    G29 failing height map for a core XY config with fixed bed
    1.2k
    • campeancalinundefined
      campeancalin
      M208
      Axis limits X0.0:600.0, Y0.0:600.0, Z0.0:525.0
      • fcwiltundefined
        fcwilt @campeancalin
        @campeancalin said in G29 failing height map for a core XY config with fixed bed:
        M208
        Wow. That is big.
        As a test could you do this:
        • set the Z=0 datum, positioning the probe at 300, 300
        • create a test height map using M557 X290:310 Y290:310 P3. This would be a 9 point map including 300,300
        • use G29 S1 to load that map and see if you get the error
        This is just for testing, it is not a height map you would ever actually use for printing.
        campeancalinundefined 1 Reply Last reply Reply Quote 0
          campeancalin @fcwilt
          @fcwilt
          G29
          Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
          9 points probed, min error 0.110, max error 0.190, mean 0.152, deviation 0.024
          Height map saved to file 0:/sys/heightmap.csvheightmap(1).csv
            campeancalin
            The M557 command should be included in the config.g file?
              campeancalin @campeancalin
              @all I mean, once all is good with the mesh probe, one should define the M557 within the config.g file? So so the start /end scripts within the slicer would remain relative?
                Yes M557 should be in config.g
                Please post your config.g, homeall.g, homez.g, bed.g files.
                Also post the results of M122 and M98 P"config.g".
                And your slicer start gcode.
                That will give us enough information to help you.
                campeancalinundefined 2 Replies Last reply Reply Quote 0
                  campeancalin @Phaedrux
                  @Phaedrux
                  config.g
                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 05 2020 11:50:08 GMT+0300 (Eastern European Summer Time)
                  G90                                                ; send absolute coordinates...
                  M83                                                ; ...but relative extruder moves
                  M550 P"Oscar"                                      ; set printer name
                  M669 K1                                            ; select CoreXY mode
                  M551 P""                                           ; set password
                  M552 S1                                            ; enable network
                  M586 P0 S1                                         ; enable HTTP
                  M586 P1 S1                                         ; enable FTP
                  M586 P2 S0                                         ; disable Telnet
                  M584 X1 Y0 Z2 E3:4                                 ; set drive mapping; INIT:X=0; Y=1; Z2;E3:4
                  M569 P0 S0                                         ; physical drive 0 goes backwards
                  M569 P1 S0                                         ; physical drive 1 goes backwards
                  M569 P2 S1                                         ; physical drive 2 goes FORWARDS
                  M569 P3 S1                                         ; physical drive 3 goes FORWARDS
                  M569 P4 S0                                         ; physical drive 4 goes backwards
                  M350 X16 Y16 Z16:16 E16:16 I1                      ; configure microstepping with interpolation ; INIT- M350 X16 Y16 Z16 E16:16 I1
                  M92 X160.00 Y160.00 Z3200.00 E881.10:881.10        ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E120.00:120.00         ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z360.00 E1200.00:1200.00    ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E250.00:250.00         ; set accelerations (mm/s^2)
                  M906 X1200 Y1200 Z1200 E1200:1200 I80              ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                                    ; Set idle timeout
                  M208 X0 Y0 Z0 S1                                   ; set axis minima
                  M208 X600 Y600 Z525 S0                             ; set axis maxima
                  M574 X1 S1 P"!xstop"                                ; configure active-high endstop for low end on X via pin xstop -added "! to xstop"
                  M574 Y1 S1 P"!ystop"                                ; configure active-high endstop for low end on Y via pin ystop  - added"! to xstop"
                  M574 Z1 S2                                          ; configure Z-probe endstop for low end on Z
                  M950 S0 C"duex.pwm5"                               ; create servo pin 0 for BLTouch
                  M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
                  G31 P25 X20 Y37 Z2.21                          ; set Z probe trigger value, offset and trigger height- changed from 3.5 to 2.19 to -0.797,to 2.373 to 2.21
                  M557 X15:470 Y15:470 S20                           ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                            ; map heated bed to heater 0
                  M143 H0 S250                                       ; set temperature limit for heater 0 to 120C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                  M308 S2 P"e1temp" Y"thermistor" T100000 B4138      ; configure sensor 2 as thermistor on pin e1temp
                  M950 H2 C"e1heat" T2                               ; create nozzle heater output on e1heat and map it to sensor 2
                  M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                  M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
                  M563 P0 S"Tool 1" D0 H1 F0                         ; define tool 0
                  G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                  G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                  M563 P1 S"Tool 2" D1 H2 F0                         ; define tool 1
                  G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
                  G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
                  M912 P0 S-16.95                                    ; adjustment of the MCU temp read
                  M575 P1 S1 B57600                                  ; enable support for PanelDue
                  M501                                               ; load saved parameters from non-volatile memory
                  Bellow there is homeall:
                  ; homeall.g
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 05 2020 11:50:09 GMT+0300 (Eastern European Summer Time)
                  M98 P"homex.g"
                  M98 P"homey.g"
                  M98 P"homez.g"
                  And the homez:
                  ; homez.g
                  ; called to home the Z axis
                  G91            ; relative positioning
                  G1 H2 Z5 F800  ; lift Z relative to current position
                  G90            ; absolute positioning
                  G1 X20 Y37 F2400 ; go to first probe point
                  G30            ; home Z by probing the bed
                  ;G29 S1         ; autoload the height map
                  G1 Z2 F100    ; lift Z relative to current position
                  M122 is bellow:
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-917NK-F23T0-6JKFA-3S86Q-KZBSF
                  Used output buffers: 3 of 24 (14 max)
                  Static ram: 27980
                  Dynamic ram: 94972 of which 20 recycled
                  Exception stack ram used: 568
                  Never used ram: 7532
                  Tasks: NETWORK(blocked,368) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1816) IDLE(ready,80)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:10:14 ago, cause: power up
                  Last software reset at 2020-10-13 17:56, reason: User, spinning module GCodes, available RAM 7276 bytes (slot 3)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                  Error status: 0
                  MCU temperature: min 14.5, current 18.3, max 18.9
                  Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: standstill, SG min/max 0/50
                  Driver 1: standstill, SG min/max 0/18
                  Driver 2: standstill, SG min/max 0/329
                  Driver 5: standstill, SG min/max not available
                  Driver 6: standstill, SG min/max not available
                  Driver 7: standstill, SG min/max not available
                  Date/time: 2020-10-13 21:26:43
                  Cache data hit count 1075521745
                  Slowest loop: 7.55ms; fastest: 0.12ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 4.1ms, write time 0.0ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 50413ms
                  === MainDDARing ===
                  Scheduled moves: 23, completed moves: 23, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 40.14ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  - WiFi -
                  Network state is active
                  WiFi firmware version 1.23
                  WiFi MAC address ec:fa:bc:02:19:4c
                  WiFi Vcc 3.44, reset reason Unknown
                  WiFi flash size 4194304, free heap 25256
                  WiFi IP address 192.168.0.100
                  WiFi signal strength -53dBm, reconnections 0, sleep mode modem
                  === DueX ===
                  Read count 1, 0.10 reads/min
                  and the M98 P"config.g".:
                  	M98 P"config.g"
                  Error: in file macro line 13 column 9: M551: non-empty string expected
                  HTTP is enabled on port 80
                  FTP is enabled on port 21
                  TELNET is disabled
                  Error: bad grid definition: Too many grid points; suggest increase spacing to 22.8mm
                  Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                  Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 532C
                  Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 597C
                  Edit: formatting
                    in homez you should change the position of the probe to the center of the bed before doing G30.
                    As the error says, your M557 has too many points. Change the spacing to at least S22.8 to stay within the limit of 441 points.
                    Otherwise that looks ok. Then you just need to modify your slicer start gcode so that it has a G28 and then G29 S1 to load the heightmap.
                    • fcwiltundefined
                      @fcwilt
                      G29
                      So you did something like this:
                      To create the test height map:
                      G1 X290 Y290 ; position probe at bed center
                      G30; probe the bed and set the Z=0 datum
                      M557 X290:310 Y290:310 P3 ; set the probing grid
                      G29; probe the bed and create the height map
                      To load the test height map:
                      G29 S1; load the existing height map
                        campeancalin
                        This post is deleted!
                          @Phaedrux
                          Bellow you have the slicer star g code:
                          G28 ; home all axes
                          G29 S1
                          G1 X20 Y37 Z0.5
                          G1 X10 Y10 F1500 ; move to prime
                          G1 Z0.2 F3000 ; get ready to prime
                          G1 X100 F5000 ; quick wipe
                          campeancalinundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            After the G28 and before G29 S1 , there has to be the G30 command?
                            • fcwiltundefined
                              It depends on what homeall.g does.
                              I don't use my Z probe for homing Z so I need to use G30 by itself before creating the height map and again before loading the height map.
                              The probe point for the G30 must be the same in both cases.
                              Your homez.g file uses G1 X20 Y37 F2400. I strongly suggest you use the center of the bed for G30.
                              Now your G31 command has the offsets of X=10 and Y=10.
                              Are you those values are correct? That puts the Z probe very close to the hotend, closer than my probe could be.
                              In any case, assuming the offsets are correct the command to position for G30 would be G1 X290 Y290 F2400.
                              With that change then as long as you use G28 before creating the height and loading the height map it should work fine.
                              campeancalinundefined 1 Reply Last reply Reply Quote 1
                                @fcwilt Thank you for your reply.
                                The homez.g has been changed :
                                ; homez.g
                                G1 X270 Y270 F2400 ; go to first probe point
                                Also the G31 command from config.g has been changed:
                                G31 P25 X20 Y37 Z2.23
                                  campeancalin
                                  campeancalin
                                  campeancalin 14 Oct 2020, 16:19
                                  @fcwilt: while posting the homez.g file , I noticed something that I forgot to take in consideration; the new homez.g file is bellow:
                                  ; homez.g
                                  G29 S1 ; autoload the height map -- initially was commented
                                  G30 ; home Z by probing the bed -- this was before G29
                                  • fcwiltundefined
                                    OK those offsets looks better.
                                    Assuming the center of the bed is X300, Y300 the command to position for G30 would be G1 X280 Y263.
                                    To determine those values I did that math: X280 = X300 - X20 and Y263 = Y300 - Y37
                                    And I assume you are going to do the G29 S1 somewhere else?
                                      @fcwilt the G29 S1 is called for in homez.g, and also , I've written it in the printing start script
                                      ; homez.g
                                      And the start script for printing:
                                      G28 ; home all axes
                                      G29 S1
                                        However I'm not really too sure about G29 S1 in the start script , if I already call for G 29 S1 in homez.g
                                        • fcwiltundefined
                                          I do things a little different from many folks.
                                          For instance I have a macro (map_create.g) to create the height map. It performs all the commands needed to insure the map is correct. It does not depend on anything else (like config.g or homeall.g) to have done some important commands first. So when I run the macro I know that height map is created correctly.
                                          Likewise I have a macro (map_load.g) to load the height map. And like the macro described above it does not depend on anything else. It does assume the height map has been created.
                                          As you know most slicers can execute code prior to starting a print and after finishing a print.
                                          Again I do not rely on the slicer to do everything that needs to be done to start or end a print.
                                          Instead I have two macros (print_begin.g and print_end.g) that are invoked by the slicer.
                                          One of the many things that print_begin.g does is to invoke map_load.g
                                          If I desired I could have it instead invoke map_create.g if I wished to create the height map at the start of every print.
                                            @fcwilt Can you share an example of each of the macros you specify? Just so I have an idea where to start from.
