    oozeBot Elevate
    My Duet controlled machine
    17
    92
    6.7k
    • oozeBotundefined
      oozeBot @theruttmeister
      @theruttmeister said in oozeBot ele^gant:
      @oozeBot
      I'm curious why you chose to go with a belt driven Z axis? Its certainly nice to watch.
      And 400mm/s is nice, but your acceleration is fairly low. Acceleration generally makes a bigger difference to print times than top speed.
      Oh, this was just a test I was doing on an early prototype to validate no steps were lost. You are right, acceleration was not set all that high.. but it sure was fun to watch it go round. 🙂
      Early on, we had multiple iterations that used various combinations of lead screws (2, 3, and 4), but I wasn't satisfied. It wasn't until I realized I could use a bank of relays to create a z-brake that I became confident in the idea of switching the z-axis to use belts. I am extremely pleased with the final results. With the combination of the right steppers, belt tension, and the z-brake, absolutely no drop is experienced when power is cut! Plus it brought the overall cost down considerably..
      Kolbiundefined 1 Reply Last reply Reply Quote 1
      • Kolbiundefined
        Kolbi @oozeBot
        @oozeBot Nice work, looks good!
        I am wondering about z axis. What is the steps per mm / motor resolution? Are there any lifespan / maintenance considerations given the increased complexity for z, with regard to relays, brakes, ...
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @Kolbi
          @Kolbi - first, all steppers we've chosen are LDO's new Class H (rated to 180° c) versions which can easily withstand our enclosure's target temp of 80° c.
          For Z, we chose two LDO-42STH60-2004AH that have a 1.8° step angle coupled to GT2 16 tooth pulleys to increase resolution.
          We will be very mindful to all lifespan / maintenance considerations, but at this time we do not have any concerns. We are using 9mm Gates fiber reinforced belts that are well within their intended use (example: same belts as used on the Shapeoko CNC). The relays only toggle on and off with power, so they should not prematurely wear out - plus we went with a board from Electronic-Salon that's using genuine Panasonic relays instead of some Chinese no-brands.
          Kolbiundefined 1 Reply Last reply Reply Quote 0
          • Kolbiundefined
            Kolbi @oozeBot
            @oozeBot Thanks for the information. What sort of bed leveling will the machine use? At 100 steps/mm on Z would mesh present difficulties?
            • oozeBotundefined
              oozeBot @Kolbi
              @Kolbi - we have not experienced any difficulties, but understand your thinking and we very well may change our minds yet again after more testing.
              I guess I'm old school and firmly believe the best approach, by far, is manually leveling the bed prior to applying any mesh compensation. Our current 9 point manual leveling setup is shown below - the final design will utilize a 3rd extrusion instead of those long supports in the middle. FYI - our build plates will incorporate a Builtak flexplate system on top of the 3.3mm borosilicate glass, and a Keenovo heater underneath. The glass was laid down bare just to show it put together.
              • Kolbiundefined
                Kolbi @oozeBot
                @oozeBot said in oozeBot ele^gant:
                I totally agree that the bed be leveled to the maximum extent possible, and if done well enough to forego mesh comp all together. Maybe I'd be slightly concerned with z-resolution + mesh comp, given a resolution of 10 microns. Not sure if it would be an actual issue or not.
                • oozeBotundefined
                  oozeBot
                  Sneak peek at the front of our prototype encloser.. fresh off the CNC! We’ll be using a 7” PanelDue as the screen.
                  • oozeBotundefined
                    oozeBot
                    Final version (hopefully) of our x-carriage and interchangeable tool heads! Any guesses on what the second tool is for? Just waiting on UPS to get that one finished up..
                      A Former User @oozeBot
                      @oozeBot
                      What machine printed those orange parts ?
                      • oozeBotundefined
                        oozeBot @A Former User
                        @CaLviNx said in oozeBot ele^gant:
                        @oozeBot
                        At this point, everything has been printed on a previously designed machine that is not commercially viable. Hence why we are not talking about it. It's sort of the chicken vs egg argument as something had to create the first prototypes, right?
                        FYI - everything is printed in IC3D's ABS within a heated chamber. We tried several different materials and came back to ABS after finding the right balance of infill, perimeters, etc to give us the rigidity required to pass our QA.
                          @oozeBot
                          What QA standard are you working to ?
                          • oozeBotundefined
                            oozeBot
                            I do not want to mispeak on a public forum, so will have to defer and only state this type information is forthcoming.
                            However, the specific QA test I was referring to when comparing materials were specific to heat (80c) and tension (>2x max belt tension).
                            Parts like this must be very rigid. The part shown was printed in polycarbonate. It worked well but turned out to be unnecessary as we achieved the same results with ABS.
                              A Former User
                              For Quality Assurance I was referring to the international inspection standards.
                              For example the ISO standard or the ANSI standard.
                              The reason I asked is because I teach mechanical inspection engineering and we work to these international inspection standards.
                              I use these standards as a benchmark, we have a 3d printing department that I look after where we use 3d printing as a teaching tool, we encompass design, prototyping, material testing, material science etc, it allows me to get paid to play with my hobby.
                              oozeBotundefined 1 Reply Last reply Reply Quote 1
                              • oozeBotundefined
                                @CaLviNx sounds like you just might be a good person to know as we move forward..! I'm sure we'll have questions.
                                • oozeBotundefined
                                  oozeBot
                                  OptLaser's new PLH3D-6W-uSpot laser head showed up today.. it appears to be extremely high quality. Here it is sitting next to it's tool holder..
                                  We are excited to test this out!
                                  theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                                  • Kolbiundefined
                                    Kolbi
                                    Nice utilization!
                                    • oozeBotundefined
                                      oozeBot
                                      Quick pic of our new mesh bed leveling routine I finally got to test today..printed in ABS on a 30x30cm build plate. Not gonna lie though, I didn’t get a picture after just the first layer. This is after four .25mm layers just so I could peel it off the build plate.
                                      We are pleased so far- next up is to do it again with much thinner layers.
                                      • oozeBotundefined
                                        oozeBot
                                        I'm tuning our latest prototype with a part set for a default printing speed of 4800mm/min. I keep upping acceleration and jerk hunting the "sweet spot" and I think I could still go higher.. My current config is as follows. And before it gets called out, reminder that Z is belt driven and handles these settings just fine..
                                        M566 X1500.00 Y1500.00 Z500.00 E1000.00		; Sets Jerk - maximum instantaneous speed changes (mm/min)
                                        M203 X24000.00 Y24000.00 Z12000.00 E5000.00	; Sets maximum speeds (mm/min)
                                        M201 X6000.00 Y6000.00 Z3000.00 E1200.00	; Sets accelerations (mm/s^2)
                                        Here is a photo of the print in ABS at these settings:
                                        And here is a link to it printing at these speeds for anyone interested: https://www.instagram.com/p/CF4uDdrj5uY/
                                        Any insight on how realistic it is to push these settings further would be appreciated. Just by modifying acceleration and jerk I've been able to reduce this print from 59m to 51m..
                                          T3P3Tony administrators
                                          can you post the video to a service that does not need an account to view it?
                                          • oozeBotundefined
                                            oozeBot @T3P3Tony
                                            @T3P3Tony my bad - I thought I had that worked out where it could be viewed without logging in. Here it is. Note the rattling is the cooling fan jerking around.. lol. I'm going to have to stiffen that part up!
                                            https://vimeo.com/464550220
