    Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home
    4.8k
    • vistalertundefined
      vistalert @Veti
      @Veti not to split hairs...
      I asked "Are we 100% confident P9 has the pullup in place by default."
      You said yes 🙂
      So for a Duet3 (my specific context), would this be correct?
      M558 P9 C"^io7.in" H5 F100 T2000
      Thanks
      • Vetiundefined
        Veti
        yes.
        i said that is what is generated by default if you configure bltouch in the duet configurator.
          vistalert
          Thanks for confirming
          No change in behaviour with the following in config.g
          Home Z, bed continues to move when contact with probe has ocurred.
          • Vetiundefined
            Veti
            can you post your homeall.g ?
            vistalertundefined 1 Reply Last reply Reply Quote 0
              vistalert @Veti
              @Veti I haven't yet got a reliable homeall.g as I haven't commissioned the BLTOUCH.
              I have Home X and Home Y, which are sensorless (pending delivery of endstops)
              So what I'm trying for test purposes is this:
              1. Execute M401 - probe deploys - touch the end of the probe briefly enough to make the BLT light red. It must be released in < 650ms is my understanding, else it errors. At no time during repeated touches does the Z sensor in DWC show anything other than 0.
              2. I use a macro to drop the bed 10mm. I execute HOME Z - with my hand on the power button, because every time I test this, the bed is going to hit the nozzle.
              For what it's worth, this is the homeall.g I've built from copy / paste / learning about sensorless homing:
              My objectives here, home to front left using sensorless. Then move to centre of bed and probe there for Z home. Welcome your comments recommendations, as always.
              M400 					; wait til stuff stops
              M574 X1 Y1 S3 			; use stall guard for endstops
              M201 X2000 Y2000 		; reduce acceleration on X/Y to stop false triggers
              M915 P0:1 S3 R0 F0 H400	; both motors because corexy; Sensitivity 4, don’t take action, don’t filter, 400steps/sec
              G91 					; relative Positioning
              G1 H2 Z5 F1200			; lower the bed
              M913 X44 Y44  			; drop motor currents
              G1 H1 X-500 F5000 		; move until the motor stalls - COARSE HOME
              M913 X100 Y100  		; motor currents back to 100%
              G1 H2 X30 Y0 F1200		; move away from end
              M913 X32 Y32  			; drop motor currents
              G1 H1 Y-500 F4000 		; move until the motor stalls - COARSE HOME
              G1 H2 X0 Y10 F1200		; move away from end
              G90 					; back to absolute positioning
              M201 X3000 Y3000 		; accel back to original
              G90 					; absolute positioning
              G1 X250 Y250 F13000 	; Move x and Y axis over to bed center so probe is on top of bed
              M558 A1 F400 			; Set single probing at faster feed rate
              G30 					; Do a single probe to home our Z axis
              M558 A3 F100 			; Set tripple probing at slower feed rate
              G30 					; Probe again to get a more accurate position
              G28 X Y
              • Vetiundefined
                Veti @vistalert
                @vistalert said in Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home:
                the bltouch pulse is so fast that you will not see it go to 1000.
                have you run the bltouch self test? its
                M280 P0 S120
                (edits it S120)
                  vistalert
                  I will try. But that runs on power up no?
                  At power on, I see the pin bounce twice then the BLT tests with solid red LED.
                  • Vetiundefined
                    Veti @vistalert
                    no the self test will retract and deploy the pin 10 times
                    • Vetiundefined
                      Veti
                      what firmware version are you on (i hope the latest 3.1.1)
                        vistalert @Veti
                        @Veti understood
                        M280 P0 S120 - Don't get any activity from BLT
                        My firmware is:
                        RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
                        • Vetiundefined
                          Veti @vistalert
                          3.01-RC9
                          please update to 3.1.1 there were some versions with bltouch problems
                            vistalert
                            Sure thing
                              vistalert
                              @Veti Completed all the upgrades to 3.1.1
                              Confirming that the BLTOUCH 3.1 self-test does now execute after the upgrade to 3.1.1.
                              M401/402 deploys and retracts.
                              Home Z does not stop the bed raising when probe touches the bed.
                              Lightly touching the probe doesn't register on DWC Z sensor, the value stays at 0.
                              A reminder, that as the bed doesn't retract within 650ms, the BLT goes into error.
                              If I manually push the pin up, then issue the BLT reset command, it does reset ready for next test cycle.
                              So, some progress 🙂
                              Bear in mind I still have questionable bed.g, homez.g - almost all of my config stuff is copy /paste from elsewhere.
                              Not sure if Z endstop setting is needed in config,g as it is put there by the configurator, but then people say it's not needed, and others say it is.
                              Please advise next steps and many thanks for the patient support so far.
                              • Vetiundefined
                                Veti @vistalert
                                i would suggest you create them using the configurator. this will give you clean files with bltouch support. select bltouch there and the generated files should be good.
                                this is not normal, try again with the clean config
                                  vistalert
                                  Got the clean configs.
                                  Do I need to set the Z screw locations AND do something to bed.g in relation to probing close to the screws?
                                  • Vetiundefined
                                    Veti @vistalert
                                    @vistalert
                                    for now focus on the bltouch problem
                                      vistalert
                                      The BLT and bed are intrinsically linked for Z probing, so don't we need to ensure bed.g and homez.g are in alignment?
                                      What steps do you want me to take now that I have the clean files? These files are initially not suitable without editing (which as a newbie is challenging). For example, the Z was travelling way too fast. There's no support in the configurator for triple steppers.
                                      What specific steps do you want me to take with what specific actions from the UI, or GCODE from the console?
                                      I think we need a less generic approach, and I need to be told: do this, expect this.
                                      We spent all day yesterday circling around my wiring, to find we should have started with the firmware version. Today you're telling me to use the configurator and without specific knowledge of the stepper setup, the bed almost shot off the top of the screws at high speed.
                                      • Vetiundefined
                                        Veti @vistalert
                                        the bed.g is used for leveling the bed using independent z motors. this required a working probe.
                                        the homez from the configurator should be correct. please post it to verify.
                                        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help/11
                                        i wanted to rule out any problem in your config file. if the files from the configurator with selected bltouch do not work, we can rule out a config problem.
                                        for the 3 z motor just add the motors back to M584.
                                        to change the speed of z change it in https://configtool.reprapfirmware.org/Motors Max. Speed (mm/s). the default is 3mm/s. is that too fast?
                                        remote debugging is hard. and you did not provide all the information specified in the guide on how to ask for help https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help/11
                                        so post the new config files that you generated.
                                        see if the bltouch is now working. next maybe the port is bad.
                                        so switch to a different port in the configurator and move the wiring.
                                        but to be honest, i think the bltouch is broken.
                                          Please post your new files for 3.1.1 config.g, homing files, bed.g and a thorough description of your printer hardware and we can work from there.
                                            vistalert
                                            Thank you @Phaedrux - I will certainly do that. Also, I'd like to apologise to @Veti for the tone of my previous post. I was a little shaken by what happened with the bed raising, but no excuses. I didn't mean to be rude.
