    Temprature sensor error unknown temperature sensor channel
    Firmware installation
    4.7k
    • JTMundefined
      JTM @droftarts
      @droftarts its says 0 on the console
      homeall :
      generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 07:34:10 GMT+1000 (Australian Eastern Standard Time)
      G91 ; relative positioning
      G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X15 Y15 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G90 ; absolute positioning
      Home z:
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 07:34:11 GMT+1000 (Australian Eastern Standard Time)
      G1 X15 Y15 F6000 ; go to first probe point
        Phaedrux Moderator @JTM
        @JTM said in Temprature sensor error unknown temperature sensor channel:
        i can move the nozzle to the bed via the controls sure, but i thought it would home to the required printing height each time if set correctly?
        The print height gets set by the slicer.
        The important thing is that after homing you can do a G90 G1 Z0 move and the nozzle touches the bed. If that works, then when you start the print it will go to the right height.
        Maybe show a photo of what you mean with the 14mm if you still think something is wrong.
        JTMundefined 1 Reply Last reply Reply Quote 0
        • JTMundefined
          JTM @Phaedrux
          @Phaedrux said in Temprature sensor error unknown temperature sensor channel:
          G90 G1 Z0
          that did the trick ! so when the print starts it moves to z position 0? i didnt know that. I am trying a print lets see what happens but im finding i have to heat the extruder manually before starting a print. Ill figure it out tommorow 🙂
          • JTMundefined
            JTM
            ![0_1600329782267_E2B2A79B-9311-4AC2-BCFF-1A5728E3112A.jpeg](Uploading 100%) I have started a print almost completed ! There are a couple of bugs to iron out but this board is amazing! So quite ! I have the wrong nozzle for the print as it was a rush to see it working but almost done! Just printing in reverse ! Lol but I’m sure there is an easy fix for it !
            Thanks heaps guys I really appreciate all the help !
            • Vetiundefined
              Veti
              you have to wait a bit after the image upload reaches 100% otherwise the image will no be displayed
              • JTMundefined
                JTM
                ![0_1600330423710_31E7A5BE-1942-488F-8CDB-FE2DC379A516.jpeg](Uploading 100%)
                I’ll try again
                • Vetiundefined
                  Veti @JTM
                  @JTM
                  wait for it to display in the preview window
                  • JTMundefined
                    JTM
                    ![0_1600333403425_BC369645-8C18-4234-9079-591754519CEB.jpeg](Uploading 100%) I don’t think I can load pictures from my mobile?
                      dc42 administrators @JTM
                      There were problems uploading images to the forum from some versions of Chrome. Is Chrome up to date on your smartphone? Or are you using a different browser?
                      • JTMundefined
                        JTM @dc42
                        @dc42 I think so mate, had an update not long ago.
                          Well no when the print starts it will move the first layer height set by the slicer. 0.2 or whatever you have it set to.
                          JTMundefined 2 Replies Last reply Reply Quote 0
                          • JTMundefined
                            JTM @Phaedrux
                            @Phaedrux yes it does move to the correct height for printing. I worked out why the machine was printing in reverse, embarrased to admit but i had the X and Y motors and end stops back to front ! lol
                            I have the machine printing but for some reason it doesn't start the heater automatically, i have to heat the extruder then start a print to get t printing. Not sure what this error is :
                            Error: Temperature reading fault on heater 0: sensor open circuit
                            Resume state saved
                            Printing paused at X0.0 Y0.0 Z0.0
                            I will try my friend google and see what i can come up with, thanks again for all the help guys !
                            • JTMundefined
                              JTM @Phaedrux
                              @Phaedrux i am getting this error when trying to print:
                              Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                              I'm guessing that the extruder temp is set below the temp (260c) i want to print at. how do i change that if that's the case?
                              Thanks in advance
                                What slicer are you using? Does it have the temp set for what you want?
                                You should add T0 to the end of your config.g so that the first tool is selected at startup. You should also add a T0 to your slicer start gcode just in case the tool gets deselected along the way.
                                Can you post a sample sliced gcode file so we can see what it's trying to do at the start of a print?
                                • JTMundefined
                                  JTM @Phaedrux
                                  @Phaedrux Hi mate, i'm using Simplyfy3d so yeah i set my temps for my other machine all through S3D. Im not sure about the sliced gcode, but in the scripts tab the starting script is G28 ; home all axes
                                  Ive also noticed my end script to lift the nozzle 50mm after print finishes doesn't work either?
                                  M104 S0 ; turn off extruder
                                  M140 S0 ; turn off bed
                                  M84 ; disable motors
                                  G91;
                                  G1 Z50;
                                  G92;
                                    G91;
                                    G1 Z50;
                                    G92;
                                    Well it disables the motors and then tries to move them so move the M84 to the end.
                                    • JTMundefined
                                      JTM @Phaedrux
                                      @Phaedrux thanks mate.
                                      i tried adding the T0 line at the end of config and also in start script and still no go.
                                      i get this error message.
                                      Resume state saved
                                      • JTMundefined
                                        JTM @Phaedrux
                                        @Phaedrux could it be in the baude rate? my other printer runs rumba at 115200 baude rate the duet is different?
                                          Are you printing over USB or are you uploading the gcode to the duet using the web interface?
                                          Do the heaters work otherwise?
                                          Have you PID tuned your heaters?
                                          • JTMundefined
                                            JTM @Phaedrux
                                            @Phaedrux uploading the file through web interface.
                                            The heater can be set manually and work fine and i have PID tuned them. I upload a gcode file then click start print and i get this error message,
                                            the printer will continue trying to print without heating the extruder so i just stop it. if i heat the hotend first then start a print it will print as i'm manually overriding the temp settings.
                                            i think?
