Dual Extruder setup BLV-printer with 2-1 Mellow Mosquito hotend
@knutselsmurf said in Dual Extruder setup BLV-printer with 2-1 Mellow Mosquito hotend:
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0tempThe thermistor seetings are wrong. B4138 is the default. I dont know the correct values for that specific hotend.
for the tool selection
do you have the T0 and T1 in there? -
I just found out that this hotend can't mix 2 different filaments (I use PETG, different colors).
When printing with extruder1, first thing to do is retract extruder2 for about 100mm. And visa versa. If no retraction: it's not possible to load the filament.So, I need some TOOL CHANGE GCODE:
- retract 100 mm of current extruder
- switch tool
- load and purge
- continue
No idea how I must do that in CURA
Any help would be great!
Not sure why you think that the hotend settings are wrong, I have done PID tuning for bed and hotend, seems ok..
using an incorrect setting for the thermistor will result in the displayed temperature and the real temperature to be different. high temperature hotends especially.
I have this thermistor: https://nl.aliexpress.com/item/4000100545980.html
that thermistor does not fit in the mellow mosquito
are you getting heater cartridge and thermistor mixed up?
But you are right about the thermistor settings, didn't now
Hotend NTC 3950 Thermistor Specs:
Resistor below 25C: 100 K
Beta value: 3950 K -
it fits, no probem.
well no. that hotend required a thermistor catridge. without it its not making good enough contact.
this is the type of thermistor you require for this hotend.
https://de.aliexpress.com/item/4000591370691.html -
I am using this heated bed:
35X35X0.3 cm Creality 3D HeatbedDon't have the resistor and beta value yet..
look at the generated g code.
is there a T0 or a T1 before the first extrusion command? -
@Veti I have ordered the Mellow thermistor now. But the current thermistor seems to be ok, stable temperature... And I have a nice filament flow.. I will replace it as soon as I got the correct one
Ok, I will do a new hotend PID tuning..
"look at the generated g code.
is there a T0 or a T1 before the first extrusion command?"Yes
@knutselsmurf oh, shit: I have the right heater and thermistor already
https://nl.aliexpress.com/item/4001294136528.html (set 2, 24V)Will replaced it..
Why do you have G21 in your slicer start g-code ?
the semitec values are B4725 C7.06e-8
