    BLTouch Zprobe marche pas
    Firmware installation
    1.8k
      What is in your deployprobe.g and retractprobe.g files?
      Does M401 and M402 deploy and retract the probe?
      • chris974Mundefined
        chris974M
        duex5 brancher sur PWM5 M401 M402 not work
          chris974M
          ; deployprobe.g
          ; called to deploy a physical Z probe
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 15:26:33 GMT+0200 (heure d’été d’Europe centrale)
          M280 P7 S10 ; deploy BLTouch
            chris974M
            ; retractprobe.g
            ; called to retract a physical Z probe
            M280 P7 S90 ; retract BLTouch
              In your deploy and retract macros P7 should be P0 now in RRF3 to match the servo index created with M950 S0.
              M280 P7 S90 > M280 P0 S90
              M280 P7 S10 > M280 P0 S10
                chris974M
                @Phaedrux said in BLTouch Zprobe marche pas:
                M950 S0
                M550 P"MonsterPrinter" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P1 S0 ; physical drive 1 goes forwards
                M569 P5 S1 ; physical drive 5 goes forwards
                M569 P6 S1 ; physical drive 6 goes forwards
                M569 P7 S0 ; physical drive 7 goes forwards
                M584 X0:5 Y1:6 Z2:7 E3 ; set drive mapping
                M92 X100.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                M566 X900.00 Y1400.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                M906 X800 Y1950 Z1400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X-6 Y-10 Z0 S1 ; set axis minima
                M208 X780 Y510 Z350 S0 ; set axis maxima
                M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                M950 S0
                M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                G31 P500 X390 Y250 Z3.71 ; set Z probe trigger value, offset and trigger height
                M557 X40:780 Y80:510 S100 ; define mesh grid
                M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
                M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                M143 H0 S150 ; set temperature limit for heater 0 to 150C
                M305 P1 T4606017 B5848 C5.548428e-8 R4700 H0 L0
                M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 ; configure sensor 1 as thermistor on pin e0temp
                M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
                M143 H1 S493
                Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  chris974M
                  config.g like that ?
                    chris974M
                    before the MAJ my BLtouch work normally
                      chris974M
                      ; deployprobe.g
                      M280 P0 S10 ; deploy BLTouch
                        chris974M
                        ; retractprobe.g
                        M280 P0 S90 ; retract BLTouch
                          @chris974M said in BLTouch Zprobe marche pas:
                          M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
                          This was correct.
                            Phaedrux Moderator @chris974M
                            Don't forget to fix this.
                              chris974M
                              oui j'ai corriger cette erreur mes sa ne marche toujours pas
                                M950 S0
                                This is wrong. It should be M950 S0 C"duex.pwm5"
                                chris974Mundefined 1 Reply Last reply Reply Quote 0
                                  chris974M @Phaedrux
                                  @Phaedrux j'ai corriger toujours rien
                                    chris974M
                                    M950 S0 C "duex.pwm5" ; créer la broche servo 0 pour BLTouch
                                    G31 P500 X0 Y20 Z3.71 ; set Z probe trigger value, offset and trigger height
                                    M143 H1 S493
                                      Try M950 S0 C"!duex.pwm5"
                                        chris974M @Phaedrux
                                        @Phaedrux not work
                                          chris974M
                                          G28
                                          Error: Z probe was not triggered during probing move
                                          Error: Homing failed
                                            Does the BLTouch do a self test on power up with the pin deploying correctly?
                                            Check your wiring for continuity.
                                            Are you sure you are connected to Duex5 PWM5?
                                            Can you try PWM1 instead?
