    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.7k
    • arhiundefined
      arhi
      got the 7yo to help me solder this, one handed soldering is a ^#^#%*)^#@ .. anyhow another issue, the excess pcb I left to not have sbc connector right on the edge (kill me why) is a problem with a heatsink .. not a huge issue but something to be aware ..
      good thing is with these long headers I can easily attach probes to sniff signals if required 🙂
      • arhiundefined
        arhi
        so far, not working
        RepRapFirmware for Duet 2 + SBC Version 3.2-beta2 dated 2020-10-05b2
        Executing config.g... Error: Networking is not supported on this hardware
        Warning: Sensor numb
        Clearly I need to remove networking stuff from the config but I doubt that's a too big of a deal, dunno if I need to add something for the SBC ?
        Oct 05 20:34:35 raspberrypi systemd[1]: Started Duet Control Server.
        Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Duet Control Server v3.2.0-beta2
        Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Written by Christian Hammacher for Duet3D
        Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Licensed under the terms of the GNU Public License Version 3
        Oct 05 20:34:37 raspberrypi DuetControlServer[782]: [info] Settings loaded
        Oct 05 20:34:37 raspberrypi DuetControlServer[782]: [info] Environment initialized
        Oct 05 20:34:38 raspberrypi DuetControlServer[782]: [fatal] Could not connect to Duet (Board is not available (no header))
        Oct 05 20:34:38 raspberrypi systemd[1]: duetcontrolserver.service: Succeeded.
        Oct 05 20:34:43 raspberrypi systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
        Oct 05 20:34:43 raspberrypi systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 7.
        Oct 05 20:34:43 raspberrypi systemd[1]: Stopped Duet Control Server.
        I didn't edit any config, only thing I did is increase SPI buffer to 8k on the pi
        will hook up the scope in a bit
        • arhiundefined
          arhi @arhi
          M122 "DSF"
          RepRapFirmware for Duet 2 + SBC version 3.2-beta2 running on Duet 2 1.02 or later + SBC (standalone mode)
          Board ID: 08DJM-9178L-L4MSN-6J9F0-3S46J-KT16P
          Used output buffers: 1 of 24 (10 max)
          Static ram: 23252
          Dynamic ram: 78280 of which 4920 recycled
          Exception stack ram used: 256
          Never used ram: 24364
          Tasks: HEAT(blocked,365) MAIN(running,427) IDLE(ready,19)
          Owned mutexes: USB(MAIN)
          Last reset 00:09:17 ago, cause: software
          Last software reset time unknown, reason: User, GCodes spinning, available RAM 22932, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
          Error status: 0x00
          MCU temperature: min 31.3, current 31.7, max 32.2
          Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: position 0, ok, SG min/max not available
          Driver 1: position 0, ok, SG min/max not available
          Driver 2: position 0, ok, SG min/max not available
          Driver 3: position 0, ok, SG min/max not available
          Driver 4: position 0, ok, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Cache data hit count 946232882
          Slowest loop: 5.29ms; fastest: 0.11ms
          === Storage ===
          Free file entries: 10
          SD card 0 detected, interface speed: 12.0MBytes/sec
          SD card longest read time 0.8ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is ready with "M122 "DSF"" in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          ok
            A Former User @arhi
            @arhi said in Duet 2 Ethernet and SBC:
            try without the sd card or config.g on the card?
            arhiundefined 1 Reply Last reply Reply Quote 2
            • arhiundefined
              arhi @A Former User
              @bearer said in Duet 2 Ethernet and SBC:
              that did it 🙂
              Connection to Linux established!
              Executing config.g... Done!
              RepRapFirmware for Duet 2 + SBC is up and running.
              Oct 05 20:58:02 raspberrypi systemd[1]: Started Duet Control Server.
              Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Duet Control Server v3.2.0-beta2
              Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Written by Christian Hammacher for Duet3D
              Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Licensed under the terms of the GNU Public License Version 3
              Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Settings loaded
              Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Environment initialized
              Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Connection to Duet established
              Oct 05 20:58:05 raspberrypi DuetControlServer[698]: [info] IPC socket created at /var/run/dsf/dcs.sock
              Oct 05 20:58:05 raspberrypi DuetControlServer[698]: [info] Starting macro file config.g on channel Trigger
              Oct 05 20:58:06 raspberrypi DuetControlServer[698]: [error] M550: Machine name must consist of the same letters and digits as configured by the Linux hostname
              Oct 05 20:58:06 raspberrypi DuetControlServer[698]: [info] Finished macro file config.g
              where is the "filesystem" now for the duet on the sbc?
              any script to "test the communication" ?
              M122 "DSF"
              RepRapFirmware for Duet 2 + SBC version 3.2-beta2 running on Duet 2 1.02 or later + SBC (SBC mode)
              Used output buffers: 1 of 24 (11 max)
              Static ram: 23252
              Dynamic ram: 99132 of which 20 recycled
              Exception stack ram used: 292
              Never used ram: 8376
              Tasks: Linux(ready,71) HEAT(blocked,370) MAIN(running,399) IDLE(ready,19)
              Last reset 00:03:10 ago, cause: software
              Last software reset time unknown, reason: User, GCodes spinning, available RAM 24332, slot 1
              Error status: 0x00
              MCU temperature: min 41.4, current 41.9, max 42.2
              Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
              Date/time: 2020-10-05 21:00:22
              Cache data hit count 430062158
              Slowest loop: 135.58ms; fastest: 0.10ms
              === Storage ===
              SD card 0 not detected, interface speed: 30.0MBytes/sec
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              === SBC interface ===
              State: 0, failed transfers: 0
              Last transfer: 20ms ago
              RX/TX seq numbers: 4497/4498
              SPI underruns 0, overruns 0
              Number of disconnects: 0
              Buffer RX/TX: 0/0-0
              ok
                A Former User
                /opt/dsf/sd/ and f.ex. /opt/dsf/sd/sys/config.g
                arhiundefined 1 Reply Last reply Reply Quote 1
                • arhiundefined
                  arhi @A Former User
                  This post is deleted!
                  • arhiundefined
                    arhi
                    missed the second part of the https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3 page 😄 sorry .. everything works 😄 ... so must boot duet2 without sd card to work with sbc - great
                      A Former User @arhi
                      or remove/rename sys/config.g - sd card in itself isn't a problem, but valid config file is.
                      • arhiundefined
                        arhi @A Former User
                        @bearer yes, but in that case better remove the card completely 🙂
                        is the "simulate job" doing some spi communication here talking between sbc and duet or is executed on the sbc only? I connected everything on my spare duet that's not in any of the printers so simulation is the best I can do (running one 50MB file right now)
                          A Former User @arhi
                          could you get away with using a regular right angle connector and solder it smd style to pads on the top and bottom of the board?
                          • arhiundefined
                            arhi
                            started simulation (2%)
                            M122
                            Static ram: 23252
                            Dynamic ram: 100992 of which 40 recycled
                            Never used ram: 6496
                            Tasks: Linux(ready,59) HEAT(blocked,135) MAIN(running,435) IDLE(ready,19)
                            Owned mutexes: HTTP(MAIN)
                            Last reset 00:04:56 ago, cause: software
                            Last software reset at 2020-10-05 21:21, reason: User, none spinning, available RAM 6580, slot 1
                            Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0xe000ed38 SP 0xffffffff Task Linu
                            Error status: 0x00
                            MCU temperature: min 31.9, current 32.1, max 32.5
                            Driver 0: position -3403, ok, SG min/max not available
                            Driver 1: position -122, ok, SG min/max not available
                            Driver 2: position 5600, ok, SG min/max not available
                            Date/time: 2020-10-05 21:26:52
                            Cache data hit count 643706022
                            Slowest loop: 128.72ms; fastest: 0.12ms
                            === Storage ===
                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 130ms
                            === MainDDARing ===
                            Scheduled moves: 35273, completed moves: 35273, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                            === AuxDDARing ===
                            Segments left: 0
                            HTTP* is ready with "M122" in state(s) 0
                            File* is ready with "G1 X-41.571999 Y-2.496000 E0.125000" in state(s) 0
                            USB is idle in state(s) 0
                            === Filament sensors ===
                            Extruder 0 sensor: no data received
                            Last transfer: 6ms ago
                            RX/TX seq numbers: 8893/8895
                            Buffer RX/TX: 72/552-0
                            === Duet Control Server ===
                            File:
                            Buffered code: G1 X-41.835 Y0.737 E0.0751
                            Buffered code: G1 X-42.029 Y0.931 E0.0251
                            Buffered code: G1 X-42.025 Y0.993 E0.0057
                            Buffered code: G1 X-41.947 Y1.264 E0.0259
                            Buffered code: G1 X-41.938 Y1.313 E0.0045
                            Buffered code: G1 X-41.883 Y1.592 F4200
                            Buffered code: G1 X-41.874 Y1.623
                            Buffered code: G1 X-41.784 Y1.676
                            Buffered code: G1 X-41.728 Y1.620
                            Buffered code: G1 X9.712 Y-0.323 F9000
                            Buffered code: G1 X9.775 Y-0.386 E0.0082 F4200
                            Buffered code: G1 X10.561 Y-0.698 E0.0775
                            Buffered code: G1 X10.830 Y-0.827 E0.0274
                            Buffered code: G1 X12.013 Y-1.633 E0.1312
                            Buffered code: G1 X11.223 Y-0.844 E0.1024
                            Buffered code: G1 X11.562 Y-0.957 E0.0327
                            Buffered code: G1 X11.968 Y-1.178 E0.0424
                            Buffered code: G1 X12.814 Y-1.444 E0.0813
                            Buffered code: G1 X13.857 Y-2.487 E0.1352
                            Buffered code: G1 X14.666 Y-2.525 E0.0743
                            Buffered code: G1 X14.851 Y-2.491 E0.0172
                            Buffered code: G1 X14.101 Y-1.742 E0.0971
                            Buffered code: G1 X14.761 Y-1.806 E0.0608
                            ==> 1088 bytes
                            Code buffer space: 2552
                            Full transfers per second: 29.92
                            File /opt/dsf/sd/gcodes/belly-4-repaired.gcode is selected, processing, simulating
                            50%
                            M122
                            Used output buffers: 1 of 24 (20 max)
                            Static ram: 23252
                            Tasks: Linux(ready,31) HEAT(blocked,135) MAIN(running,435) IDLE(ready,19)
                            Last reset 01:05:19 ago, cause: software
                            Error status: 0x00
                            MCU temperature: min 31.8, current 32.7, max 33.1
                            Driver 0: position 1514, ok, SG min/max not available
                            Driver 1: position -4643, ok, SG min/max not available
                            Driver 2: position 183680, ok, SG min/max not available
                            Date/time: 2020-10-05 22:27:15
                            Slowest loop: 157.10ms; fastest: 0.11ms
                            === Storage ===
                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 217ms
                            === MainDDARing ===
                            Scheduled moves: 813549, completed moves: 813549, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                            === AuxDDARing ===
                            Segments left: 0
                            File* is ready with "G1 X18.978001 Y-58.014999 E0.005600" in state(s) 0
                            Last transfer: 9ms ago
                            RX/TX seq numbers: 52153/52155
                            Buffer RX/TX: 1008/1512-0
                            File:
                            Buffered code: G1 X19.514 Y-57.642 E0.0406
                            Buffered code: G1 X20.322 Y-57.460 E0.0759
                            Buffered code: G1 X20.667 Y-57.806 E0.0447
                            Buffered code: G1 X21.102 Y-57.712 E0.0408
                            Buffered code: G1 X21.441 Y-57.589 E0.0330
                            Buffered code: G1 X21.008 Y-57.156 E0.0561
                            Buffered code: G1 X21.162 Y-57.084 E0.0156
                            Buffered code: G1 X21.778 Y-56.936 E0.0581
                            Buffered code: G1 X22.168 Y-57.326 E0.0506
                            Buffered code: G1 X22.516 Y-57.201 E0.0339
                            Buffered code: G1 X22.527 Y-57.198 E0.0010
                            Buffered code: G1 X22.875 Y-57.043 E0.0349
                            Buffered code: G1 X22.570 Y-56.738 E0.0396
                            Buffered code: G1 X22.922 Y-56.598 E0.0347
                            Buffered code: G1 X23.303 Y-56.482 E0.0366
                            Buffered code: G1 X23.569 Y-56.747 E0.0344
                            Buffered code: G1 X24.290 Y-56.479 E0.0706
                            Buffered code: G1 X24.049 Y-56.237 E0.0313
                            ==> 860 bytes
                            Pending code: G1 X24.257 Y-56.166 E0.0202
                            Pending code: G1 X24.765 Y-55.963 E0.0501
                            Pending code: G1 X25.017 Y-56.216 E0.0327
                            Pending code: G1 X25.163 Y-56.167 E0.0141
                            Pending code: G1 X25.760 Y-55.969 E0.0577
                            Pending code: G1 X25.471 Y-55.680 E0.0375
                            Pending code: G1 X25.906 Y-55.483 E0.0437
                            Code buffer space: 1868
                            Full transfers per second: 30.03
                            during simulation:
                            • arhiundefined
                              arhi @A Former User
                              yes, that would work but I hate those comb soldering + it would require thicker board to properly work, also I don't think I ever seen 90 degree female double header, usually male is 90 degree and we need female here.
                              Thing is, there's nothing important between connector and edge of the board, I can just move the connector closer to the edge (cut the edge closer to connector) but for now it's not a big deal since I just used another rpi that does not have active cooler on it and the passive heatsinks are more than enough as this will be in a box with duet that will have active cooling anyhow so air movement will happen for sure 🙂 ... also, dunno when plugins will come but for now load is very low so rpi is rather cold
                              • arhiundefined
                                arhi
                                test jig
                                • arhiundefined
                                  arhi
                                  finished simulation
                                  M122
                                  Static ram: 23252
                                  Last reset 11:58:35 ago, cause: software
                                  Error status: 0x00
                                  MCU temperature: min 31.7, current 32.6, max 33.4
                                  Driver 0: position -936, ok, SG min/max not available
                                  Driver 1: position -3271, ok, SG min/max not available
                                  Driver 2: position 320880, ok, SG min/max not available
                                  Date/time: 2020-10-06 09:20:31
                                  Slowest loop: 353.02ms; fastest: 0.11ms
                                  === Storage ===
                                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 244ms
                                  === MainDDARing ===
                                  Scheduled moves: 1563560, completed moves: 1563560, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                                  === AuxDDARing ===
                                  Segments left: 0
                                  File* is idle in state(s) 0
                                  RX/TX seq numbers: 9278/9280
                                  Buffer RX/TX: 0/0-0
                                  File:
                                  Buffered code: M98 P"print_stop.g"
                                  Buffered code: ; Build Summary
                                  Buffered code: ;   Build time: 10 hours 10 minutes
                                  Buffered code: ;   Filament length: 159104.0 mm (159.10 m)
                                  Buffered code: ;   Plastic volume: 382690.08 mm^3 (382.69 cc)
                                  Buffered code: ;   Plastic weight: 478.36 g (1.05 lb)
                                  Buffered code: ;   Material cost: 22.00
                                  ==> 424 bytes
                                  Code buffer space: 4096
                                  Full transfers per second: 32.35
                                  • arhiundefined
                                    arhi
                                    now question is how is simulation related to real stuff wrt sbc/duet communication
                                      dc42 administrators @arhi
                                      The simulation runs on the Duet, so the SBC to Duet traffic is much the same as for a real print, except for fewer status requests/responses because of the shorter duration.
                                      • arhiundefined
                                        arhi @dc42
                                        @dc42 said in Duet 2 Ethernet and SBC:
                                        Great, so I can assume this "link" between SBC and Duet2 is stable.
                                        I intentionally put a DCDC close to the "link" and I have these long pins sticking out like antennas so "worse case scenario" and after the relativly long simulation I don't see any errors in the log. When I trim the pins and remove the DCDC from there it should be even better :).
                                        Awesome 🙂
                                        btw, another question. How does the SBC+Duet work now? Similar to klipper where SBC is calculating paths and duet just executing stepping table or more like octoprint where SBC is streaming G-Code to the duet and the path calculation is executed on the Duet? (I know it's not identical to neither of those two but those are 2 extremes)
                                          GCodes are pre-parsed on the SBC and certain operations (e.g. macro expansion) are done on the SBC. The motion calculation is done on the Duet.
                                          • arhiundefined
                                            arhi @dc42
                                            @dc42 nice, so closer to octoprint than to klipper but unique ... /me like 🙂
