Identical artifacts/issues on two parts on the same print job
1.4k
    Turbo @Veti
    @Veti so would the code just look like...?
    M305 P1 T100000 B4725 C7.06e-8 R4700    ; Set thermistor + ADC parameters for heater 1
    also what about the bed heater? its a keenovo assembly
    Cant stop tuning wont stop tuning.
    Dbot, Custom i3, Voron 0&2
      Veti
      in rrf2 yes
      undefined 1 Reply Last reply 7 Oct 2020, 17:14 Reply Quote 0
        Turbo @Veti
        @Veti newbie question but how can i tell if i have rrf2 or not? thats the code on the printer in question, and this is the code on my other printer. Different M commands
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
        M308 S1 P"e0temp" Y"thermistor" T100000 B3988 ; configure sensor 1 as thermistor on pin e0temp
        also i now realize i have the bed therm for this config set as an e3d therm and not the actual one. i think theyre backwards.
          Veti
          using M115
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M115_Get_Firmware_Version_and_Capabilities
          undefined 1 Reply Last reply 7 Oct 2020, 17:18 Reply Quote 0
            Veti
            @Turbo said in Identical artifacts/issues on two parts on the same print job:
            M906 X1000 Y1000 Z1000 E850:850 I50 ; Set motor currents (mA) and motor idle factor in percent
            what motors have you got?
            undefined 1 Reply Last reply 7 Oct 2020, 17:19 Reply Quote 0
              Turbo @Veti
              @Veti
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
                Veti
                so you are on rrf2 here.
                  Turbo @Veti
                  @Veti mototrs are part no 17hs19-2004s1.
                  I dont think theyre the culprit because i have had good prints before with them. The printer sat for 6 months or so so i came back to a bunch or random issues and not remembering much about the printer
                    Veti
                    17hs19-2004s1.
                    those are 2A motors. you are running them with not enough current. set the current to 1500ma
                    undefined 2 Replies Last reply 7 Oct 2020, 17:28 Reply Quote 0
                      Turbo @Veti
                      @Veti done. would that cause my issues or could there be more? its ran fin on 1000mA current since i got it, but now that i think of it, the prints were never perfect.
                        Veti
                        it could.
                          Turbo @Veti
                          @Veti also would you know where i can find a chart or something for setting thermistors? i need to adjust both of my printers. this is the bed heater NTC 100K thermistor ( Beta 25/50 3950K-1%
                            Veti
                            3950K
                            thats the beta value
                            undefined 1 Reply Last reply 7 Oct 2020, 17:42 Reply Quote 0
                              Turbo @Veti
                              @Veti gotcha. Thank you for answering my questions. Im going to try a test print or 2 with the updated settings and report back.
                                Veti
                                do post your final config for another check
                                undefined 1 Reply Last reply 7 Oct 2020, 17:44 Reply Quote 0
                                  Turbo @Veti
                                  @Veti Its been through some revisions so theres some leftover code that i keep incase i revert back.
                                  ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
                                  ; generated by RepRapFirmware Configuration Tool on Thu Jun 21 2018 19:14:32 GMT-0700 (Pacific Daylight Time)
                                  M667 S1 ; Select CoreXY mode
                                  M550 PBlue the D-Bot ; Set machine name
                                  M552 S1 ; Enable network
                                  M586 P0 S1 ; Enable HTTP
                                  M586 P1 S0 ; Disable FTP
                                  M586 P2 S0 ; Disable Telnet
                                  M569 P3 S0 ; Drive 3 goes forwards
                                  M92 X100 Y100 Z423 E394 ; :870(E2) ; Set steps per mm (Start:Z415) (chimera value 870)
                                  M566 X1000 Y1000 Z240 E600:600 ; Set maximum instantaneous speed changes (mm/min) (OG E600:600)
                                  M203 X18000 Y18000 Z2400 E3600:3600 ; Set maximum speeds (mm/min)
                                  M201 X1250 Y1250 Z250 E2000:2000 ; Set accelerations (mm/s^2)
                                  M906 X1500 Y1500 Z1000 E850:850 I50 ; Set motor currents (mA) and motor idle factor in percent
                                  M84 S30 ; Set idle timeout
                                  M208 X-10 Y-10 Z0 S1 ; Set axis minima (chimera/original y value = 0)
                                  M208 X300 Y185 Z300 S0 ; Set axis maxima
                                  M574 X1 Y2 S3 ; Set endstops controlled by motor load detection
                                  M574 Z1 S2 ; Set endstops controlled by probe
                                  M307 H3 A-1 C-1 D-1
                                  M558 P9 H5 F750 T7200
                                  G31 X25.9 Y0 Z02.3 P25 ; Probe Offset - Increase for Nozzle down, Decrease for Nozzle up (chimera value .6)
                                  M557 X26:280 Y5:185 S50:45 ; Define mesh grid
                                  M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                                  ; Heater 1
                                  M143 H0 S110 ; Set temperature limit for heater 0 to 110C
                                  M143 H1 S275 ; Set temperature limit for heater 1 to 275C
                                  ; Heater 2 (disable for Titan Aero)
                                  ;M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
                                  ;M143 H2 S275 ; Set temperature limit for heater 2 to 275C
                                  M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P1 S165 T55 H1:2 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M563 P0 D0 H1 ; Define tool 0
                                  ; Next 3 lines are for Chimera config. Disabled for Titan Aero
                                  ; IMPORTANT: Titan Aero Thermistors are swapped at the board. Swap them back for Chimera Use. NOT THE CASE FOR V2
                                  ;M563 P1 D1 H2 ; Define tool 1
                                  ;G10 P1 X9 Y0 Z0 ; Set tool 1 axis offsets
                                  ;G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                                  T0 ; Select first tool. Change to T-1 for use with Chimera
                                  undefined undefined 3 Replies Last reply 7 Oct 2020, 17:45 Reply Quote 0
                                    Turbo @Turbo
                                    @Turbo For fun heres my other printers config file running rrf3 if you want to rifle through it
                                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 16 2020 15:52:25 GMT-0700 (Pacific Daylight Time)
                                    M550 P"CCPrinting" ; set printer name
                                    M552 S1 ; enable network
                                    M586 P0 S1 ; enable HTTP
                                    M586 P1 S0 ; disable FTP
                                    M586 P2 S0 ; disable Telnet
                                    M569 P2 S0 ; physical drive 2 goes backwards
                                    M92 X160.00 Y160.00 Z400.00 E390.00 ; set steps per mm (Currently 2x for 0.9 Steppers on X & Y)
                                    M566 X700.00 Y700.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                    M203 X12000.00 Y12000.00 Z1200.00 E3000.00 ; set maximum speeds (mm/min)
                                    M201 X800.00 Y800.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                    M906 X700 Y700 Z700 E855 I30 ; set motor currents (mA) and motor idle factor in per cent
                                    M208 X-3.5 Y0 Z0 S1 ; set axis minima
                                    M208 X200 Y200 Z140 S0 ; set axis maxima
                                    M574 X1 S3 ; configure sensorless endstop for low end on X
                                    M574 Y1 S3 ; configure sensorless endstop for low end on Y
                                    M558 P9 C"^zprobe.in" H5 F750 T7200 ; BLTouch connected to Z probe IN pin
                                    M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector
                                    G31 P500 X55 Y10.58 Z1.2 ; set Z probe trigger value, offset and trigger height Increase for Nozzle down, Decrease for Nozzle up
                                    M557 X55:197 Y20:190 S71:85 ; define mesh grid
                                    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                    ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
                                    ;M106 P0 C"SHORTED DO NOT USE" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                                    ;M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency
                                    ;M106 P1 C"SHORTED DO NOT USE" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                                    M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                    M106 P2 C"Part Cooling Fan" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
                                    M563 P0 S"Hemera" D0 H1 F2 ; define tool 0
                                    M501
                                    T0 ; select first tool
                                      Veti @Turbo
                                      Z1000
                                      is your z motor a different motor?
                                      undefined 1 Reply Last reply 7 Oct 2020, 17:48 Reply Quote 0
                                        Turbo @Veti
                                        @Veti its a 5:1 geared stepper motor. 17hs15-1684s-pg5
                                        https://www.omc-stepperonline.com/nema-17-stepper-motor-bipolar-l38mm-w-gear-raio-51-planetary-gearbox-17hs15-1684s-pg5.html
                                          Veti
                                          17hs15-1684s-pg5
                                          set that to 1200
                                          you should got for around 75% of the stated current.
                                          how heavy is your bed, that you need 5:1 stepper drivers?
                                          undefined 1 Reply Last reply 7 Oct 2020, 17:52 Reply Quote 0
                                          21 out of 50
