Change GUI Design on PanelDue
Hello guys, you have a great forum here! Very polite and active: that's awesome. I have simple question: Can i change the GUI (Graphical User Interface) on the PanelDue!? I would like to pick other colors and so.. it shouldn't be a big deal I think?! Maybe someone could give me a hint where to begin. Thx a lot. Cheers
you can find the firmware files here
https://github.com/Duet3D/PanelDueFirmware -
@Veti : thx a lot! your link helped me to understand..
Okey I think I got it: the webinterface can be changed with CSS .. but does that also change the look on the paneldue?!Does the PanelDue has a browser built in!?
no you will need to change the sources yourself and compile it.
@Veti :Do you mean I have to change the files with "..cpp"(C++?!) and then compile them!? So it is a big deal!?
@Area51 said in Change GUI Design on PanelDue:
CSS
no css, just c++ https://github.com/Duet3D/PanelDueFirmware/blob/master/src/ColourSchemes.cpp
then to build https://github.com/Duet3D/PanelDueFirmware/blob/master/BuildInstructions.md
yes. remember that these are embedded devices. every bit counts. so not every feature has space on the device
Okey thx a lot. I'll try to change the looks. Wish me luck.. ^^
@bearer: hmm wait a sec. I have already changed the looks of the webinterface. And I only did it with HTML/CSS. Is there a benefit if I do everything in cpp?
@Area51 The looks of the web interface are not C++, it's HTML/CSS/etc. like you discovered. The PanelDue is much different.
@Area51
the paneldue does not work with css. its not a web browser -
@Area51 @bearer linked to the file that holds the color schemes. You can edit one of the three schemes to your liking and then select this one on the Setup tab after compiling and flashing.
EDIT: The available color names you will find in the corresponding
.hpp
header file.EDIT 2: but you are not limited to these. PanelDue uses 16-bit color (5-6-5). You can select any color you want and convert it to 16-bit representation and use that.
@wilriker: okey thx. That should be easy. Even for me ^^ what if I want to change buttondesign!? or if I want to add a picture of my dog in the background?! Where should I start, which file in git?
@Area51 Changing button layout completely will lead you into the rabbit hole of framebuffer painting.
It's all inDisplay.cpp
and starts withButtonBase::DrawOutline()
and continues with the various button relatedRefresh()
methods.To get the picture of your dog in the background you need to convert this into one of two formats. Either a 4-bit palletted byte representation or a (run length encoding compressed) 16-bit color representation. I will release a small tool soon to do at least the former but I currently fail to create valid output for the latter.
Is it possible to update the Duet via Wifi?!
@Area51
please read the documentation
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware -
@wilriker said in Change GUI Design on PanelDue:
And now I managed to get this fixed. It's a new implemention of
bmp2c
written in Go and pre-compiled for the three major OS's. You can find it in thedev
branch of PanelDueFirmware in the directoryTools/gobmp2c/(linux|macos|win)
. It's a command line toolIt can be used to either convert Icons into paletted byte representation (check
bmp2c.go
functiongetPaletteIndex()
for available colors and source colors that convert to that). That will output contents for aC++
header file.The other mode is adding the
-binary
parameter and that is supposed to be used when you convert a splash screen into a RLE compressed 16-bit color representation.I will add a README the coming days but wanted to just put a short notice into this thread already.
That would be a great idea.
Hi did anyone manage to make changes? If there is anyone that knows how I have a paid project if anyone is interested.
Martin
