True Bed Leveling
i have some problems to configurate the true bed leveling on my ratrig vcore pro.
the positons for the lead screws i set to the balls of the mounts and the leveling points are set as near as possible to the balls.
when i start mesh bed leveling one corner is high. the strange thing is when i rotate the plate the issue is in the same corner. so the plate should be ok. dont know it seems something in my configuration is wrong.
On my printer the height map looked very much like yours.
The problem was that the end of the Y rail was low, as indicated by the high corner of the height map.
I was able to loosen it at the low end and raise it little by little, creating a height map after each adjustment, until the height map was satisfactory.
For "true bed leveling" you need three independant Z-motors.
But, as for your question. If the error is in the same corner you must have an imperfect kinematic system. Meaning your bed may very well be leveled, but your printer is not square.
Also, Have you cancelled all existing compensation before running the probe?
Edit: fcwilt was quicker
Ok. Makes sense for me
Is there any good way to adjust this so accurately as possible?
The frame was assembled with steel square and lineal
@janjoh said in True Bed Leveling:
Where can I find if there is any compensation activ?
He does have three independent Z-Axis Motors
@ErwinH78 said in True Bed Leveling:
I use a couple digital inclinometers zeroed to the build surface one for X and another for Y
ok now i tried to get the left back side of rail a little bit down. i used feeler gauge tape 0,15mm. the highmap didn´t change. no idea whats going wrong
The rise in the height map at the corner indicates that end of the rail is low, so it needs to be raised.
I simply loosened the screws holding the end of the extrusion and moved the extrusion up.
@fcwilt said in True Bed Leveling:
mhmm ok. ok maybe in the wrong direction but this changed nothing in the measurament. the issue is exact the same as before
Well the high part of the height map is up some 0.32mm.
And I see a shim but it does not appear to be at the end of the rail.
It looks like your frame is held together with gussets. It should be easy to loosen the bolts securing the end of the extrusion and shift it. This would insure you have no unevenness in the rail due to shims.
Looking at the pic the rails are inverted, the X/Y carriage hang down underneath?
this being so then the rail/extrusion needs to be lowered not raised, as from the height map that corner is showing the nozzle to be rising up
@CaLviNx said in True Bed Leveling:
Hmm...
I just did a four point height map putting a metal plate along the front edge of the bed ensuring it was placed so that the probe triggered on it at both front corners.
The height map indicated that the front of the bed has higher than the back by the thickness of the plate.
So if "raising" the bed did that wouldn't lowering the front ends of extrusions/rails have the same effect?
Your bed is warped. Auto-leveling isn't going to help here.
In the height map, look at the three points it uses as the true-leveling probe points. They are all near zero. So it's doing its job.
The docs say to have probe points near the leadscrews, but really you can have them anywhere and it'll do the least-squares best fit. I use 4 points at each corner and one point in the center and I think the result looks better than using just 3.
Oh, I didn't see a screw at the third rail. Sooo I assumed two.. and that may very well have been a mistake on my part.
My journeyman always drummed into me, : assume nothing, find out, assumption is the mother of all f**k ups
@TDK said in True Bed Leveling:
Really ? please tell me how can you be 100% of that without physically being there and laying the milled tool plate on a granite surface plate and physically measuring to see if it is warped or not, that's an amazing leap of faith and an assumption at best, I dont do assumptions, i prefer facts myself.
The usual "if it looks like sht, smells like sht, tastes like sh*t" applies, and the fastest thing to check would be if both y axis rails are perpendicular to each other, then and ONLY then start looking down other avenues, K.I.S.S applies. work methodically using a process of elimination to reach the reason for the anomaly, and dont take stabs in the dark without proof.
I would also advise the OP to remember to mentally separate the two features at work here.
We have "auto bed compensation" (G32) which is used to probe close to (in this case THREE) lead screws, that will work out to be a triangular pattern at THREE POINTS ONLY.
This is why you define the locations of the "lead-screws" using
M671: Define positions of Z lead-screws or bed leveling screwsAnd that G32 runs to make sure that all three screws in this case are in sync at the same height, that is true level.
Also remember Level does NOT equate to Flat, it only equates to LEVEL.
AFTER G32 has established a datum and "leveled" the three lead screws you then run (G29) "mesh grid COMPENSATION" THIS IS NOT leveling G32 ALREADY did that.
The purpose of G29 is to ascertain just how FLAT (or NOT) the print surface is.
I have a picture of the exact same bed surface to illustrate.
The top picture is probed above the beds 4 adjusters and looks pretty much level.
The bottom picture is a multiple probe of a defined grid of the same bed immediately AFTER making sure it is level.
I'm going off of this picture by OP:
in which you can see the bed is clearly non-planar. A warped frame or non-planar XY motion could also cause this.
Since bed leveling only adjusts the best fit plane, it's not going to remove the one corner that is warped upward.
You are correct Insofar as there is a rise at that point but from the picture you cannot assert what is causing it. So you cannot use the word warped with any degree of certainty.
Initially you said "Your bed is warped".
You seem to have amended your analysis.
