Solved BLTouch Zprobe marche pas
@chris974M said in BLTouch Zprobe marche pas:
G31 P500 X390 Y250 Z3.71
Your X and Y offset is certainly wrong. This should be the distance from the nozzle to the probe.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
Delete that line. It's not used in RRF3.
M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
What pin are you connected to? Are you using a duex?
What is in your deployprobe.g and retractprobe.g files?
Does M401 and M402 deploy and retract the probe?
duex5 brancher sur PWM5 M401 M402 not work
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 15:26:33 GMT+0200 (heure d’été d’Europe centrale)
M280 P7 S10 ; deploy BLTouch -
; retractprobe.g
; called to retract a physical Z probe
M280 P7 S90 ; retract BLTouch -
In your deploy and retract macros P7 should be P0 now in RRF3 to match the servo index created with M950 S0.
M280 P7 S90 > M280 P0 S90
M280 P7 S10 > M280 P0 S10 -
@Phaedrux said in BLTouch Zprobe marche pas:
M950 S0
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 15:26:33 GMT+0200 (heure d’été d’Europe centrale); General preferences
M550 P"MonsterPrinter" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P5 S1 ; physical drive 5 goes forwards
M569 P6 S1 ; physical drive 6 goes forwards
M569 P7 S0 ; physical drive 7 goes forwards
M584 X0:5 Y1:6 Z2:7 E3 ; set drive mapping
M92 X100.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y1400.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y1950 Z1400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-6 Y-10 Z0 S1 ; set axis minima
M208 X780 Y510 Z350 S0 ; set axis maxima; Endstops
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X390 Y250 Z3.71 ; set Z probe trigger value, offset and trigger height
M557 X40:780 Y80:510 S100 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M305 P1 T4606017 B5848 C5.548428e-8 R4700 H0 L0
M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S493
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
config.g like that ?
before the MAJ my BLtouch work normally
; deployprobe.g
M280 P0 S10 ; deploy BLTouch -
; retractprobe.g
M280 P0 S90 ; retract BLTouch -
This was correct.
Don't forget to fix this.
oui j'ai corriger cette erreur mes sa ne marche toujours pas
M950 S0This is wrong. It should be
@Phaedrux j'ai corriger toujours rien
M950 S0 C "duex.pwm5" ; créer la broche servo 0 pour BLTouch
G31 P500 X0 Y20 Z3.71 ; set Z probe trigger value, offset and trigger height
M143 H1 S493
Try
M950 S0 C"!duex.pwm5"
@Phaedrux not work
G28
Error: Z probe was not triggered during probing move
Error: Homing failed
