Trouble with the Duet 2 on a Monoprice Maker Ultimate
Servo 0 not defined would make sense if you're still using rrf2
Can you send m122 and m98 p"config.g" and post the results ?
It would be a lot easier if we just configured for rrf3 at this point.
How are you switching between rrf2 and rrf3?
@Phaedrux said in Trouble with the Duet 2 on a Monoprice Maker Ultimate:
This is the million dollar question... for some reason, I had thought that just uploading the config zip file was enough.
Your last comment lead me to check my assumptions, and yeah, it's still running 2.x...
I'm trying to upload the bin via the web control panel now... I've managed to get web control panel to report that it's 3.x but diagnostics is still saying reprap is 2.05.1...
Do I have to do a hard power cycle maybe?
Ah, ok, then. That answers that.
Here's how you should proceed with the updates.
First make sure you're running 2.05.1, and it sounds like you are, but just to make sure you have all the files needed here's how you do a complete firmware update. It just involves uploading a single zip file for each version to the sys folder via the web interface.
Start with the 2.05.1 zip file. Then upload the 3.0 zip file. Then 3.1.1. It'll reboot between each. Then you can upload your config zip file if you haven't already.
Upload the whole zip file. don't extract it.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
Alright! This seems to be working a lot better. It got to 3.0.0 successfully, though it's been spinning for quite a while on 3.1.1.
The temp sensors were working though.
Still just waiting on it to come back up after the 3.1.1 upgrade though. Might have to go a more manual route for this one since it seems to not be coming back up...
@thejmather said in Trouble with the Duet 2 on a Monoprice Maker Ultimate:
should take less than a minute; reset and try again if it takes longer.
@bearer Yep, it just needed the ol' "turn it off and then on again" treatment. Let's see where I'm at functionality wise with 3.1.1 now that I'm not trying to run a v3 config on v2 firmware LOL...
Neat! It mostly seems to be working. Endstops are good. BLTouch is good.
I was warming things up to do a bed probe though, and got:
Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
I don't see much for options in the config editor to counter this, though...
Config:
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 09 2020 21:30:59 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"MPUltimate" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 E94.30 ; set steps per mm M566 X600.00 Y600.00 Z24.00 E60.00 ; set maximum instantaneous speed changes (mm/min) M203 X7200.00 Y7200.00 Z300.00 E300.00 ; set maximum speeds (mm/min) M201 X800.00 Y800.00 Z100.00 E500.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X200 Y200 Z175 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!^xstop" ; configure active-high endstop for low end on X via pin !^xstop M574 Y1 S1 P"!^ystop" ; configure active-high endstop for low end on Y via pin !^ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X31 Y-20 Z1 ; set Z probe trigger value, offset and trigger height M557 X31:200 Y0:180 S10 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory T0 ; select first tool
You'll need to PID tune your heaters.
Info: https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
Guide: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161 -
It looks like you're missing a hotend heatsink fan, which would normally be on fan1.
Cool - I wasn't sure if that still applied when using the "bang-bang" control method.
@thejmather Bang-bang isn't recommended at all. Once the heaters are tuned with M303, you can send M500 to save the results to config-override.g. Your config.g already has M501 at the end to load them at boot.
I'm lazy and have it plugged into one of the always-on fan spots.
I've read that I can hook up the built-in LED lights to one of the PWM fan connections too... might give that a try.
Ah, good to know bang-bang isn't recommended. I'll get the pid tuning done in a jiffy here...
Fan2 would be a good candidate for LEDs. Fan1 is intended for the hotend because it will power on automatically briefly at power up in case the hotend was hot during a reboot.
You'd need this in your config to add a thermostatically controlled fan for the hotend.
; Fans M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on when hotend is 45c
For fan 2 and the leds it would be the same as your fan0, except F2 and P2
; Fans M950 F2 C"fan2" Q500 ; create fan 2 on pin fan1 and set its frequency M106 P2 S1 H-1 ; set fan 2 for LED controlled by slider. on by default.
The Q value is the PID frequency and you can adjust it needed for fans or LEDs. Different fans and leds will work differently sometimes.
Awesome, after I'm pid-tuned I'll put the patient back on the operating table and flip things around a bit.
@Phaedrux Thank you so much for the tips. The 500 seems to be working good for the fans I have in place at the moment, but I could totally see the LEDs being more fickle, and it's great to know what lever to start with.
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
You're well on your way now that you have the right firmware and config paired.
When in doubt there's the gcode wiki. https://duet3d.dozuki.com/Wiki/Gcode
I'll be curious to see what the calibration cube looks like once this is all set.
The one on the v2 firmware looked pretty good, aside from some weirdness around the edge corners of the X, even after doing an extruder calibration.
Any recommendation on the best balance for auto bed leveling? Is there a such thing as "too many points of data" if I'm willing to wait for it to take tons of measurements?
On the Wanhao controller, there was only enough memory (or something) for Marlin to handle 9 points of data, but it seemed to still work fairly well.
This printer was a super cheap open-box-special, and I'm fairly certain it was open box because whoever got it realized the bed was ... we'll say "special".
My lovely build bed, btw... lol...
