    Dual Extruder setup (2-1 Mellow Mosquito hotend)
    770
    • Vetiundefined
      Veti
      see
      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_change_files
      • knutselsmurfundefined
        knutselsmurf
        Ok, I have these files now:
        ; tfree0.g
        ; called when tool 0 is freed
        M83 ; relative extruder mode
        G1 E-25 F2500 ; retract 25mm
        ; tfree1.g
        ; called when tool 1 is freed
        ; tpost0.g
        ; called after tool 0 has been selected
        ; Wait for set temperatures to be reached
        M116 P0 ; wait for tool 0 only to reach operating temperature
        G1 E25 F2500 ; undo retraction
        ; tpost1.g
        ; called after tool 1 has been selected
        M116 P1 ; wait for tool 0 only to reach operating temperature
        Dual-color Print job started: printer starts but the nozzle-heater stops heating after a short moment. No errors...
        Any idea?
          Post your gcode file.
            knutselsmurf
            I have done some tests (without gcode print job): when I just heat up the hotend (tool0 is selected on startup) and I purge some filament it works nice. When I click on tool1 then the filament of tool0 is retracted 25mm, after that, tool1 moves 25mm filament.
            When I repeat the selection of both tools a few times, it works but after some time the hotend stops heating.... Active heater setup is changed to 0 also..
            I get an error after some attemps too:
            "T0 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault"
            But that's logic, the hotend is switched off...
            So, I hope somebody can help with this...
            😉 Arthur
              Where are you setting the standby temps with G10?
              Have a read of this to see the sequence of events during a tool change.
                knutselsmurf
                Problem with the heater is fixed: replaced thermistor and heater, SliceEngineering tools now installed..
                  knutselsmurf
                  Printing with just 1 color is ok now..
                  But: I want to print a dual-color print.
                  I have followed the things above but it still doesn't work ok.
                  First extruder 1 is selected, printer purge the hotend and after that it start printing.
                  Then the 2nd color is needed, selection of the 2nd extruder goes well but it must purge first before it can continue printing. Same thing as soon as the 1st extruder is needed for printing.
                  How must this be done ?
                  😉 Arthur
                    knutselsmurf
                    By the way, below is my current configuration:
                    config.g :
                    M550 P"BLV mgn Cube" ; set printer name
                    M669 K1 ; select CoreXY mode
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S1 ; enable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P4 S1 ; physical drive 4 goes forwards
                    M584 X0 Y1 Z2 E3:4 ; set drive mapping
                    M92 X200.00 Y200.00 Z400.00 E420.00:420.00 ; set steps per mm
                    M566 X720.00 Y720.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z1500.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z250.00 E1000.00:1000.00 ; set accelerations (mm/s^2)
                    M906 X1600 Y1600 Z1600 E1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X0 Y5 Z0 S1 ; set axis minima
                    M208 X345 Y350 Z640 S0 ; set axis maxima
                    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                    M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
                    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                    M557 X40:320 Y40:320 S50 ; define mesh grid
                    M143 H0 S100 ; set temperature limit for heater 0 to 100C
                    M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
                    M106 P0 C"BED-FANS" S1 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                    M106 P1 C"HOTEND-FAN" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                    M563 P0 S"Extruder0" D0 H1 F1:1 ; define tool 0
                    M563 P1 S"Extruder1" D1 H1 F1:1 ; define tool 1
                    T0 ; select first tool
                    ; tfree0.g
                    ;M83 ; relative extruder mode
                    ;G1 E-55 F2500 ; retract 55mm
                    M83 ; Relative E mode
                    G92 E0 ; Reset E
                    G1 E-6 F1500 ; Retract 6mm @ 25mm/s
                    G91 ; Relative moves
                    G1 Z1.2 F1000 ; Lift nozzle 1.2mm
                    G90 ; Exact moves
                    G1 X245 F6000 ; Move to PurgeBox
                    G92 E0 ; Reset E
                    G1 E-50 F3000 ; Retract 50mm
                    G92 E0 ; Reset E
                    ; tfree1.g
                    G92 E0 ; Reset E
                    G90 ; Exact moves
                    G92 E0 ; Reset E
                    G92 E0 ; Reset E
                    ; tpost0.g
                    ;G1 E55 F2500 ; undo retraction
                    G92 E0 ; Reset E
                    G1 E56 F3000 ; Extrude 56mm
                    G1 E30 F300 ; Purge 30mm to clear chamber
                    G4 P1000 ; Wait 1s
                    G92 E0 ; Reset E
                    G1 Z-1.2 F1000 ; Lower nozzle 1.2mm
                    G90 ; Exact moves
                    G1 X225 F6000 ; Wipe 1
                    G1 X245 F6000 ; Wipe 2
                    ; tpost1.g
                    M116 P1 ; wait for tool 1 only to reach operating temperature
                    G92 E0 ; Reset E
                    G4 P1000 ; Wait 1s
                    G92 E0 ; Reset E
                    G90 ; Exact moves
                    The above free* and post* files is a copy of another guy with a multi-extruder setup.
                    Don't think this is ok for me, but for starters..
                      Phaedrux Moderator @knutselsmurf
                      @knutselsmurf said in Dual Extruder setup (2-1 Mellow Mosquito hotend):
                      Where is the gcode to cause it to purge the hotend? It should be in your tool change files so that it happens after each tool change on the active tool.
                        knutselsmurf
                        Maybe you can correct/add it for me, I really don't know how to fix this 😉
                          But you're saying it already does a purge for the first tool. What exactly is it doing and when is it doing it? Slicer start gcode? If it's already doing what you want at some point you just need to find where that gcode is so it can be reused/adapted to your other tool and probably moved into the tool change files since it would need to happen when going between t0 and t1 and t1 and t0 again and not just once at the start of a the print.
