    Temprature sensor error unknown temperature sensor channel
    Firmware installation
    4.7k
    • JTMundefined
      JTM @Veti
      @Veti the first two are updating?
      this is what comes up in the gcode console :
      2:44:19 PMUpdating Firmware...
      2:43:02 PMM997 S0:1
      2:43:01 PMConnection established!
      2:41:56 PMUpdating Firmware...
        A Former User @JTM
        @JTM said in Temprature sensor error unknown temperature sensor channel:
        Thanks so much for the help ! Ive uploaded two updates and the third came up an error? i see on my web interface the gcode console says updating firmware for two updates, taking a long time though is that normal?
        Update should be less than a minute. Reload page and try again; if page doesn't reload connect using USB and issue M997 command to repaet the update.
        JTMundefined 1 Reply Last reply Reply Quote 0
        • JTMundefined
          JTM @A Former User
          @bearer the wifi module has stopped working 😞 i plugged in the USB but cant load up the web interface ?
            A Former User @JTM
            https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s5
            can issue the command over usb serial terminal? if not refer to https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
            JTMundefined 2 Replies Last reply Reply Quote 0
            • JTMundefined
              JTM @A Former User
              @bearer i dont know what ive done but i have connected via usb and using yat i cannot start the wifi as per the instructions on the link. I send the 552 S0 command and get ok, doesnt go into idle?
              • JTMundefined
                JTM @A Former User
                @bearer i get wifi module is being started?
                  A Former User
                  see this post; https://forum.duet3d.com/topic/18354/received-duet2-wifi-with-doa-wifi/6?_=1600236157757
                  if no change, run M997 S1 to reflash the wifi module and repeat?
                  • JTMundefined
                    JTM
                    i ran M997 S1 it reloaded the firmware, i finally have the blue led on for wifi but now i cant load the Duet web interface? the page is blank? my due panel works but i think the homing code has changed as my zprobe doesnt work it goes to manual?
                      Phaedrux Moderator @A Former User
                      @bearer said in Temprature sensor error unknown temperature sensor channel:
                      This will likely do it. Sometimes the wifi firmware doesn't flash automatically. Doing it manually is usually enough to get it going.
                      This happened to me on a recent update and as soon as the wifi was reflashed it acted like nothing happened.
                        When you were doing the initial updates did you upload the zip file as is, or did you extract them and use the M997 S1:0 to flash?
                          A Former User @JTM
                          clear browser cache or visit it in incognite/private window?
                          alternatively remove SD card form Duet and extract https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip to the www folder on the sd card as described here https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_DuetWebControl_files
                            If the web interface wasn't updated along the way with the firmware, you can manually install the DWC files by extracting the DWC zip file into the /www folder on the SD card with your PC.
                            • JTMundefined
                              JTM @Phaedrux
                              @Phaedrux i extracted to documents then uploaded the lot from there?
                                The zip files are meant to be uploaded as is. The DWC handles the extraction and firmware installation. This also ensures you have all the required IAP files and DWC files.
                                When you send M115 what does it say is installed for firmware version?
                                • JTMundefined
                                  JTM @Phaedrux
                                  @Phaedrux version 3 now
                                    Alright, if 3.0 is installed you should try replacing the DWC files with the zip linked above. That may get you back on track.
                                    Once in the web interface, just upload the whole 3.0 zip file as is to the /sys folder in DWC. Then upload the 3.1.1 zip file. Don't extract them first.
                                    • JTMundefined
                                      JTM @Phaedrux
                                      @Phaedrux i cant get in the web interface it is just a blank screen? sorry to be such a pain .
                                        Phaedrux Moderator @Phaedrux
                                        @Phaedrux said in Temprature sensor error unknown temperature sensor channel:
                                        You'll have to do this.
                                        • JTMundefined
                                          JTM @Phaedrux
                                          @Phaedrux im hopeless at this stuff ! i loaded that file onto the sd card and now i get this message from the web face
                                          Your Duet rejected the HTTP request: page not found
                                          Check that the SD card is mounted and has the correct files in its /www folder
                                          • Vetiundefined
                                            Veti @JTM
                                            you have to upack the zip file
                                            the content of the zip file has to be in the folder www on the sd card
