    double extruder motor - g.code?
    Firmware installation
    711
    • duttiundefined
      dutti
      hey,
      I want to have 2 motors on each filament.
      One motor for the direct drive extruder, one motor for changing the filament and helping getting filament from a heavy filament roll (10kg).
      Does anybody knows what I have to change on the g code?
      Driver 1 + Driver 0 or
      Driver 2 + Driver 0 Must work together all the time. Same steps etc.
      Drivers areon the expansion board.
      Duet3
      thanks
      R.G.
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Duet 3" ; set printer name
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M569 P1.0 S1 ; physical drive 1.0 goes forwards
      M569 P1.1 S1 ; physical drive 1.1 goes forwards
      M569 P1.2 S1 ; physical drive 1.2 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z1600.00 E375:375:375 ; set steps per mm ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z3000 E1000:1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X700 Y700 Z800 S0 ; set axis maxima
      M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
      M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
      M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
      G31 P25 X0 Y-36 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X10:600 Y10:600 S200 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S90 ; set temperature limit for heater 0 to 90C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138                                     ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                                               ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"out8" Q500 ; create fan 0 on pin out3 and set its frequency
      M106 P0 S1 H-1  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
      M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on
      M671 X185:185:615:615 Y-125:925:925:-125 S2.5
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
        deckingman @dutti
        @barbarossa-cologne
        To run 2 extruder motors in "push-pull" configuration you simply map both motors to the tool and set the mixing ratio to 1:1.
        Assuming you have 3 extruder motors mapped as you have them in your M584. Then the first motor is extruder drive 0, the second is extruder drive 1 and the third is extruder drive 2. Assuming the first one is common (driver 0) then you define the tool like this....
        M563 P0 D0:1 H1 F0 ; define tool 0
        and set the mixing ratio like this
        M567 P0 E1.00:1.00
        To change extruder drives, you now have 2 options and to switch between them, the best way might be to use macros. The first option is simply to change the drive mapping. So it becomes
        M563 P0 D0:2 H1 F0 ; define tool 0
        Or you can create a second tool as above but change P0 to P1 so the second tool becomes tool 1 and when you change to a different spool, you change the tool.
        Actually, there is also a third option and that is to have a single tool but map all drives to it like this:
        M563 P0 D0:1:2 H1 F0
        and then change the mixing ratio so for one reel of filament you would use:
        M567 P0 E1.00:1.00:0.00
        and for the second reel of filament you would use
        M567 P0 E1.00:0.00:1.00
        HTH
        duttiundefined 1 Reply Last reply Reply Quote 1
        • duttiundefined
          dutti @deckingman
          @deckingman said in double extruder motor - g.code?:
          I would prefer the option with
          :M563 P0 D0:2 H1 F0 ; define tool 0
          with adding the second tool it´s :
          M563 P1 D0:2 H1 F0 ; define tool 1
          Is this correct?
          thanks for the great expalantion!!
          Richard
            deckingman @dutti
            @barbarossa-cologne said in double extruder motor - g.code?:
            Is this correct?
            Richard
            Err no. Your two tool definitions are identical so that won't work. With reference to your sketch, you have extruder drive 0 as "common", and driver 1 is the left hand filament and driver 2 is the right hand filament. So your two tool definitions should be:
            That is to say, one tool uses extruder 0 and extruder 1, the other tool uses extruder 0 and extruder 2.
            duttiundefined 2 Replies Last reply Reply Quote 1
            • duttiundefined
              dutti
              ok....
              I´ll try and tell you if it works!
              thank you for the great answer.
              LG
              Richard
              • duttiundefined
                dutti
                This post is deleted!
                • duttiundefined
                  dutti @deckingman
                  • duttiundefined
                    dutti @deckingman
                    @deckingman
                    It´s working..
                    Thanks a lot!!
                      deckingman @dutti
                      @deckingman
                      It´s working..
                      Thanks a lot!!
                      • XSIVSPDundefined
                        XSIVSPD
                        @deckingman thanks for all your knowledge and helpfulness on this forum!
                        I'm thinking of making a MMU2 type multi-material setup that's run via the duet and a duex5 so this thread has been super helpful!
                        I have a BMG that is currently set up as direct drive, and i would like to keep it where it is so that i have the excellent extrusion control that it gives me.
                        My question is: do both drives need to be set to the same steps/mm ?
                        the BMG is 3:1 and the mmu plans that I'm looking at are directly driven by hobs off the stepper shaft. can i set that up with m92 since (im assuming) I'll need to define the additional stepper as U or V axis
                        Thanks in advance!
