    BLTouch Zprobe marche pas
    Firmware installation
    1.8k
      Phaedrux Moderator @chris974M
      @chris974M said in BLTouch Zprobe marche pas:
      M558 P9 C "^ zprobe.in " H5 F120 T3000; BLTouch connecté à la sonde Z IN pin
      M950 S0 C "duex.pwm1"; créer servo / gpio 0 sur l'élément chauffant 3 broches sur le connecteur d'extension
      M280 P0 S10; envoyer un signal de commande à BLTouch via servo / gpio 0
      Like that or nope
      Yes it should be like that.
      • chris974Mundefined
        chris974M
        @Phaedrux said in BLTouch Zprobe marche pas:
        duex.pwm
        M280 before or after the line G31
          chris974M
          Its WORK
            chris974M
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 15:26:33 GMT+0200 (heure d’été d’Europe centrale)
            M550 P"MonsterPrinter" ; set printer name
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P1 S0 ; physical drive 1 goes forwards
            M569 P5 S1 ; physical drive 5 goes forwards
            M569 P6 S1 ; physical drive 6 goes forwards
            M569 P7 S0 ; physical drive 7 goes forwards
            M584 X0:5 Y1:6 Z2:7 E3 ; set drive mapping
            M92 X100.00 Y80.00 Z400.00 E420.00 ; set steps per mm
            M566 X900.00 Y1400.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X1700 Y2400 Z1700 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-6 Y-10 Z0 S1 ; set axis minima
            M208 X780 Y510 Z350 S0 ; set axis maxima
            M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
            M558 P9 C"^zprobe.in" H5 F120 T6000 ; BLTouch connected to Z probe IN pin
            M950 S0 C"duex.pwm1" ; create servo/gpio 0 on heater 3 pin on expansion
            M280 P0 S10 ; envoyer un signal de commande à BLTouch via servo / gpio 0
            G31 P500 X0 Y20 Z3.71 ; set Z probe trigger value, offset and trigger height
            M557 X40:780 Y80:510 S100 ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
            M143 H0 S150 ; set temperature limit for heater 0 to 150C
            M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 ; configure sensor 1 as thermistor on pin e0temp
            M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
            M143 H1 S493
              chris974M
              Pour le BLTouch avec DUEX5 brancher sur PWM1
              si sa peut aider quelqu'un d'autre
                chris974M
                My pin Is down during homing XY why ?
                  Post your homing files. Does m401 and m402 work?
                    chris974M
                    ; homeall.g
                    ; called to home all axes
                    G91 ; relative positioning
                    G1 H2 Z5 F8000 ; lift Z relative to current position
                    G1 H1 X-787 Y505 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X5 Y-5 F8000 ; go back a few mm
                    G1 H1 X-787 Y505 F600 ; move slowly to X and Y axis endstops once more (second pass)
                    G90 ; absolute positioning
                    G1 X390 Y250 F8000 ; go to first bed probe point and home Z
                    ;G91 ; relative positioning
                    ;G90 ; absolute positioning
                    ; homez.g
                    ; called to home the Z axis
                    G1 X390 Y250 F8000 ; go to first probe point
                      chris974M
                      M401 and M402 work
                        chris974M
                        BEFORE
                        NEW
                        M280 P0 S90 ; envoyer un signal de commande à BLTouch via servo / gpio 0
                        Just that Thanks
                          chris974M
                          thank you phaedrux for your help
                            Do you have the right command in the right file?
                              chris974M
                              Just change m280
                                So it's working now?
                                chris974Mundefined 1 Reply Last reply Reply Quote 0
                                  chris974M @Phaedrux
                                  @Phaedrux Yes
