    Firmware package 3.2beta1 released
    Beta Firmware
    12
    42
    3.3k
      dc42 administrators @dc42
      I've done some research, and it appears to me that in CNC mode it's normal to let the coordinates go on growing. So when at position A355, instead of sending G1 A1 you would send G1 A357. Eventually the numbers get too big and a reset is needed, typically using G92. Some controllers reset automatically if you switch into relative movement mode using G91.
        dc42 administrators @arhi
        @arhi said in Firmware package 3.2beta1 released:
        @dc42 I know I'm being PITA but I have to and I apologize
        It is impossible to figure out what are the branches of each project required to make a certain build. The BuildInstructions.md is not very up2date. So it would be cool if you could, for e.g. in these forum release posts, add info on what branch of each project goes into this release :). Ideally adding a same TAG as release on each product would be awesome
        BuildInstructions.md was updated a week ago. https://github.com/Duet3D/RepRapFirmware/blob/v3.02-dev/BuildInstructions.md
        All the projects that make up RRF 3.2beta1 are now tagged, except for DuetWiFiSocketServer.
        arhiundefined 1 Reply Last reply Reply Quote 1
        • arhiundefined
          arhi @dc42
          @dc42 awesome!!! I missed the buildinstruction update, was looking at the wrong branch 😞 .. but tags are awesome 🙂 thanks
            Yes, it's a problem that project-wide files such as WhatsNew.md and BuildInstructions.md exist on so many different branches, it makes it hard to find the latest one.
              jay_s_uk @dc42
              @dc42 could the be moved to their own branch? Or maybe to a wiki for the repo so they aren't branch dependant?
                dc42 administrators @jay_s_uk
                @jay_s_uk said in Firmware package 3.2beta1 released:
                Yes, moving them to a wiki would be a good solution I think.
                • arhiundefined
                  arhi @dc42
                  @dc42 Yes, WIKI, either on github or duet3d.dozuki would be awesome ... dunno how many ppl build their own firmware but ..
                    jay_s_uk @arhi
                    @arhi I tried to build it once.... Gave up
                    • arhiundefined
                      arhi @jay_s_uk
                      I built it few times so far, setting up env on mac is super easy 🙂 .. on windows I gave up as it was interfering with my other stuff .. but I had issues with getting proper versions of all sub-projects... anyhow once you get over that it's rather easy 🙂 ... much more important part is actually understanding the code 😄 and making use of ability to compile it 🙂
                      • observatoerundefined
                        observatoer
                        This post is deleted!
                          A Former User
                          This is what i get for a Maestro Board 3.1.1 running -> 3.2beta1 DuetMaestroFirmware.bin
                          • Vetiundefined
                            Veti @A Former User
                            @Nellor
                            this is a topic about 3.2
                            please read the documentaiton. you need to update to 3.0 first.
                              A Former User
                              • Vetiundefined
                                Veti
                                then you should have downloaded https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetMaestroIAP.bin from 3.0
                                  A Former User
                                  As everything worked so far without any problems (considering that I'm a normal end-user)
                                  this should covered somehow different - nevertheless thank you for the friendly hint.
                                  • Vetiundefined
                                    Veti
                                    how did you update to 3.1.1? through bossa?
                                    its written in the release notes for 3.1.1
                                    https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1
                                      A Former User @Veti
                                      @Veti
                                      Search for another person to fight with... this is not my level...
                                      • Vetiundefined
                                        Veti @A Former User
                                        @A-Former-User said in Firmware package 3.2beta1 released:
                                        sorry if i offended you. that was not my intention.
