    Fine tuning the Magnetic Filament Monitor
    Filament Monitor
    999
      T3P3Tony administrators
      I have put some documentation for this here:
      https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion?#Section_Flashing_the_firmware
      • mwolterundefined
        mwolter
        I have three of the magnetic filament monitors and they also report over extrusion occasionally. From what I can tell, they most often report over extrusion on very short infill patterns. All three are version 2.0 and I would like to update them to 3.0 to see if this helps.
        My question, is there a wiring diagram and STL for the pogo pins?
          the pogo pins are a standard ISP 6 pin pinout:
          Updated the documentation to show this image.
          mwolterundefined 1 Reply Last reply Reply Quote 1
          • mwolterundefined
            mwolter @T3P3Tony
            @T3P3Tony
            Followed the steps to program the MFM and the ELF software file in the release-44a directory on github is v1. This is the URL of the file https://github.com/Duet3D/MagneticFilamentMonitor/raw/master/Release-44a/FilamentSensor.elf.
            As you can see in the screenshot below, it was v2 before uploading and is now v1. Did I do something improperly? Or is there a link for v3?
            Here is the output from avrdude when uploading the file
            C:\avrdude>avrdude.exe -pt44 -cusbtiny -Uflash:w:FilamentSensor.elf:e
            avrdude.exe: AVR device initialized and ready to accept instructions
            Reading | ################################################## | 100% 0.02s
            avrdude.exe: Device signature = 0x1e9207 (probably t44)
            avrdude.exe: NOTE: "flash" memory has been specified, an erase cycle will be performed
                         To disable this feature, specify the -D option.
            avrdude.exe: erasing chip
            avrdude.exe: reading input file "FilamentSensor.elf"
            avrdude.exe: writing flash (1826 bytes):
            Writing | ################################################## | 100% 1.41s
            avrdude.exe: 1826 bytes of flash written
            avrdude.exe: verifying flash memory against FilamentSensor.elf:
            avrdude.exe: load data flash data from input file FilamentSensor.elf:
            avrdude.exe: input file FilamentSensor.elf contains 1826 bytes
            avrdude.exe: reading on-chip flash data:
            Reading | ################################################## | 100% 1.14s
            avrdude.exe: verifying ...
            avrdude.exe: 1826 bytes of flash verified
            avrdude.exe: safemode: Fuses OK (E:FF, H:DF, L:E2)
            avrdude.exe done.  Thank you.
            Also, receiving the following error when setting the fuses. Not sure if this is related. Are additional files needed to set the fuses?
            C:\avrdude>avrdude.exe -p t44 -c usbtiny -U lfuse_w_0xe2_m -U hfuse_w_0xdf_m -U efuse_w_0xff_m
            Reading | ################################################## | 100% 0.01s
            avrdude.exe: reading input file "lfuse_w_0xe2_m"
            avrdude.exe: error opening lfuse_w_0xe2_m: No such file or directory
            avrdude.exe: can't determine file format for lfuse_w_0xe2_m, specify explicitly
            avrdude.exe: read from file 'lfuse_w_0xe2_m' failed
            Thanks for your help.
            • mwolterundefined
              mwolter
              @T3P3Tony @dc42 Can you help with this? Did I do something wrong or was v1 firmware posted by mistake?
                Fuse setting has an error, should be:
                C:\avrdude\avrdude -p t44 -c usbtiny -U lfuse:w:0xe2:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m
                Looks like the colons were removed on the Dozuki site and replaced with underscores 😖 i have updated that. so should work now but I don't think that is the cause of this issue
                please try this firmware:
                FilamentSensor.elf
                • mwolterundefined
                  mwolter
                  @T3P3Tony
                  Thank you for the reply. Unfortunately that firmware file also reports as v1. Not sure if this makes a difference or not but Release 44a and the file you uploaded are both 32,204 bytes.
                    I will have a look, which version of the filament monitor board do you have?
                    • mwolterundefined
                      mwolter
                      @T3P3Tony
                      I have three and they all were purchased late 2019. This particular one was purchased November 16, 2019 from Filastruder. They all say 1.7 but I believe they are 1.7a.
                      • mwolterundefined
                        mwolter
                        @T3P3Tony Not sure if you saw the last post but would like to get this machine running again. Thanks!
                          hi @mwolter yes those use the attiny44a so the version 3 firmware that I shared is right for that. I am very surprised that it shows up as version 1.
                          I got a version 1.7 sensor from my spares and flashed the firmware to it (there are a few minor differences between 1.7 and 1.7a - none that should effect his but I may as well have exactly the setup you have).
                          This is the response from a printer running RRF 2.0.5.1:daf18c35-7a1f-4d5c-9cd2-c8dcb34340ea-image.png
                          Error code 6 is expected because i just plugged the board in no magnet to detect.
                          The key point is its showing as version 3. This is the firmware I flashed
                          FilamentSensor.elf
                          please download and overwrite whatever firmware you have with this one ☝ and test again.
                          Since it originally changed from version 2 to version 1, to me that indicates it is likely to be an issue with the firmware file being flashed
                          • mwolterundefined
                            mwolter
                            @T3P3Tony
                            Thank you, that worked. I believe the issue was that no magnet was detected. Mounted the board in it's proper location (next to the magnet) and it reported v3. With it just plugged and hanging in it reported v1. This is a Duet3 no SBC on v3.1.1. Thanks again.
