Homing fails in all axys
check the output of M119
https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status -
It never reachs the endstops, and when I force the home process, it slams against the endstops.
@rodolfo_paulo said in Homing fails in all axys:
Z2560
Thats an unusual Number for steps/mm, what setup is that?
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1you have not set up your thermistors yet. B4138 is the default and not correct for your printer.
loop up the specs for your thermistor. -
@rodolfo_paulo
whats the output? -
@Veti It is a Hypercube Evolution 2020
@rodolfo_paulo You may not moving far enough for the initial movement in the homing files.
i mean what leadscrew are you using to get that Z2560.
@Veti Endstops - X: at min stop, Y: at min stop, Z: at min stop, Z probe: not stopped
now press and hold one endstop and post the output again.
@Veti M119
Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stoppedBut I do not have a Z probe... Should this be appearing?
M574 X1 Y1 Z1 S1 ; set active high endstops
change this line to
M574 X1 Y1 Z1 S0 ; set active low endstops -
@Veti , you are a life saver! It worked just fine!!!
Regarding the leadscrew, I've must have chaged that when I compiled a new instalation in the RRF Config Tool. I'm using an 8mm, step 4 lead screw...
Is this correct?
8mm 4 start leadscrew with a 1.8 degree motor would be 400
@Veti , if you ever stop by Portugal, I'll buy you a crate of beer or wine, which one you prefer!
Thanks a lot! Now it's calibration time...
But I still don't understand why did it all go bezerk, with the normal shutdown...
i started out with a 2020 hypercube as well, but have converted it to a blv cube since then.
@Veti What are the main differences, besides the mgn rail?
@rodolfo_paulo
the parts are sturdier.and now all metal parts have been released.
https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube -
@Veti Thanks once again!!!
@Veti said in Homing fails in all axys:
@rodolfo_paulo
https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cubeI just checked the prices at AliExpress.
For the kit with the better parts it's more than $900. Then you get to pay more than $500 shipping.
I'm not used to seeing prices like that out of China.
@fcwilt said in Homing fails in all axys:
it was not designed in china. the stores just offer kits.
the project site has a bom that you source yourself.
the kit you are looking at has original hiwin rails
