Changing Temps on Panel Due
1.3k
    pogo1213
    First off Firmware
    Duet WiFi- 1.18.1
    Panel Due-1.16
    Every time I attempt to adjust the hotend temp on to load a filament it doesn't change. I click on the active or standby temp on the panel due and it gives the option to adjust up or down by +-1 +-5 +-10 and when I do so it says to desired temp for one second and switches back to 0. There has to be a way to fix this or a different way of doing it. I dont want to have to use the web interface for this when I have a 7inch touch screen.
    Controlling extrusion/retraction, fans, prints and movement all work the only thing that seems to not work properly is the temps.
    If you can help out I would appreciate it.
    Thanks
      Dougal1957
      It work perfectly for me you do however have to have the tool Active first AFAICR
        pogo1213
        When my tool is active and I set a temp with the web interface and try to adjust it with the panel the temp just jumps back to wat was set in the web interface
          Dougal1957
          What temp are you trying to set on the Panel?
          Know it sounds daft asking that but I have a reason a trap I have fallen for myself?
            pogo1213
            I was trying to set the hotend temp but every time I adjusted the temp and hit set, the number would change back to what it was previously set at
              Dougal1957
              yes but what value was you setting???
                pogo1213
                I have tried both standby and active values both with the same conclusion. If you are asking for a number I tried it today by setting the active from 0 to 240 to load filament but it would bounce back to 0 once I pressed set.
                  Dougal1957
                  That is very strange the only time I ever had anything like that happen was when I was trying to set a value above the default limit hence why I asked for a number the limit by Default is I believe 262 degrees.
                    pogo1213
                    Thanks for your input, my next three duet wifis and panels should be in tomorrow I'll see if they also act up
                      It sounds as though the commands to set the temperature that PanelDue sends are not being received by the Duet. Do other commands work, e.g.homing and movement?
                        pogo1213
                        Homing and moving commands work properly. Temps and gcode console don't work both changes revert instantly once entered
                          pogo1213
                          I have solved the problem, thank you both for the incite. You guys gave me the drive to look further into it and found my mistake.
                            Dougal1957
                            And what was the mistake just so anyone else that has the same issue will hopefully find this thread and be able to check if they have done the same?
                              jrlederer
                              Yes, please do tell, as it turns out I have been experiencing this behavior for some time now but just side step it by calling up the web control via an iPad I've always got right next to the machine. It'd be great to hear how you resolved this.
                              Thanks, in advance,
                              Jonathan
                              "Insanity is doing the same thing over again, yet expecting different results..." --Albert Einstein
                              6 out of 14
