    Trying to get a FolgerTech FT5, R2 kit dialed in
    1.3k
    • bjacksonundefined
      bjackson
      Some time ago, I bought a FolgerTech FT5 kit. It came with a BigTreeTech SKR 1.3 board as the controller. It did work for a while, but then it failed. I got some replacement boards on the Internet, but they had problems too. I decided I didn't want any more of those boards, so now I'm here, and using a Duet2Ethernet board with a 5" PanelDue.
      It's all connected, and basically working, and pretty much still a stock FT5. I have added a BLTouch probe and a glass plate to print on.
      I have so far only progressed to making some test prints. One of the files makes a little open top cube, and the other file is for the Benchy boat. I have attached photos of the most recent prints made of the cube and the boat.
      The cube is not terrible, but the boat really is pretty bad. In the same room, I have a stock Creality Ender 3 printer that makes much nicer copies of these two objects, so clearly I have some work ahead in order to get this FT5 to do as well as the little Chinese printer. This is the first time I have built a 3D printer from parts, and thus been responsible for getting it all tuned up correctly.
      The most obvious thing wrong with the boat is all the random strands all over the hull, but other aspects of the print look pretty rough to me as well. The cube is better, but I do notice that there seems to be a little build up of height at the corners, giving the top corners little peaks that I don't think should be there.
      Some observations and things tried so far:
      I did a calibration of the esteps for the extruder and confirmed that when I ask for 100 mm of filament, I get 100 mm moved into the extruder. The esteps for the X, Y, & Z motion look fine to me as things move to the expected locations. It appears to me that the BLTouch probe system is working.
      When I watch the boat print, one of the things I see as the nozzle goes around the perimeter while building up the hull is that the existing model seems a little soft, and as the nozzle goes around extruding another layer, it see it actually pushing down on the existing model enough that I can see it flex. In fact, more than once the force applied by the nozzle on the existing partial model was enough to unstick it from the glass plate. That failure is not pictured 🙂
      Because I'm rather new to this, I'm hoping some folks here with more experience (maybe even with converting an FT5 to Duet), can give me some suggestions of things to try. I'm pretty confident that the FT5 should be able to do much better.
      I have also included my config.g file for review. Thanks in advance for any suggestions.
      config.g
      Regards,
      Brian
      • Vetiundefined
        Veti
        B4138 is the default and wrong for your thermistor. so you are printing at the wrong temperature
        bjacksonundefined 1 Reply Last reply Reply Quote 0
        • bjacksonundefined
          bjackson
          I'm not sure how to obtain the correct values to use with the thermistor that I have. All that I really know about it now is that it was included in the FT5-R2 stock kit, and it fits in a 3mm hole in the hot end. I would like to just contact FolgerTech and ask them for information about what I have, but they are not really responsive these days.
          An alternative perhaps is to just buy a new temperature sensor from somebody that knows what they are selling, and could provide additional tech information if needed. For example, I could get at PT1000 sensor from Filastruder that looks like it would fit in the hole (right diameter and length). Perhaps I should get two of them, and replace whatever is in the bed heater area too.
          One thing that has occurred to me is to bring the hot end up to where it reports say 210 Deg C, then aim a non-contact laser equipped thermometer at the hot end and see if it seems close, or is way off. I may try that later today.
          • bjacksonundefined
            bjackson
            I tried using the laser guided optical thermometer on the hot end, but the results gave me zero confidence that I was getting any sort of useful measurement with that tool in this application.
            I then recalled that I had a thermocouple probe and a digital multi-meter with a temperature function made for it (came all together in the multi-meter kit). I was able to put that little thermocouple sensing end into one of the little holes in the hot end block and hold it there for a while.
            The setting in the Duet console was 210 Deg C. The meter was reading about 198-200 Deg C. So, it would seem that the mismatch in my configuration may be causing printing to be at about 10 Deg C lower than intended.
            How critical is the printing temperature with PLA? How far off the right temp might I need to be in order to cause the issues shown in the pictures.
              That definitely looks like overheated printing and maybe some over extrusion as well.
              Optical thermometers aren't ideal to use on small shiny surfaces, so the readings could be quite off.
              10c difference that you saw may be a bit more (you're losing some heat to the thermocouple and it's not inside the nozzle) so it may be more like 15-20c, which may be quite substantial for some pure PLA filaments.
              A PT1000 could be a good option, or even just a E3D thermistor cartridge with known values, provided they will fit in the hotend.
              The exact temperature isn't really required, you can experiment with different temperatures and find one that gives a good enough result and if it says you need 170 then so be it, that's what you use even if the actual temp is 200.
              You may want to go through some calibration steps:
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
              • bjacksonundefined
                bjackson
                @Phaedrux said in Trying to get a FolgerTech FT5, R2 kit dialed in:
                A few thoughts have gone through my mind after reading a few other things here and there. This extruder assembly that was/is "stock" on the FT5 kit is really sort of a bare bones (just enough to get the job done) sort of assembly. There is just one fan involved, and it blows on a heatsink that keeps the upper part of the extruder assembly from being too hot. There is no part cooler fan at all.
                One site showed a similar looking flawed boat hull and mentioned filament droop as the problem caused by insufficient cooling. I'm wondering if I should consider just getting a totally new extruder/hot end assembly that's better engineered. I have spare conductors in the wiring harness so I can easily support having two fans separately controlled. I would just need to find a good product that's not terribly difficult to adapt to the existing FT5 gantry.
                In the meantime, I will start studying that calibration link you provided.
                Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @bjackson
                  @bjackson said in Trying to get a FolgerTech FT5, R2 kit dialed in:
                  Couldn't hurt.
                  I think FT5 stands for Fix That x5
                  A Former User? bjacksonundefined 2 Replies Last reply Reply Quote 0
                    A Former User @Phaedrux
                    Couldn't hurt.
                    How very dare you, dont you know John Folger thinks he can walk on water.......
                    • fcwiltundefined
                      fcwilt @bjackson
                      I designed a new extruder assembly for my FT5.
                      It's simple, allows for different hotends such as a E3Dv6, Mosquito or Dragon and includes part cooling and mounting for a BLTouch v3 or a 12mm Inductive/Capacitive Z probe.
                      However it is based on using a Zesty Nimble and I'm not sure you can get those at this time.
                      • bjacksonundefined
                        bjackson @Veti
                        @Veti
                        Since the thermistors I have came from FolgerTech, and you can't ask them any questions, I searched around looking for any posts where somebody seemed to have authoritatively identified and specified the thermistors that were placed in the R2 kits like I have. I found no such post, but that doesn't mean there isn't one to be found someplace.
                        It occurred to me after reading some articles on calibration that perhaps what I should try to do is make measurements and determine a beta value myself. I do have a thermocouple sensor for one multi-meter, and I have another meter I can use for resistance measurements.
                        I got the hot end plenty hot while I had my thermocouple in there with some thermal grease to help it be more accurate. I then turned off the machine and quickly transferred the thermistor leads to my meter. Now, it was just a matter of taking occasional readings as it cooled down. I even got a reading below ambient room temperature by holding an ice cube against the hot end block when it wasn't going to get any cooler on its own.
                        I used the readings at 28 Deg C and 217 Deg C along with the resistance readings of 86800 ohms and 500 ohms. Plugging that data into the formula resulted in an experimentally calculated beta of 4022.
                        For now, that's what I have in my config.g now. For the moment, I'm going to assume this is also valid for the bed thermistor, but I may test that later.
                          4022
                          I'd venture that the actual value is 3950 as that is a very common value for NTC thermistor.
                          • bjacksonundefined
                            bjackson @Phaedrux
                            ... and maybe some over extrusion as well.
                            I'm thinking that too. I followed that link to the calibration page you suggested. Down near the end was the "Method 1" using the 100 mm x 100 mm very thin walled cube. Experimenting with various settings in DWC of the extrusion factor caused me to settle initially on a value of 77%.
                            That seemed like quite a significant adjustment to be making, but I went ahead and revised the extruder estep value in config.g and printed another Benchy boat. The attached photo shows considerable improvement, that's for sure.
                            It surprised me that my first extruder estep adjustment made by my measuring actual filament distance moved into the extruder when requesting 100 mm of extrusion would be subject to a second adjustment so large.
                            I still think I need to get a better extruder and/or hot end. It doesn't seem to me like the stock extruder grips the filament quite as securely as I would like.better-boat.jpg
                            • bjacksonundefined
                              bjackson @Phaedrux
                              Couldn't hurt.
                              I think I'm ready to improve the extruder assembly on this printer. The stock extruder just has a single toothed drive gear and a spring actuated roller to press the filament against the drive gear. The grip just isn't that good. Sometimes, when I start a print, after the bed probing is done, the gantry goes to the start point, the extruder starts moving, and filament immediately pops out off the top of the extruder.
                              Also, when that does not happen, and the print actually starts, it often seems like the filament is so late in starting to come out of the nozzle that a fraction of the first layer of the actual part might be missing. It seems like I need to have something in the "Start g-code" section of Cura to make the nozzle do an extra lap around the outside of the part before it begins for real. I'm not sure how to do that.
                              I've seen some videos about assembling the parts needed to retrofit something like the E3D extruder and hot end that involve sourcing some milled aluminum parts from 713maker.com. It seems that they are out of stock on their aluminum extruder mounting plates, so I'd need to look elsewhere for the mounting bits.
                              Has anybody here got a suggestion for a source for what's needed? The aluminum parts looked nice, but thingiverse may offer 3D printed parts to do this as well. I will look around.
                              fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • fcwiltundefined
                                fcwilt @bjackson
                                My mount is designed for the 713 parts. I've never had to wait long for them.
                                The issue with my design is that it uses a Zesty Nimble and I don't know if they are shipping.
                                Attached is the version for a Mosquito Hotend and a 12mm Inductive Z-Probe.
                                  That sounds like a form of the MK8 extruder. https://reprap.org/wiki/Extruder_assembly
                                  It's a bit primitive these days but it's cheap and functional. If you used that calibration guide I linked you should be able to find your maximum flow rate and as long as you stay within that limit you should be able to get decent results with it. Upgrading to some form of geared extruder would be worthwhile. Direct drive or bowden.
                                  You can add a nozzle prime line to the start gcode section, or you can use the skirt function (under the bed adhesion heading) which adds a number of loops around the outside of the part on the first layer to ensure there is plastic flowing.
                                  Example of a nozzle prime macro:
                                  ;M98 P"0:/sys/PrimeNozzle.g"
                                  G90 			; Absolute positioning
                                  G1 X1 Y270 F6000 	; Move to front left corner
                                  M400 			; clear movement buffer
                                  M116 			; Wait for temps
                                  G1 Z0.3 F100		; Move Z to prime height
                                  G91 			; Relative positioning
                                  M83 			; Relative extrusion
                                  G1 E5 F300 ; pre-prime nozzle
                                  G1 X40 E10 F300 	; Prime line
                                  G10			; Retract
                                  G1 Y-1 X1 F10000 	; Wipe nozzle
                                  M400
                                  • bjacksonundefined
                                    bjackson
                                    Yes, the pictures in your link are almost a perfect match for what FolgerTech included in my kit.
                                    You can add a nozzle prime line to the start gcode section, or you can use the skirt function.
                                    I worked a bit with both of those suggestions. I tried putting the g-code commands in the section to be applied before each print, but it didn't work as expected. The nozzle came over the the front right, seemed to try and extrude a little (nothing came out), then it traveled over to the front left, and extruded a big doughnut of PLA that just surrounded the nozzle since it wasn't moving. Rather than troubleshoot that immediately, I moved on to your second suggestion.
                                    I had been slicing using something called the "Cura Engine" accessible to be through Repetier. That slicer has no "skirt" function. It has brim and raft, but not skirt. I then looked at Cura 4.7. That of course had the skirt function plus a hugh bunch of new confusing things 🙂 I sliced the 20 mm calibration cube and sent it to the printer. The results were not good.
                                    I had a bad first layer really, some of the corners start to lift off, and there was a persistent corruption of one of the sides of the cube near one of the corners, pretty much all the way up. Photo attached; not sure what happened, and it was repeatable.cura47.jpg
                                    I also have Slic3r accessible through Repetier, and I just downloaded their latest version as well. Of all the slicers I've fooled with so far, the interface on Slic3r is my favorite. It made a good calibration cube, and it had a very functional and easy to configure skirt function.
                                    As for the remark I made in another post about the filament springing out when I would start another job, I have partially tracked that down. The extruder motor was definitely going in reverse after a print finished, and it felt like it was running quite a while (probably would have ejected 100 mm if there had been that much to retract). I have not located the g-code yet that was doing that. When I printed the cube sliced by Slic3r, the extruder did not do that at the end of the print.
                                      You may want to try Prusa Slicer as well.
                                      • bjacksonundefined
                                        bjackson
                                        Yes, that is on my list as well.
                                        Since I am getting some of the "Extruder Issues" somewhat resolved and understood, I may move forward for a while with this MK8 configuration since it does work. I think the priority right now is to arrange for a "part cooler" fan system.
                                        BTW, I was talking with a friend today about his 3D printing adventures. He has a Creality CR10, and he made some remarks about wanting to upgrade his mainboard at some point. I gave him a glowing review of the Duet3D line.
                                        I came here because of all the miserable issues I had with compiling Marlin. I could not get it to work; compiles always failed, and the error messages were really aimed at somebody who was a full blown coder (which I am not).
                                        I am also planning to get clear acrylic panels laser cut so I can enclose the FT-5. The fact it's already a nice box framed with extrusions, and nothing major tries to "poke out" of the rectangular solid shape it is, makes it an easy device to put walls on. I'm sure many here have enclosed their printers in various creative ways 🙂
                                        • bjacksonundefined
                                          bjackson @Phaedrux
                                          I think you are right. Now that I know that things that look exactly like my hot end appear as kits on Amazon searchable as MK8, some of those mention as the thermistor description "NTC 3950 100K Thermistor".
                                          I'm wondering if the bed thermistor that FolgerTech put in my kit is likely to be the same or not.
                                          BTW, I did do the tests to determine the maximum extrusion rate at 210 Deg C, and I came up with a volumetric limit of 8 cu-mm/sec, and thus a max printing speed for 0.2 mm layer height and 0.4 mm layer width of 100 mm/sec.
                                            Quite likely. You can get NTC 3950 100K Thermistors in bags of 10000, so if they use it for one, chances are they use it for all. Since displayed temp accuracy isn't critical for 3d printers it's a suitable thermistor, but you'll need to PID tune and then do some experimenting to find the best set temps.
                                            That sounds reasonable. Now that you know the limit of the hotend, the limit of the motion system for best quality will likely be below that unless ringing and other visual defects aren't important.
