Bad printing quality for unknown reason
951
    Phantom329 @Veti
    @Veti Its the full BLV MGN Cube kit https://www.aliexpress.com/item/4000216439704.html
      Phantom329
      @Veti I think it printed better but it still has the weird lines artifact. Printing a benchy now.
      EDIT: Benchy failed but same story.
      print
      undefined 1 Reply Last reply 3 Oct 2020, 04:37 Reply Quote 0
        brotherchris
        Hey, I just happen to see you said Cura, just a wild guess on my part. Is your Slicer set to 3mm filament?
        undefined 1 Reply Last reply 4 Oct 2020, 02:58 Reply Quote 1
          Veti @Phantom329
          @Phantom329 said in Bad printing quality for unknown reason:
          maybe they supplied a semitec thermistor. try B4725 C7.06e-8
            Phantom329 @brotherchris
            @brotherchris Nope, I have the extruder and material set to 1.75mm.
              Phantom329
              I slowed down the printing speed to 30mm/s and on one side it printed almost the same, smaller blobs. On the other side, though, it printed with minimal blobs and shows pretty clean lines. I'm tempted to blame the feeder... its a knock-off dual drive feeder and I had to rebuild it like 10 times to make it smooth. My friend also said it could be the hotend which is a v6 clone. What do you think?
                Veti
                print a temperature tower
                undefined 1 Reply Last reply 9 Oct 2020, 00:38 Reply Quote 0
                  Phantom329 @Veti
                  @Veti Seems like its not a temperature issue
                  undefined 1 Reply Last reply 9 Oct 2020, 04:17 Reply Quote 0
                    Looks over extruded and overheated.
                      Veti @Phantom329
                      did you just print the tower? it looks the same for all heights.
                      you need to script the change of temperature
                      16 out of 16
