[3.1.1] Issue Parsing Layer Change
Tried that, but it still doesn't seem to be working:
It always seems to know the correct total layer count. It always seems to start at "layer 2". There seems to be an arbitrary time associated with this starting layer.
Have you tried migrating to using start.g and stop.g yet?
@Phaedrux said in [3.1.1] Issue Parsing Layer Change:
Not yet. But with this version RRF and DWC it was working fine in the past. I'm not sure if some subtle tweak to the start gcode broke it, or what.
It would be awesome if a dev could run through debug with the gcode I posted. Maybe it is getting tripped up on something we haven't noticed.
The only thing I can think of that I changed, is putting a larger SD card in. But, I am unsure if it was before/after layer parsing broke,.
@CCS86 said in [3.1.1] Issue Parsing Layer Change:
I put ;E comments on every line in my start gcode with a Z move, and even tried running code from Superslicer. The result is the same.
Can you show your current start and end gcode?
;//////// START GCODE \\\\\\\\ G90 ; abs pos M82 ; abs ext M106 S0 ; fan off M104 S170 ; Set hotend M140 R33 ; Set bed G28 ; Home M109 S170 ; Wait for hotend M190 R33 ; Wait for bed G4 S10 ; Pause M557 X12:201 Y34:151 P12:9 G29 S0 ; Probe bed mesh M376 H3 ; Mesh taper G1 Z60.0 F5000 ; E G92 E0 ; Zero extruder G1 X20 Y20 E-4 F4000 M109 S210 ; Wait for hotend G1 X10 Y0 Z.3 F2000 ;E G1 E0 F2000 G1 X50 E5 F1200 G1 X140 E11 F1200 G1 Y2 Z.1 F9000 ;E G4 S2 G1 Y3 F9000 G1 X20 Z.07 F9000 ;E G1 Z5 ;E G92 E-.7 ; Comp for ooze ;///////////////\\\\\\\\\\\\\\
;////// END GCODE \\\\\\ M400 ;wait for clear buffer G91 ;relative positioning M83 ;relative extruder G1 Z5 E-3 F4000 G28 XY G1 E3 F1500 M106 S128 M104 S0 ;extruder heater off M140 S0 ;heated bed heater off M18 ;steppers off G4 S120 M106 S0 ;////////////\\\\\\\\\\\\
I tried offloading stuff with Z calls to NozzlePrime.g, behavior is still the same. I noticed that it shows the current layer as 0 until just after the probing sequence, where it jumps quickly to layer 1, then layer 2, where it stays stuck for the rest of the print. Is it possible that something inside the G29 command is breaking this?
Here is what a new piece of gcode looks like:
; generated by SuperSlicer 2.2.53 on 2020-10-03 at 20:25:26 UTC ; ; external perimeters extrusion width = 0.40mm ; perimeters extrusion width = 0.40mm ; infill extrusion width = 0.40mm ; solid infill extrusion width = 0.40mm ; top infill extrusion width = 0.40mm ; support material extrusion width = 0.40mm ; first layer extrusion width = 0.40mm ; object:{"name":"Hero 9 Lens Cap","id":"Hero 9 Lens Cap.stl id:0 copy 0","object_center":[32.949028,122.885129,0.000000],"boundingbox_center":[32.949028,122.885129,3.925000],"boundingbox_size":[33.549999,33.549999,7.850000]} M107 ;//////// START GCODE \\\\\\\\ G90 ; abs pos M82 ; abs ext M106 S0 ; fan off M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M290 R0 S0 ; clear babystepping M104 S170 ; Set hotend G28 ; Home M140 R35 ; Set bed M109 S170 ; Wait for hotend M190 R35 ; Wait for bed G4 S10 ; Pause ; Replaced marker: M557 TBD ; parameters will be set automatically M557 X12:63 Y92:153 P4:5 ; End marker ;M557 X20:190 Y10:180 S15 ; Define mesh grid G29 S0 ; Probe bed mesh ;G29 S1 P"mesh.csv" M376 H3 ; Mesh taper G92 E0 ; Zero extruder G1 Z60.0 E0 F5000 G1 X20 Y20 E-4 F4000 M109 S215 ; Wait for hotend M98 P"0:/sys/PrimeNozzle.g" ;///////////////\\\\\\\\\\\\\\ G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ; Automesh: begin layer 0 G1 Z0.250000 F10200.000 G1 E-2.50000 F2400.00000 G1 Z0.950000 F10200.000 G1 X21.559 Y103.095 G1 Z0.250000 G1 E0.00000 F2400.00000 G1 F1800.000 M204 S1600 G1 X23.618 Y102.888 E0.02789 G1 X42.248 Y102.887 E0.27900 G1 X43.816 Y103.005 E0.30019 G1 X45.811 Y103.499 E0.32789 G1 X47.258 Y104.136 E0.34919 G1 X48.911 Y105.219 E0.37584 G1 X50.066 Y106.285 E0.39702 G1 X51.051 Y107.510 E0.41820 ... G1 X15.283 Y106.923 E1.80679 G1 X15.842 Y106.275 E1.81832 G1 X16.811 Y105.362 E1.83626 G1 X17.501 Y104.833 E1.84798 G1 X18.633 Y104.140 E1.86586 G1 X19.408 Y103.766 E1.87746 G1 X20.669 Y103.313 E1.89553 G1 X21.501 Y103.110 E1.90707 M204 S2500 G1 X21.583 Y103.446 F10200.000 G1 F1800.000 M204 S1600 G1 X23.625 Y103.234 E1.93474 G1 X42.248 Y103.234 E2.18575 G1 X43.761 Y103.347 E2.20620 G1 X45.701 Y103.828 E2.23314 G1 X47.091 Y104.439 E2.25361 G1 X48.705 Y105.498 E2.27962 ... ; stop printing object Hero 9 Lens Cap.stl id:0 copy 0 M106 S127.5 ; Automesh: begin layer 1 M204 S2500 G1 Z0.400000 F10200.000 G92 E0 G1 E-2.50000 F2400.00000 G1 Z0.600000 F10200.000 G1 X13.793 Y136.284 G1 Z0.400000 G1 E0.00000 F2400.00000 G1 F2700.000 G1 X13.568 Y135.759 E0.00490 G1 X13.197 Y134.457 E0.01654 G1 X13.038 Y133.526 E0.02464 G1 X12.951 Y132.193 E0.03611 G1 X12.974 Y112.892 E0.20187 G1 X13.171 Y111.435 E0.21450 ...
And again, this file, like every file simulates perfectly fine. I wish @chrishamm or @dc42 could help us out here. The fact that simulation senses layers without issue should be a solid diagnostic clue.
On my list to look at in 3.2beta.
I did some more diagnostics and narrowed it down to a very unlikely culprit. The line:
Is what causes the layer counter to jump from 0 / 49 to 2 / 49, where it stays. I put 6 second dwells between each line of code in that area, to act like single block mode.
Any ideas how that line could possibly be involved?
Are you sure it's that one and not the Z60 before it?
G1 Z60.0 E0 F5000
G1 X20 Y20 E-4 F4000 -
G1 Z60.0 E0 F5000
G1 X20 Y20 E-4 F4000I had a 6 second dwell after the "G1 Z60.0 E0 F5000" line as well. It executed that lift and sat for 6 seconds with layer 0 / 49 still registering. It jumped to 1 /49 then 2 / 49 almost immediately after beginning the G1 X20 Y20 E-4 F4000 line.
Well, I kept hacking at this problem. Since it didn't like:
I broke it up into the XY and then the E move, like this:
M557 X12:65 Y88:148 P5:5 G29 S0 ; Probe bed mesh M376 H3 ; Mesh taper G92 E0 ; Zero extruder G1 Z60.0 E0 F5000 G4 S2 G4 S2 G4 S2 G1 X20 Y20 F4000 G4 S2 G4 S2 G4 S2 G1 E-4 F1800
That change alone caused the layer counter to stay at 0/49 through the whole probing and prime sequence. Jumping to 1/49 only once the the print began, and continuing to count layers correctly for the rest of the print.
I'm shocked, but hopefully that gives you guys some good info to hunt this bug.
Thanks for pinning it down. I think I see what is happening. RRF detects layer changes by looking for movement involving both XY and E while at a height that is greater than the previous such height. So it's the combination of the G1 Z60 move and the following G1 X20 Y20 E-4 move that causes RRF to think there has been a layer change, and the new layer is at Z=60.
I can fix this particular case by requiring the extrusion to be positive, so that the G1 X20 Y20 E-4 move won't count. I will make that change in RRF 3.2beta2 which we expect to release on Monday or Tuesday.
Sweet, teamwork!
