New Duet 2 extruder not working
@Phaedrux ; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed May 06 2020 16:21:04 GMT+0800 (中国标准时间)
G91 ; relative positioning
G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning
; homey.g
; called to home the Y axis
G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F6000 ; go back a few mm
G1 H1 Y-215 F360 ; move slowly to Y axis endstop once more (second pass)
; homez.g
; called to home the Z axis
G1 H1 Z-205 F1800 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homeall.g
; called to home all axes
G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-205 F360 ; move Z down stopping at the endstop
;G90 ; absolute positioning -
@GG said in New Duet 2 extruder not working:
M574 Z1 S2;
M558 P1 H3 F120 A10 S0.03 I1 ; set endstops controlled by probe
M558 P1 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh gridYou've got a probe defined, but your homing files are using an endstop.
Do you have a probe installed?
You should combine the two M558 lines you have into one line.
@Phaedrux Yes I m using the original z probe which triggers in DWC at 990 and also stops the bed when raising to nozzle and the led flashes. I think its a inductive type
@Phaedrux Yes yuo are right, the whole z probe config looks a bit confusing to me one line says set endstop controlled by probe and the next says disable probe ???
@Phaedrux How would I combine the two M558 lines
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)To change to using the z probe you need to modify your homeall and homez to use a G30 command instead of this endstop homing move.
Replace that section with something like this
G1 X150 Y150 ; move probe to center of bed
G30 ; probe z0
G1 X0 Y0 ; return to home position -
M558 P1 H5 F120 T6000 A10 S0.03
@Phaedrux z homing now moves to centre of bed, great but does not home because dwc says probe already triggerd at start of movement, I could see it was already at 1000 at start of home
@Phaedrux said in New Duet 2 extruder not working:
Sorry I neglected to add the
I1
from one of your commands to invert the signal.M558 P1 H5 F120 T6000 A10 S0.03 I1
@Phaedrux Thanks got that sorted. In DWC when I use z button after homing, to move 5mm it moves 50mm , Any help appreciated .GG
Z4000
Your steps per mm should probably be 400 not 4000.
@Phaedrux I changed that and it fixed the movement back to 5mm but the movement was sooooo slow
Z180
Increase your maximum speed for z. 180mm/min is 2mm/s. Change it to 600 and try again.
Probe speed is defined by m558 F
I changed M558 to F600 and that solved speed problem but Z axis went back to moving 50mm when 5mm button pressed on dwc console
Post your current config.g
@Phaedrux Also panel due still not reading config g as in not homing like ; Configuration file for Duet WiFi (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed May 06 2020 16:21:04 GMT+0800 (中国标准时间); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; core xy mode
M555 P2 ; set output to look like marlin
G21 ; work in mm,s
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M569 P3 S1 ; physical drive 3 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
;Dual Z
M584 X0 Y1 Z2:4 E3 ;
M671 X-100:415 Y160:160 S2.0 ;
M92 X80.00 Y80.00 Z4000.00 E396.00 ; set steps per mm
M208 X-100 Y-30 Z0 S1 ; set axis minima
M208 X310 Y310 Z380 S0 ; set axis maxima; Endstops
M574 X1 Y1 S0 ; set active low and disabled endstops
;Filament Run Out Sensor
M591 D0 P1 C4 S1; Filament run out sensor for extruder E0 on E1 end stop input P1 = signal HIGH .
M574 Z1 S2;M558 P1 H5 F600 T6000 A10 S0.03 I1 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 1
M305 P2 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 2
M143 H2 S280 ; set temperature limit for heater 2 to 280C; Fans
M106 P1 S1 I0 F500 H1:2 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 S"Extruder" ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CT0;
M302 P1
M575 P1 S1 B57600; Enable paneldue -
You didn't change the steps per mm in config.g
@Phaedrux Duet2 ethernet purchased from Official reprap store thru aliexpress , July 2020, along with 4" paneldue
This is almost certainly a clone board with no warranty provided by Duet3D. Just in case you were not aware.
What exactly happens when you press the homing buttons on the paneldue?
What buttons are you clicking on in DWC to home?
What happens if you send M98 P"0:/sys/homeall.g"? Does it behave the same as pressing homeall on the paneldue or homeall on the DWC?
Can you post a screenshot of your DWC screen showing what you're clicking on to home? Or make a video showing the behaviour?
@Phaedrux Sorry I thought I had changed that, It now moves the amount commanded by dwc on z, but still slow, 10 sec to move vertically 25mm, maybe thats ok. I didnt know board was clone, but had my suspicions when it didnt come in Duet box. Thought "official" reprap store would have been legit. I read somewhere that the ethernet boards were being made under license in china and the wifi boards inUK. I suppose that means Paneldue is clone also?? I certainly paid top dollar. There were clones on the site but stated as clones and were half the price???
Upon send the M98 command it homes all symataneously, ie diagonally for x and y then homes z but quite slowly.
Im using the home buttons in the machine movement section in the dashboard of DWC. Is this board liokely to be piece of crap,, should I buy a relacemenr genuine, I tried to buy wifi board but difficulty due to Covid and uk factory under lockdown.
I can home all axis individually so maybe Ill have to settle for that
