Solved BLTouch Zprobe marche pas
@Phaedrux not work
G28
Error: Z probe was not triggered during probing move
Error: Homing failed -
Does the BLTouch do a self test on power up with the pin deploying correctly?
Check your wiring for continuity.
Are you sure you are connected to Duex5 PWM5?
Can you try PWM1 instead?
@Phaedrux said in BLTouch Zprobe marche pas:
Yes
My wiring is perfect
yesterday i check that before the maj and he is working corrct -
Can you please send M122 and report the results.
Also send M98 P"config.g" and report the results. -
M122
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DLM-996RU-N8PS4-6JKD8-3S06T-KBVRN
Used output buffers: 1 of 24 (10 max)
Static ram: 27980
Dynamic ram: 94224 of which 44 recycled
Exception stack ram used: 264
Never used ram: 8560
Tasks: NETWORK(ready,416) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1824) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:17 ago, cause: software
Last software reset at 2020-10-08 00:05, reason: User, spinning module GCodes, available RAM 8560 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 23.8, current 24.4, max 24.9
Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Date/time: 2020-10-08 00:07:10
Cache data hit count 133234046
Slowest loop: 5.10ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.5ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is ready with "M122 " in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.65ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address f4:cf:a2:66:94:6a
WiFi Vcc 3.43, reset reason Unknown
WiFi flash size 4194304, free heap 26096
WiFi IP address 192.168.1.122
WiFi signal strength -57dBm, reconnections 0, sleep mode modem
=== DueX ===
Read count 1, 0.77 reads/min
- WiFi -
M98
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Error: M305 has been replaced by M308 and M950 in RepRapFirmware 3
Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 605C -
@chris974M said in BLTouch Zprobe marche pas:
M305 P1 T4606017 B5848 C5.548428e-8 R4700 H0 L0
Remove that line, though it's not related to the bltouch issue.
Are you able to try PWM1?
ok i try
que faut il que je change pour PWM1
Example 4 (BLTouch on Duet WiFi) - old code:
M558 P9 H5 F120 T3000 ; BLTouch connected to Z probe IN pin
M307 H3 A-1 C-1 D-1 ; free up heater 3 to use as BLTouch servo pin
M280 P3 S10 I1 ; send control signal to BLTouch through heater 3 pin
New code:M558 P9 C"^zprobe.in" H5 F120 T3000 ; BLTouch connected to Z probe IN pin
M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector
M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0 -
M558 P9 C "^ zprobe.in " H5 F120 T3000; BLTouch connecté à la sonde Z IN pin
M950 S0 C "duex.pwm1"; créer servo / gpio 0 sur l'élément chauffant 3 broches sur le connecteur d'extension
M280 P0 S10; envoyer un signal de commande à BLTouch via servo / gpio 0Like that or nope
Avertissement: le réchauffeur 0 semble être suralimenté. S'il est laissé allumé à pleine puissance, sa température devrait atteindre 365 ° C.
Avertissement: le réchauffeur 1 semble être suralimenté. S'il est laissé allumé à pleine puissance, sa température devrait atteindre 605 ° Cis it normal ?
Yes it should be like that.
Its WORK
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 15:26:33 GMT+0200 (heure d’été d’Europe centrale); General preferences
M550 P"MonsterPrinter" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P5 S1 ; physical drive 5 goes forwards
M569 P6 S1 ; physical drive 6 goes forwards
M569 P7 S0 ; physical drive 7 goes forwards
M584 X0:5 Y1:6 Z2:7 E3 ; set drive mapping
M92 X100.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y1400.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X1700 Y2400 Z1700 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-6 Y-10 Z0 S1 ; set axis minima
M208 X780 Y510 Z350 S0 ; set axis maxima; Endstops
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P9 C"^zprobe.in" H5 F120 T6000 ; BLTouch connected to Z probe IN pin
M950 S0 C"duex.pwm1" ; create servo/gpio 0 on heater 3 pin on expansion
M280 P0 S10 ; envoyer un signal de commande à BLTouch via servo / gpio 0
G31 P500 X0 Y20 Z3.71 ; set Z probe trigger value, offset and trigger height
M557 X40:780 Y80:510 S100 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S493
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
Pour le BLTouch avec DUEX5 brancher sur PWM1
si sa peut aider quelqu'un d'autre -
My pin Is down during homing XY why ?
