    Homing fails in all axys
    738
    • rodolfo_pauloundefined
      rodolfo_paulo @Veti
      @Veti M119
      Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped
      But I do not have a Z probe... Should this be appearing?
      • Vetiundefined
        Veti
        @rodolfo_paulo said in Homing fails in all axys:
        M574 X1 Y1 Z1 S1 ; set active high endstops
        change this line to
        M574 X1 Y1 Z1 S0 ; set active low endstops
        rodolfo_pauloundefined 1 Reply Last reply Reply Quote 1
          rodolfo_paulo @Veti
          @Veti , you are a life saver! It worked just fine!!!
          Regarding the leadscrew, I've must have chaged that when I compiled a new instalation in the RRF Config Tool. I'm using an 8mm, step 4 lead screw...
          Is this correct?
          • Vetiundefined
            Veti
            8mm 4 start leadscrew with a 1.8 degree motor would be 400
              rodolfo_paulo @Veti
              @Veti , if you ever stop by Portugal, I'll buy you a crate of beer or wine, which one you prefer!
              Thanks a lot! Now it's calibration time...
              But I still don't understand why did it all go bezerk, with the normal shutdown...
              • Vetiundefined
                Veti
                i started out with a 2020 hypercube as well, but have converted it to a blv cube since then.
                rodolfo_pauloundefined 1 Reply Last reply Reply Quote 0
                  rodolfo_paulo @Veti
                  @Veti What are the main differences, besides the mgn rail?
                  • Vetiundefined
                    Veti @rodolfo_paulo
                    @rodolfo_paulo
                    the parts are sturdier.
                    and now all metal parts have been released.
                    https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube
                    rodolfo_pauloundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                      rodolfo_paulo @Veti
                      @Veti Thanks once again!!!
                      • fcwiltundefined
                        fcwilt @Veti
                        @Veti said in Homing fails in all axys:
                        @rodolfo_paulo
                        I just checked the prices at AliExpress.
                        For the kit with the better parts it's more than $900. Then you get to pay more than $500 shipping.
                        I'm not used to seeing prices like that out of China.
                        • Vetiundefined
                          Veti @fcwilt
                          @fcwilt said in Homing fails in all axys:
                          it was not designed in china. the stores just offer kits.
                          the project site has a bom that you source yourself.
                          the kit you are looking at has original hiwin rails
                          • fcwiltundefined
                            fcwilt @Veti
                            Yes that much was clear. Still, I've purchased a few kits from China but none as pricey as that.
                            Given I have four kits awaiting assembly I don't think the wife would understand why I needed yet another. 😉
                            • Vetiundefined
                              Veti @fcwilt
                              @fcwilt
                              the lite kit is a lot cheaper. it comes without the fancy stuff like led, panels etc.
                              • fcwiltundefined
                                fcwilt @Veti
                                @fcwilt
                                "Lite Kit" - where would I find that?
                                • Vetiundefined
                                  Veti @fcwilt
                                  @fcwilt
                                  https://www.aliexpress.com/item/4000374263194.html
                                  but i would check if you can source the extrusion locally.
                                  because thats what makes it expensive to ship
                                  • fcwiltundefined
                                    fcwilt @Veti
                                    Thanks much. If a kit includes accurately cut parts I rather buy them then cut them myself.
                                    I've cut lots over the years and am rather tired of it.
