    Temprature sensor error unknown temperature sensor channel
    Firmware installation
    4.7k
    • JTMundefined
      JTM @A Former User
      @bearer i dont know what ive done but i have connected via usb and using yat i cannot start the wifi as per the instructions on the link. I send the 552 S0 command and get ok, doesnt go into idle?
      • JTMundefined
        JTM @A Former User
        @bearer i get wifi module is being started?
          A Former User
          see this post; https://forum.duet3d.com/topic/18354/received-duet2-wifi-with-doa-wifi/6?_=1600236157757
          if no change, run M997 S1 to reflash the wifi module and repeat?
          • JTMundefined
            JTM
            i ran M997 S1 it reloaded the firmware, i finally have the blue led on for wifi but now i cant load the Duet web interface? the page is blank? my due panel works but i think the homing code has changed as my zprobe doesnt work it goes to manual?
              Phaedrux Moderator @A Former User
              @bearer said in Temprature sensor error unknown temperature sensor channel:
              This will likely do it. Sometimes the wifi firmware doesn't flash automatically. Doing it manually is usually enough to get it going.
              This happened to me on a recent update and as soon as the wifi was reflashed it acted like nothing happened.
                When you were doing the initial updates did you upload the zip file as is, or did you extract them and use the M997 S1:0 to flash?
                JTMundefined 1 Reply Last reply Reply Quote 0
                  A Former User @JTM
                  @JTM said in Temprature sensor error unknown temperature sensor channel:
                  clear browser cache or visit it in incognite/private window?
                  alternatively remove SD card form Duet and extract https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip to the www folder on the sd card as described here https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_DuetWebControl_files
                    If the web interface wasn't updated along the way with the firmware, you can manually install the DWC files by extracting the DWC zip file into the /www folder on the SD card with your PC.
                    • JTMundefined
                      JTM @Phaedrux
                      @Phaedrux i extracted to documents then uploaded the lot from there?
                        The zip files are meant to be uploaded as is. The DWC handles the extraction and firmware installation. This also ensures you have all the required IAP files and DWC files.
                        When you send M115 what does it say is installed for firmware version?
                        • JTMundefined
                          JTM @Phaedrux
                          @Phaedrux version 3 now
                            Alright, if 3.0 is installed you should try replacing the DWC files with the zip linked above. That may get you back on track.
                            Once in the web interface, just upload the whole 3.0 zip file as is to the /sys folder in DWC. Then upload the 3.1.1 zip file. Don't extract them first.
                            • JTMundefined
                              JTM @Phaedrux
                              @Phaedrux i cant get in the web interface it is just a blank screen? sorry to be such a pain .
                                Phaedrux Moderator @Phaedrux
                                @Phaedrux said in Temprature sensor error unknown temperature sensor channel:
                                You'll have to do this.
                                • JTMundefined
                                  JTM @Phaedrux
                                  @Phaedrux im hopeless at this stuff ! i loaded that file onto the sd card and now i get this message from the web face
                                  Your Duet rejected the HTTP request: page not found
                                  Check that the SD card is mounted and has the correct files in its /www folder
                                  • Vetiundefined
                                    Veti @JTM
                                    you have to upack the zip file
                                    the content of the zip file has to be in the folder www on the sd card
                                    JTMundefined 2 Replies Last reply Reply Quote 0
                                    • JTMundefined
                                      JTM @Veti
                                      @Veti i extracted those files to the sd card www file? is that right?
                                      • JTMundefined
                                        JTM @Veti
                                        @Veti i switched it on and off and now its working !!!! i have web interface again !
                                        • JTMundefined
                                          JTM
                                          now my zprobe doesnt deploy 😞 on the bright side the temp probe is showing temp, but when i tried to heat the hotend i got an error it was too slow.
                                            Alright you're getting somewhere.
                                            Have you uploaded the 3.0 and 3.1.1 zip files?
