    Maestro SD Pinout?
    334
    • cabal2000undefined
      cabal2000
      Hi guys. Is the SD port/pinout the same as whats on a PC mother board? The reason I am asking is to mod the port to accept a USB 2.0 thumb drive rather than a SD card. Just a thought.
      • Vetiundefined
        Veti
        you are planning to modify the firmware as well?
        cabal2000undefined 1 Reply Last reply Reply Quote 0
          cabal2000 @Veti
          @Veti may have to. But right now it just a thought!!
            cabal2000
            The micro usb port!! Can you not transfer file through it? Maybe user, micro usb to USB. humm
            Vetiundefined A Former User? 2 Replies Last reply Reply Quote 0
            • Vetiundefined
              Veti
              you will find the wiring definition here
              https://github.com/Duet3D/Duet-2-Hardware/tree/master/Duet2/Duet2Maestro_v1.0
              • Vetiundefined
                Veti @cabal2000
                @cabal2000 said in Maestro SD Pinout?:
                no there is no support for usb otg there. also there is not support for the usb protocol, if you replace the sd slot with a usb port.
                  cabal2000 @Veti
                  @Veti understood
                    A Former User @cabal2000
                    sort of, i could only make it work with a filesize specified
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M559_Upload_file
