The rotating magnet filament monitor is out of stock eveywhere
@the_dragonlord said in The rotating magnet filament monitor is out of stock eveywhere:
what's the gcode to add to the firmware to configure and make the sensor work? even to configure the pause in event of run out
M591
I use
M591 D0 P2 C"io8.in" S1
because my switch is wired to pull input 'io8.in' low when the filament is present, but it will depend what firmware and hardware you're running - see the description at https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
@achrn said in The rotating magnet filament monitor is out of stock eveywhere:
M591
I use
excellent my friend, thanks!
would it be possible to use a switch as a filament sensor?
Yes but it only tells you if the filament has broken or run out.
The failure of filament to feed is of importance and thus the existence of sensors like the laser and rotating magnet designs.
But I imagine you already know all that.
@fcwilt said in The rotating magnet filament monitor is out of stock eveywhere:
sure, infact I'll use a simple switch only for the time needed for the magnet sensor to be available again
@the_dragonlord
A while back I ordered two but they only had one.
So like everyone else I wait...
and wait...
and wait...
and wait...
We were all set up to move to an improved injection-molded housing for the magnetic filament monitor. Then COVID struck, and the supplier concerned has quite reasonably decided to devote its resources to making PPE instead.
@dc42 said in The rotating magnet filament monitor is out of stock eveywhere:
We were all set up to move to an improved injection-molded housing for the magnetic filament monitor. Then COVID struck, and the supplier concerned has quite reasonably decide to devote its resources to making PPE instead.
uh, ok... but have you got a reasonably forecast for the time needed to the device for be delivered again? are we talking about days, weeks, months or no forecast at all?
PPE? Have no idea what that is but it must be important.
Stupid virus - mucking everything up - in protest I'm going to refuse to get sick - I'll show that virus who's boss.
Personal Protective Equipment - something worn by an individual to protect that individual.
Previously mostly commonly referring to stuff in industry or construction guarding against physical injury (steel toe-cap boots, helmet, safety glasses, etc) more recently most used with reference to infection control (masks, visors, gloves etc). Used somewhat loosely - face coverings are not for the benefit of the wearer. -
And here I thought it was poly propylene elastomer.
@Phaedrux said in The rotating magnet filament monitor is out of stock eveywhere:
I think it stands for Personal Protection Equipment----
@the_dragonlord I think you're right.
@dc42 Is there an option to just buy the electronics in the meantime and print our own less-fancy housing?
We have a few sets of housingless MFMs at Filastruder, drop an email at support@filastruder.com.
