    DWC only shows "retract" after reaching temps...
    Duet Web Control
    584
    • beachtecundefined
      beachtec @Phaedrux
      @Phaedrux
      Hi 🙂 Any thoughts? New territory for me! Hahaha
        Can you check the DWC version? Should be under the settings tab. Should be 3.1.1.
        beachtecundefined 1 Reply Last reply Reply Quote 0
        • beachtecundefined
          beachtec @Phaedrux
          @Phaedrux That is correct. It is 3.1.1, which I believe is the most current. I went back and reinstalled EVERYTHING and re-flashed the Duet and tool boards with the current release as well.
            Phaedrux Moderator @beachtec
            @beachtec said in DWC only shows "retract" after reaching temps...:
            M906 X1600 Y1600 Z1600:1600:1600
            There should be only 1 current value listed for the Z axis here.
            Can you send M584, M350, M92, and M906 in the console and report the results?
            M204 P1000 T2000 R5000
            R isn't a valid parameter for M204 in RRF.
            M584 E20.0:21.0
            Are these mappings correct?
            • beachtecundefined
              beachtec @Phaedrux
              @Phaedrux Sorry about the R parameter... not sure about that one, but removed it anyway with no effect. The mappings are correct. The tool boards appear to be functioning correctly.
                We're looking into it.
                The R parameter would just be ignored anyway, so no big deal there really.
                Can you send M584, M350, M92, and M906 in the console and report the results? Jut in case they are getting modified or not applied.
                  Are you using M302 anywhere?
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
                  • beachtecundefined
                    beachtec @Phaedrux
                    @Phaedrux Hey @Phaedrux ... Not using cold extrude commands.
                    • beachtecundefined
                      beachtec @Phaedrux
                      Entered all the commands you noted above on the command line. All accepted without issue. DWC only offers retract as a selection here.
                      Ugh!!!
                        Your temperature only shows as 100. The default minimum extrusion temp is 160.
                        From the link above:
                        The minimum temperatures for extrusion can be set using the Snnn parameter with a default value of 160°C if unset. A minimum retraction temperature can be set with the Rnnn parameter. The default for this is 90°C.
                        • beachtecundefined
                          beachtec @Phaedrux
                          This post is deleted!
