than I had - this was based off of a part I printed, so the original revision I sent them was fairly bulky. They kept the spacing for everything, but slimmed it way down.
                        • kraegarundefined
                          kraegar
                          @patterson6:
                          I went with a 50mm spacing. The plate has it built in, and then the adapters work with whatever carriage that has the same mounts as the seemecnc barbells (either the injection molded ones, or the tricklaser ones I'm using now). I have something totally new brewing for a carriage, though. Hope to be able to post it by this time next week!
                          As for the piezo, it works great with the 713maker mount, and a few printed parts. I've put them up here: https://www.thingiverse.com/thing:2268205
                          • Quadcellsundefined
                            Quadcells
                            New to this forum.
                            Been looking for a aluminum effector for my DIY Delta build. I really like the 713maker E3D V6 mount and Effector, but the Effector is not compatible with Haydn Huntley's magnetic arms and balls. Yours looks like it will work great.
                            Is it possible to order one of those effector plates from you or 713maker?
                            /quadcells
