    Help PID tuning Dyzend Pro
    Firmware installation
    5.9k
      Ok if that successfully worked you can do as DC42 said above and edit the resulting M307 command in config-overide to increase the D value.
      If you have already run heater tuning and copied the resulting values into your M307 H1 command in config.g, increase the D parameter in that command until the temperature is stable when the print head is not moving. Try increasing it by 30% initially.
      • chris974Mundefined
        chris974M
        Ok je vais essayer sa
          chris974M
          temp. régler a 220 for test
          elle monte a 232 avant de descendre vraiment doucement jusqu'à 220
            Phaedrux Moderator @chris974M
            @chris974M said in Dyzend Pro:
            temp. set to 220 for test
            it goes up to 232 before going down really slowly to 220
            If it overshoots the target, increase the A parameter. Try increasing/decreasing it by 5% or 10%.
            https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control#Section_Manual_adjustments_to_the_heater_model_parameters
            chris974Mundefined 2 Replies Last reply Reply Quote 0
              chris974M
              et la température se stabilise pas
                chris974M @Phaedrux
                @Phaedrux
                config.g or config-override.g
                  Your tuned values are stored in config-override.g You can edit them there, but if you ever re-tune they will get over wrote, so you should probably cut and paste the M307 H1 command from config-override.g into config.g. so you can edit it there.
                  Also, have you seen this from Dyze?
                  https://docs.dyzedesign.com/hotends.html#reprap-firmware
                  chris974Mundefined 1 Reply Last reply Reply Quote 0
                    chris974M @Phaedrux
                    @Phaedrux
                    PID Troubleshooting
                    The first thing we would recommend with the PID Tuning if you have any issues is to increase the functional range. Because our heater cartridge is really fast, the PID functional range might be too slow and cause some overshoot issues.
                    #define PID_FUNCTIONAL_RANGE 40 /For example, set to 40 instead of 10/
                    #Solution 1 – Reduce the Bang Max value
                    This solution is recommended if you don’t plan on printing at high temp or you’re comfortable with flashing your firmware each time you want to do higher temperature printing.
                    For example, on Marlin Firmware, reduce the BANG_MAX value to 200 or even lower.
                    #define BANG_MAX 255
                    #Solution 2 – Change the PID default safety range
                    By default, some firmware defines a low maximum temperature overshoot when doing the PID autotune, which might create some issues with our high-performance heaters. You can change this default behavior with a greater value like 40.
                    For example, on Marlin, in the PID section of configuration.h add:
                    #define MAX_OVERSHOOT_PID_AUTOTUNE 40
                    This is for Marlin ?
                      chris974M @Phaedrux
                      @Phaedrux
                      J'ai essayer plusieurs paramètre sans succès
                        Can you try with these settings in config.g and delete the config-override.g and retry tuning.
                        M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 C5.548428e-8 ; configure sensor 1 as thermistor on pin e0temp
                        M950 H1 C"e0heat" T1                                        ; create nozzle heater output on e0heat and map it to sensor 1
                        M307 H1 A580.4 C256.6 D6.4 S0.50
                        M143 H1 S510
                          chris974M @Phaedrux
                          @Phaedrux
                          C’était mes paramètres de départ impossible avec cela de faire un auto tuning sans préchauffer
                            I'm not sure what else to say. This is a very difficult thermistor/heater combo to auto tube. 50W and 500c. I think your best chance will be to preheat as little as possible so that you can get an auto tune complete and then manually adjust the PID values to try and get it stable at temp.
                            How does it perform with the values provided by Dyze without auto tuning?
                              chris974M
                              la température regler a 220 pour impression elle monte a 231 et descend a 215 puis se mets en fault
                                You can try using M570 H1 P60 T25 S120 to change the sensitivity of heater fault detection to allow time for it to stabilize.
                                https://duet3d.dozuki.com/Wiki/Gcode#Section_M570_Configure_heater_fault_detection
                                  chris974M
                                  Ok i try
                                    chris974M
                                    Si nécessaire, vous pouvez effectuer des ajustements manuels des paramètres du modèle M307, comme suit:
                                    Si pendant le chauffage initial, la température dépasse la cible, réduisez le paramètre A. S'il dépasse la cible, augmentez le paramètre A. Essayez de l'augmenter / le réduire de 5% ou 10%.
                                    cela doit etre fait dans config-override.g
                                      @chris974M It must be done to the M307 command that is being sent last. So if you have an M307 H1 in config-override.g then you should change that one, but as I said before, cut and paste it into config.g and remove it from config-override.
                                        chris974M
                                        c'est difficile a comprendre et régler
                                          chris974M
                                          Error: Heater 1 fault: temperature excursion exceeded 15.0°C (target 220.0°C, actual 236.8°C)
                                            Did you add the M570 command I posted?
