z axes moves wrong way while printing?
New to reprap firmware. My problem is that the z axis moves correctly from machine control. but when I try to start a print after the first layer it decreases the clearance of the nozzle instead of increasing. here is my config file. Any help will be greatly appreciated.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Sep 10 2020 18:09:59 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes forwards
M92 X200.00 Y200.00 Z400.00 E400.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z3.6 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z2000.00 E6000.00 ; set maximum speeds (mm/min)
M201 X2000.00 Y2000.00 Z100.00 E2000.00 ; set accelerations (mm/s^2)
M208 X316 Y300 Z350 S0 ; set axis maxima; Endstops
M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M558 P5 C"!^zprobe.in" H5 F120 T12000 ; set Z probe type to switch and the dive height + speeds
G31 P100 X25 Y75 Z1.07 ; set Z probe trigger value, offset and trigger height
M557 X20:285 Y20:265 S20 ; define mesh grid; Heaters
;TO DO use the following guide to PID tune the bed heater as every build will have different values
;https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
;M307 H0 A191.5 C435.9 D4.3 V0 B0 ; disable bang-bang mode for bed heater and set PID autotune PWM values
; Extruder Heater
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as Hemera thermistor on pin e0temp
;TO DO use the following guide to PID tune the hotend as every build will have different values
;M307 H1 A566.5 C268.7 D4.5 V24.3 B0 ; disable bang-bang mode for heater and set PID autotune PWM values; Fans
;Part cooling fan
M950 F0 C"fan0" Q200 ; create fan 0 on pin fan0 and set its frequency
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off;Hotend fan
M950 F1 C"fan1" Q200 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 L120 X255 H1 T60:140 ; set fan 1 value. Thermostatic control is turned on. Min speed of 120 as 60 deg, and max speed for 190 at 140+degrees
;!!!Set X255 for full speed hotend fan, if you have heat creep issues; Tools
G10 P0 X0 Y0 Z2.66 ; set tool 0 axis offsets
M501 ; load saved parameters from non-volatile memory -
Are you sure the Z axis is moving the correct direction when jogging? Does Z0 = the nozzle touching the bed and Z+ move the nozzle and bed farther apart?
Can you post your homeall and homez files?
Can you post your slicer start gcode section?
Thanks for the quick reply. here are the files.
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 16:00:20 GMT-0400 (Eastern Daylight Time)
G91 ; relative positioning
G1 H1 X-315 Y-315 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-315 ; home X axis
G1 H1 Y-315 ; home Y axis
G1 H1 X-315 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-315 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X150 Y150 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X0 Y5 F6000 ; go to first probe point
;G90 ; absolute positioning -
@carlkelly176 can you do these tests as well:
