    BLTouch M401 M402 test does not work
    752
    • campeancalinundefined
      campeancalin
      • Vetiundefined
        Veti
        if heater 3 is PWM1 then pwm 5 should be heater 7 not 5
          campeancalin
          M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds.
          H5 becomes H7?
            campeancalin
            Nevermind the last question. I meant to ask that "duex.e5heat" becomes "duex.e7heat", in the M950 bellow?
            M950 S0 C"duex.e5heat" ; create servo pin 0 for BLTouch
            • Vetiundefined
              Veti
              @campeancalin said in BLTouch M401 M402 test does not work:
              the configurator even suggest to do this
              M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
                campeancalin
                There 2 options in the configurator : "duex.pwm5" and "duex.pwm5"(active low). Wht's the diferrence between them?
                • Vetiundefined
                  Veti @campeancalin
                  @campeancalin
                  the output value is inverted
                  • wdenkerundefined
                    wdenker @campeancalin
                    @campeancalin your P0 should be P7 in your deploy and retractprobe.g
                    www.bd3dcustoms.com | BD3DCUSTOMS Supercube
                    • Vetiundefined
                      Veti @wdenker
                      @wdenker said in BLTouch M401 M402 test does not work:
                      P0 is correct for RRF3
                      P7 was RRF2
                      wdenkerundefined 1 Reply Last reply Reply Quote 1
                      • wdenkerundefined
                        wdenker @Veti
                        @Veti you are right sorry I pulled from my 2.05 version. and 3.1 I only have working on duet 3 so far.
                          campeancalin
                          Thank you again for the info @Veti. Everything works with "duex.pwm5" set up.
