    No Axis Movement
    Firmware installation
    1.6k
      Phaedrux Moderator @1d1
      @1d1 said in No Axis Movement:
      M584 Z4
      • 1d1undefined
        1d1
        Closer yet. All axis moving normally now with Z on E1 (4). But the endstops are still not stopping movement or triggering. Yes, I changed the z end stop to E1.
        Here is M122:
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
        Board ID: 08DGM-956GU-DJMSN-6JTDA-3S46Q-TUQHH
        Used output buffers: 3 of 20 (8 max)
        Static ram: 28380
        Dynamic ram: 95928 of which 16 recycled
        Exception stack ram used: 276
        Never used ram: 6472
        Task NETWORK ready, free stack 324
        Task HEAT blocked, free stack 1256
        Task MAIN running, free stack 3592
        Last reset 00:01:34 ago, cause: software
        Last software reset at 2020-09-15 17:08, reason: User, spinning module GCodes, available RAM 6472 bytes (slot 0)
        Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
        Error status: 0
        Free file entries: 10
        SD card longest block write time: 0.0ms
        MCU temperature: min 32.3, current 32.6, max 32.9
        Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
        Date/time: 2020-09-15 17:09:43
        Slowest loop: 4.79ms; fastest: 0.07ms
        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
        Bed compensation in use: none
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 72.51ms; fastest: 0.01ms
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is running
          WiFi firmware version 1.21
          WiFi MAC address 5c:cf:7f:76:71:a9
          WiFi Vcc 3.29, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 13864
          WiFi IP address 192.168.1.54
          WiFi signal strength -44dBm, reconnections 0, sleep mode modem
          and M98 "config.g"... nothing comes up
        • 1d1undefined
          1d1
          Under machine properties:
          X No -99 mm 99 mm 20 mm/s 300 mm/s 2000 mm/s² 800 mA
          Y No -99 mm 99 mm 20 mm/s 300 mm/s 2000 mm/s² 800 mA
          Z Yes 201 mm 200 mm 20 mm/s 300 mm/s 2000 mm/s² 800 mA
          E0 Yes n/a n/a 10 mm/s 13.33 mm/s 2000 mm/s² 600 mA
          Which can't be right...
            The first thing I would suggest you do is update the firmware.
            Download that zip file, then upload it as is to the /sys folder in DWC. That should prompt it to update everything.
            • 1d1undefined
              1d1
              Done. Nothing lost but nothing gained. Goes up on all axes, hits endstops and then bangs away until I hit Emergency Stop.
              • 1d1undefined
                1d1
                M115: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
                  Alright, when you manually trigger the endstops do they register on the LED light on the Duet board?
                  What kind of endstops are they? Can you post a photo? How are they wired to the board? Does the status change if you send M119 before it's pressed compared to while it's depressed?
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
                    droftarts administrators @1d1
                    @1d1 identify which motor is X, Y and Z (using G1 H2 X/Y/Z moves) then check that each endstop is connected on the correct axis (it sounds like you may have two swapped), and all are triggering. Despite moving Z to driver 4, the endstop should still be plugged into z endstop pins. Check triggering with M117 M119 or the endstop display in DWC.
                      Phaedrux Moderator @droftarts
                      @droftarts said in No Axis Movement:
                      M117
                      M119 😇
                      • 1d1undefined
                        1d1
                        OK. Motors and endstops all correspond to their identified axes and are mounted in their proper spots. Each endstop light on the board is lit and goes off when manually triggered at the switch. The switches are just buttons pushing in and triggering when the carriage hits. Two wires, black and red, so, open or closed. Placing the Z connector back on the Z driver location gives a "no" when not triggered and" yes" when activated. They do not all trigger at once, only individually. They each behave properly when trying the M119 method as well as the machine properties read out in the UI.
                          The Z endstop should still be on the Z endstop connector even though the Z driver is now the E1 driver. RRF2 is pretty rigid about that.
                          At this point it's tempting to just upgrade you to RRF3.0 and then 3.1.1 and get a fresh config from the configurator for a delta and go from there.
                          Upload this zip: https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                          Then upload this zip: https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                          Then get a config set from here and upload the resulting zip file as well: https://configtool.reprapfirmware.org/General
                          • 1d1undefined
                            1d1
                            OK, back again... thanking you again. I downloaded in the order given and all uploads were successful. This is where we are now:
                            G28
                            Error: Failed to enable endstops
                            So we're back to no movement but much closer, I think, as we know that all motors, drivers and endstops function. I still have the z endstop connected at the z position though the z motor is connected at P4.
                            droftartsundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                              @1d1 Check your firmware version with M115, and post response, and please also post your current config.g.
                              For forum ease-of-use, copy the text from DWC and paste it in your reply post. For extra points, format it as 'code', by highlighting the copied text and clicking </> in the formatting bar. Should looks something like:
                              My config.g here!
                              If you do this with all pasted text (eg M122 responses) it makes it MUCH easier to troubleshoot, and will probably make it easier for other forum members to help.
                              • 1d1undefined
                                1d1
                                M115
                                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later ```
                                FIRMWARE_DATE: 2020-05-19b2
                                Q5Delta
                                Send code...
                                Status
                                Idle
                                Mode: FFF
                                Tool Position
                                X
                                0.0
                                Y
                                0.0
                                Z
                                201.00
                                Extruder Drives
                                Drive 0
                                0.0
                                Speeds
                                Requested Speed
                                0 mm/s
                                Top Speed
                                0 mm/s
                                Sensors
                                Vin
                                24.2 V
                                MCU Temperature
                                32.1 C
                                 Tools
                                 Extra
                                 Control All
                                Tool	Heater	Current	Active	Standby
                                Tool 0
                                T0 - Load Filament	n/a	n/a
                                0
                                0
                                Temperature Chart
                                No Data
                                System Directory
                                0:/sys/config.g
                                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 09:55:19 GMT-0400 (Eastern Daylight Time)
                                G90                                            ; send absolute coordinates...
                                M83                                            ; ...but relative extruder moves
                                M550 P"Q5"                                     ; set printer name
                                M665 R104.3 L215 B52 H210                      ; Set delta radius, diagonal rod length, printable radius and homed height
                                M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
                                M552 S1                                        ; enable network
                                M586 P0 S1                                     ; enable HTTP
                                M586 P1 S0                                     ; disable FTP
                                M586 P2 S0                                     ; disable Telnet
                                M569 P0 S1                                     ; physical drive 0 goes forwards
                                M569 P1 S0                                     ; physical drive 1 goes backwards
                                M569 P2 S1                                     ; physical drive 2 goes forwards
                                M569 P3 S1                                     ; physical drive 3 goes forwards
                                M584 X0 Y1 Z2 E3                               ; set drive mapping
                                M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                                M92 X80.00 Y80.00 Z80.00 E663.00               ; set steps per mm
                                M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
                                M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
                                M201 X1000.00 Y1000.00 Z1000.00 E1000.00       ; set accelerations (mm/s^2)
                                M906 X800 Y800 Z800 E600 I30                   ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30                                        ; Set idle timeout
                                M208 Z0 S1                                     ; set minimum Z
                                M574 X2 S1 P"xstop"                            ; configure active-high endstop for high end on X via pin xstop
                                M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
                                M574 Z2 S1 P"zstop"                            ; configure active-high endstop for high end on Z via pin zstop
                                M558 P4 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to switch and the dive height + speeds
                                G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
                                M557 R52 S20                                   ; define mesh grid
                                M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                                M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
                                M140 H0                                        ; map heated bed to heater 0
                                M143 H0 S100                                   ; set temperature limit for heater 0 to 100C
                                M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                                M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                                M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                                M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                                M106 P0 S1 H T45                               ; set fan 0 value. Thermostatic control is turned on
                                M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                                M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                                M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
                                M106 P2 S1 H1 T45                              ; set fan 2 value. Thermostatic control is turned on
                                M563 P0 D0 H1 F0                               ; define tool 0
                                G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                                G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                                Remove a space
                                Z0 ;
                                • 1d1undefined
                                  1d1
                                  Well, that didn't quite work right. I'll try again just get it the way it should be. Learning a lot here....
                                  Q5Delta
                                  Send code...
                                  Status
                                  Idle
                                  Mode: FFF
                                  Tool Position
                                  X
                                  0.0
                                  Y
                                  0.0
                                  Z
                                  201.00
                                  Extruder Drives
                                  Drive 0
                                  0.0
                                  Speeds
                                  Requested Speed
                                  0 mm/s
                                  Top Speed
                                  0 mm/s
                                  Sensors
                                  Vin
                                  24.2 V
                                  MCU Temperature
                                  32.1 C
                                   Tools
                                   Extra
                                   Control All
                                  Tool 0
                                  0
                                  0
                                  Temperature Chart
                                  No Data
                                  System Directory
                                  0:/sys/config.g
                                  Remove a space
                                  Z0 ;
                                  M115
                                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
                                  • Vetiundefined
                                    Veti @1d1
                                    this is not reflected in your config
                                    • 1d1undefined
                                      1d1
                                      Done. Homing moves X and Y - no Z. Here is M122:
                                      Q5
                                      Send code...
                                      Status
                                      Idle
                                      Mode: FFF
                                      Tool Position
                                      X
                                      0.0
                                      Y
                                      0.0
                                      Z
                                      210.00
                                      Extruder Drives
                                      Drive 0
                                      0.0
                                      Speeds
                                      Requested Speed
                                      0 mm/s
                                      Top Speed
                                      0 mm/s
                                      Sensors
                                      Vin
                                      24.2 V
                                      MCU Temperature
                                      32.8 C
                                       Tools
                                       Extra
                                       Control All
                                      Tool 0
                                      T0 - Load Filament	Heater 1
                                      off	20.7 C
                                      0
                                      0
                                      Bed	Heater 0
                                      off	20.9 C
                                      0
                                      0
                                      Temperature Chart
                                      M122
                                      9/16/2020, 11:12:11 AM	M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                                      Used output buffers: 3 of 24 (11 max)
                                      Static ram: 27980
                                      Dynamic ram: 92916 of which 56 recycled
                                      Exception stack ram used: 264
                                      Never used ram: 9856
                                      Tasks: NETWORK(ready,292) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
                                      Owned mutexes: WiFi(NETWORK)
                                      Last reset 00:01:41 ago, cause: software
                                      Last software reset at 2020-09-16 11:10, reason: User, spinning module GCodes, available RAM 9624 bytes (slot 2)
                                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                      Error status: 0
                                      MCU temperature: min 31.2, current 32.7, max 33.0
                                      Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                      Date/time: 2020-09-16 11:12:09
                                      Cache data hit count 168900657
                                      Slowest loop: 2.20ms; fastest: 0.13ms
                                      === Storage ===
                                      SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                                      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                      === MainDDARing ===
                                      === AuxDDARing ===
                                      Segments left: 0
                                      HTTP is idle in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Trigger is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      === Network ===
                                      Slowest loop: 15.75ms; fastest: 0.00ms
                                      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                      - WiFi -
                                      Network state is active
                                      WiFi firmware version 1.23
                                      WiFi Vcc 3.29, reset reason Unknown
                                      WiFi flash size 4194304, free heap 24616
                                      WiFi signal strength -48dBm, reconnections 0, sleep mode modem
                                      9/16/2020, 11:11:59 AM	M115
                                      9/16/2020, 11:10:38 AM	Connection established
                                      9/16/2020, 11:10:36 AM	Connection interrupted, attempting to reconnect...
                                      9/16/2020, 11:10:28 AM	G28
                                      Error: G0/G1: insufficient axes homed
                                      9/16/2020, 11:10:28 AM	Emergency stop, attemping to reconnect...
                                      9/16/2020, 11:10:11 AM	Connection established
                                      9/16/2020, 11:08:50 AM	Connection interrupted, attempting to reconnect...
                                      HTTP request timed out
                                      9/16/2020, 11:08:37 AM	Upload of config.g successful after 1s
                                      9/16/2020, 10:48:26 AM	M115
                                      9/16/2020, 10:06:42 AM	G28
                                      9/16/2020, 10:00:42 AM	G28
                                      9/16/2020, 10:00:05 AM	Connection established
                                      9/16/2020, 10:00:04 AM	Connection interrupted, attempting to reconnect...
                                      9/16/2020, 9:59:44 AM	Upload of config.g successful after 1s
                                      9/16/2020, 9:59:12 AM	G28
                                      9/16/2020, 9:59:02 AM	Connection established
                                      9/16/2020, 9:59:02 AM	Connection interrupted, attempting to reconnect...
                                      9/16/2020, 9:58:49 AM	Upload of config.g successful after 1s
                                      9/16/2020, 9:57:32 AM	G28
                                      9/16/2020, 9:56:58 AM	Connection established
                                      9/16/2020, 9:56:58 AM	Connection interrupted, attempting to reconnect...
                                      9/16/2020, 9:56:18 AM	Upload of config.g successful after 1s
                                      9/16/2020, 9:38:32 AM	Connected to 192.168.1.54
                                      code_text
                                        @1d1 Does your config.g have M584 X0 Y1 Z4 E3 in it now? And you'll need to reset after changing this.
                                        Is your homedelta.g unchanged from the one you posted earlier in the thread?
                                        Please send M98 P"config.g" and post the response (this checks for errors in config.g).
                                        • 1d1undefined
                                          1d1
                                          @droftarts said in [No Axis Movement](/post/179087):
                                          > M584 X0 Y1 Z4 E3
                                          Yes it is
                                          ; homedelta.g
                                          ; called to home all towers on a delta printer
                                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 09:55:20 GMT-0400 (Eastern Daylight Time)
                                          G91                        ; relative positioning
                                          G1 H1 X215 Y215 Z215 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                                          G1 H2 X-5 Y-5 Z-5 F1800    ; go down a few mm
                                          G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
                                          G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
                                          G90                        ; absolute positioning
                                          G1 X0 Y0 F6000             ; move X+Y to the centre
                                          	M98 P"config.g"
                                          HTTP is enabled on port 80
                                          FTP is disabled
                                          TELNET is disabled
                                          Error: Invalid Z probe type 4
                                          Error: Invalid Z probe index
                                          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                                            @1d1 Change
                                            to
                                            M558 P5 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to switch and the dive height + speeds
                                            (Probe type 4 is not supported in RRF3, use either 5 or 8.)
                                            Still not sure why it's not activating the endstops. What EXACTLY happens when you press HOME ALL? If the X and Y motors are moving (the Z may not be, but I think that's possibly a wiring issue), how far do they move? They should move 215mm up towards the endstops. If they don't move that far (which may be why the endstops are not being triggered and you get the error message) it's possible that your steps per mm on XY and Z are incorrect.
