Log temperatures for post analysis
720
    MaracMB
    I am testing a bunch of things and would like to log and further analyse the data on temperatures in Excel
    So how do i log and export temperature readings?
      A Former User
      no built in function i'm affraid; which board and firmware version?
      undefined 1 Reply Last reply 16 Sept 2020, 07:26 Reply Quote 0
        MaracMB @A Former User
        @bearer duet wifi+duex5 on latest fw 3
        I thought there is somesort of debugging/logging function that generates log (m929 ?).
        Would be nice if it just logged temperatures on sensors like every 0.5 or 1 second reading interval.. any extra parameters would be supercool.
        Example #1
        I am inserting a thermistor in a hemera’s heatsink. Just looking at DWC and logging stuff manually is a bad way of doing it. Log would show the gradual increase (or not) throughout a print.
        #2
        Ambient temperature in relation to buildspace temperature throughout a 24 hour print.
        List goes on.
        That would be very helpful stuff
        I don’t have explicit coding skills, but friends do, so is there an API for this? So a separate service would just read and log from DWC?
        ? 1 Reply Last reply 16 Sept 2020, 07:42 Reply Quote 0
          A Former User @MaracMB
          @MaracMB said in Log temperatures for post analysis:
          m929 only logs start/stop of prints, so no good for graphing temps.
          you could use daemon.g with M118 to send a message containing a object model refrence to serial or telnet, and collect the data there; or use M408 from serial or telnet to poll data from the duet - or M409 for a more targeted query of the object model
          M111 enables debug info, not sure of contents and intervals - might affect operation but you could poke it and see what you find?
          you can also query the duet with M408/M409 using HTTP, but in generall it'll be a bit of DIY i think,
          tampermonkey to capture the temp graph from DWC might be an option; there have been a few other threads on the same topic, maybe search to see if I missed someting
            MaracMB
            @bearer thank you. At least i have some options now. I think tampermonkey would be best as it wouldn't load the duet at all. fan tastic 🙂
              A Former User
              btw if you missed this, it might be of interest?
              https://forum.duet3d.com/topic/18688/firmware-package-3-2beta1-released?_=1600243427741
              although the post wasn't clear if it would work with a duet2 running rrf3.2 or just a duet3 in standalone mode - the mention of dsf that runs on the sbc made it a bit confusing.
                MaracMB
                oooook... that confused the hell out of me.
                i'm no expert but i guess this would then need raspberry pi and not sure if this even runs on Duet2... as you said. confusion is building up.
                for a simple guy like me, tampermonkey is best bet.
                ? 1 Reply Last reply 16 Sept 2020, 08:23 Reply Quote 0
                  sleep
                  tell me more about this thing you call sleep?:P
                  anyways, if you could share your work I'm sure others will appreciate it. as mentioned there has been a couple of similar threads recently. godspeed!
                    MaracMB
                    i edited/deleted because i thought you won't get it 🙂
                    i'll call my coding brain friend and will share if anything comes out of this.
                    Thank you for a very constructive debate.
                      MaracMB
                      @bearer @Phaedrux @dc42
                      Sorry for nagging, but could i get a link to an API for this for my programmer?
                      He said he’ll write in python. I guess that’s ok?
                        A Former User
                        try the links in this thread?
                        https://forum.duet3d.com/post/178347
                        undefined 1 Reply Last reply 18 Sept 2020, 10:31 Reply Quote 1
                          @bearer found it. thank you
                          4 out of 12
