    IR Sensor LED Doesn't Flash
    IR Height Sensor
    • alielsayidundefined
      alielsayid
      I purchased 4 IR sensor boards from Ali express.com, I connected the sensor board to duet wifi to probe a glass bed. The LED on the sensor board does not flash when I apply power to duet board. I checked the connection many times and they are ok. The sensor is showing a reading between 320-330 on the Duet Web Control, and the reading doesn't change when the sensor gets closer to the bed. I tried all 4 sensor boards, all of them have the same behavior.
      Any idea what is the issue?
        droftarts administrators @alielsayid
        @alielsayid as you have bought a clone IR board, it’s hard to say. See this thread: https://forum.duet3d.com/topic/18874/ir-prome-not-working/
        Could be it needs 5V input, not 3.3V (which is the voltage of the probe pin), if it says 5V on the PCB, not VCC. If you have a link for your purchase, post that, or pictures of both sides of the board.
          alielsayid
          Thanks for your reply.
          I tried connecting to 5v, still same problem, no flashing on start.
          Since it's a clone, now I believe it's faulty.
